My Compaq Presario SR5710y monitor will not turn on, but the fans are blowing out air, and the green light is not flashing when I attempt to turn it on?
    New Friend:
  • 75 Answers
Do u have your monitors played into the computer check for lose cables or cables that are unplugged.
Posted on Dec 01, 2014
mellomania
  • 121 Answers
SOURCE: Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Posted on Nov 13, 2007
tbirdfan1
  • 3051 Answers
SOURCE: Compaq Presario S0000/8000 Series hard
is the power supply working have u recently installed a new hard drive or cd rom need to make sure that the wires are securly plugged into the drive and into the board and are plugged in to the drive correctly if this is all ok you may have to get a new drive
Posted on Aug 14, 2008
reb19
  • 112 Answers
SOURCE: Compaq Presario SR1000
Unless compaq displays that message when the computer goes into sleep mode, it could be a virus.
Posted on Nov 09, 2008
SOURCE: Compaq Presario SR1000 desktop boot up problem
nothing to do with the ram ... this motherboard sometimes locks, ( dont ask me why) but if you take out the power cord for 5-10 minutes and then press and hold the front power button on the machine (about 10 seconds) it will reset the board. Plug in the power cord and the basic items, sound, video etc ( some usb devices tend to stop it booting to) boot into windows. Then add the rest of your usb devices ..
Posted on Dec 01, 2008
  • 23 Answers
SOURCE: Power light flashes and computer turns off
This is a 1,2,3 item. If it is not the power supply, the cpu or motherboard are the next likely culprits. Generally, if the power supply is OK, the pc would have the fans running and you should be able to open the case and check the North Bridge, the large chip on the motherboard near the cpu and the cooler on the cpu itself. If they are both still cold, it is most likely the mother board.
It it were the cpu, it won't post, but you should still be able to feel the heat with the back of your fingers, just to be safe and touch it quickly so you don't get burned.
You can also try to remove the ram and try to reboot, if you get a steady series of beeps, you can add 1 stick at a time and reboot just to try to elimanate ram as a potential problem.
My next step would be to remove all of the other cards and add 1 at a time and reboot after each card, I probably removw the 4 pin connectord from the dvd/cd hard drives also ans add 1 at a time.
I know this sounds like a lot of work, but this is how I troubleshoot pc and telephone systems for the last 25 years.
Posted on Jan 25, 2009
Our Compaq Presario SR1538X will not turn on. Help!!..
Sounds like a bad video card or the cable to the monitor could be bad or the monitor itself is bad>
Nov 27, 2011 | HP Compaq Presario SR1538X (PX799AA) PC...
When I attempt to boot the unit, no signal is sent to the monitor or keyboard, nor does the green light next to the power button turn on. The amber light does not, either. The fan will run at high power...
I had the same problem with my computer and the Compaq-HP techs told me to pull the ram out and then put it back in. They called it reseating the ram.
This fixed the problem i had. Try this and good luck.
Feb 14, 2011 | Compaq Presario S4020WM PC Desktop
Compaq Presario SR2150NX doesn't turn on. Front panel green light turns on but nothing else happens (no fans, no boot, no noise, nothing) Please advice
On the back of the Power Supply there should be a Green LED, When you power it on if it is flashing, this means that the Power Supply is dead and you need to replace it.
Apr 14, 2010 | HP Compaq Presario SR2150NX PC Desktop
Changed the CPU fan and now the monitor won't turn on. Power light stays green, and harddrive light stays yellow. Fan is running.
its not problem of fan. re-insert your ram. even if doesnt come then problem with ur motherboard chipset. if in blore call 9972888885
Jan 21, 2010 | Compaq Presario S6000CL (DT072A) PC...
Green light comes on and the fan but monitor will not
Hello.
Could be the monitor or your Presario's VGA card. Swap the monitor with another system to see where the problem lies. If another monitor works on your system , it's your monitor. If another monitor doesn't work, then the problem is the VGA card.
Hope this helps.
Nov 10, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Computer won't turn on, you can hear the fans turn on, and the green lights turn on, but no screen.
check your connections to the monitor and pc make sure all your connections are secure. It could be a bad video card in the pc, bad cable or bad monitor.
Oct 31, 2009 | HP Compaq Presario SR2020NX PC Desktop
Computer Power comes on, shows compaq first screen, then everything stops. press esc, F10 or F12 and nothing happens. just continues to show the compaq screen. Any suggestions?
Try unplugging everything you can from the computer. Only leave keyboard, monitor, and power cables connected. Then try to turn on again. If computer boots now, then start adding peripherals back one at a time, rebooting each time. when you get the hang, there is your suspect peripheral.
Also, is the monitor itself having issues, or is it the computer? Look at the power light on the monitor, is it staying green, or is turning back to same color when it is in standby state?
Oct 02, 2009 | HP Compaq Presario SR1420nx...
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
