Question about Samsung UN60D7050 60 3D-Ready LED-LCD 1080p HDTV
I have a Samsung un60d7050 3d tv I can not synch my samsung 3d bluetooth glasses with any longer. I have used these exact glasses to connect before and I tried 3 separate pairs. I'm thinking the bluet
-I have powered/restarted the TV and retried syncing my glasses. -I have tried to sync 3 separate pairs of 3d glasses and all just continue to flash -i have tried to detect my tv bluetooth connection from both a smartphone and a mac air laptop.
    Top Expert:
  • Samsung Master
  • 75,311 Answers
Contact the authorized service center for Samsung; in this case. http://electronicshelponline.blogspot.com/
Posted on Dec 02, 2014
  • 4234 Answers
SOURCE: How to replace the frony glass on a 50" samsung tv
The cost will depend upon the model of the set. I would suggest that you purchase the service manual which will contain all of the specific instructions on how to replace the glass. You can find this using the model number and the keyword "manual".
Dan
Posted on Mar 17, 2008
SOURCE: Samsung 32" LCD TV
I replaced mainboard imported from germany, new version. fixed the problem, lasted for another 3 weeks and same problem, luckily they sent two cards instead of one and replaced with second mainboard, it is still working, never buy samsung tv again. I did every thing on the mainboard that i could like looking for a dry joint under magnifying glass, power on each connector, i dont have a ociloscope and also some of the parts on the mainboard are impossible to replace or find anyway. sick of opening and closing the stupid thing.
I dont connect anything except skybox to it and dvd player over hdmi, i think the problem could be due to PC connection, i.e. resolution changes causing some effect on the databus on the video processor chip.
Posted on May 28, 2008
  • 92 Answers
SOURCE: Samsung TV can't detect connection to laptop
Make sure you set the laptop to display at a resolution the TV can display, it seems best to start with 1024x768 then work up.
If you are using a VGA - HDMI converter it is possible you will not get a picture.
You should be able to set the laptop to 1024 x 768, plug it into the TV, select PC input on the TV remote, and the picture should appear.
If not, then check you have the monitor output on the laptop switched on, test it with another monitor to be sure.
If all the above still fails to work, and you've checked the cable the TV has a fault.
I hope this helps.
Posted on Mar 28, 2009
  • 127 Answers
SOURCE: I have a Samsung Series 6-650 LCD TV (Model #
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Posted on Mar 02, 2010
SOURCE: optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Posted on May 26, 2010
How do you make Bush TV Passive 3D
Only if it is a 3D television.
Bush 3D TV - Passive 3D TV Bush 3D TVs are exclusively available through Argos. Make sure you check if the Bush 3D TV is passive or active, it isn't always clear on the site. To ensure that everybody can enjoy 3D TV our family packs contain two, four and six pairs of designer 3D glasses by Oskav.
Oskav Designer 3D glasses are compatible with all Bush passive 3D TV
How do you make Bush TV Passive 3D Google Search
Feb 25, 2018 | Bush Televison & Video
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
Jan 31, 2016 | Samsung UN65HU8700 65"" Curved 4K Ultra HD...
Will the Bose 535 Series II work with UHD tv..?
If there is a setup code to the device you want to sync: with this remote, you can.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 26, 2014 | Samsung HU9000 78"" Class 4K UHD Curved 3D...
Hi Guys, I have a Sony 55nx810 TV connected to wifi with the latest update. My 3D, one day just stop working. Since then, in the options menu/3d menu, I only can select: "3D simulatior" or...
Sounds to me like it is the 3d Transmitter, but before you go and buy another one try and do a factory reset on your t.v , maybe this could help everything go back to normal. By the way you have a great tv :) .. if the problem continues call sony customer support 1-877-865-7669. Have a nice day.
Jun 23, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
Missing sync not connecting on my laptop
Wireless or USB? First thing to test is to turn off the PC firewall... you should also look in the Help section of Missing Sync on the PC, there is a 'Fix Connection' button. Go ahead and try to select that and also try to sync again as that restarts all the Missing Sync background processes. It will take a few seconds to restart things and you will get a popup letting you know when its done. Then, try to sync again.
If still not syncing, I would try to start the process over, from the beginning.
1. On your device, Unpair with the desktop (in Missing Sync)...if you are paired
2. Reboot your device
3. Reboot your desktop
4. Verify both device and desktop connected to the WiFi router and you have internet access (can browse the web)On the device, also check this: Settings>Wifi>Wireless Controls> Wifi.
5. Run the Setup Assistant, in Missing Sync on the desktop and it will generate a PassKey
6. Launch Missing Sync on the phone and enter this passkey, and hit the 'Pair' button
7. Now try to sync... Contacts and Calendar syncing are initiated on the phone and synced wirelessly (WiFi or Bluetooth) and not over USB .. Media syncs using the USB cable and its initiated on the desktop.
Jun 22, 2011 | Acer Computers & Internet
I bought this to play 3d ps3 games and the games are working fine. I tested 4 3d games so far and had same problem will all 4. About 2" area on top is not converted to 3d i can see both images...
could be the 3d glasses or your monitor settings or the game itself. make sure the glasses are syncing or play with the settings to see what works. read the manual.
Feb 16, 2018 | Acer HS244HQ Monitor
My sansung pn50a460s4dxza says it is 3d ready. how can i use this feature on my tv.
Your tv is a 2008 model, legacy 3d tv and requires a lot more than a current 3d HDTV does to view 3d. Today with a current 3d HDTV, Normally you only need a 3d source like a 3d Bluray movie and 3d glasses from Samsung and a HDMI cable connection from bluray player to HDTV. See below for your TV. You need a PC and IR emitter and Samsung 3d glasses plus user selected options on the tv.
Samsung 3-D Ready HDTV How do Samsung 3-D Ready HDTVs work?
Samsung 3-D Ready HDTVs are enabled by Digital Light Processing (DLP(R)) or Plasma Display Panel (PDP) engines that are capable of very fast refresh rates (120Hz). The inherent speed of these display technologies enables high quality stereoscopic 3-D by alternatively displaying left and right eye images. The display is synchronised with 3-D shutter glasses to provide the observer with a vivid perception of depth.
How do I connect my PC to a Samsung 3-D Ready HDTV?
The DVI output from the PC's graphics card must be connected to the TV's 3-D compatible HDMI port using a DVI-to-HDMI cable (or a HDMI cable plus a DVI to HDMI adaptor).
Alternatively, some newer graphics cards have a HDMI port instead of a DVI port. In this case, simply use a HDMI cable to connect the PC directly to the TV.
On all models, the 3-D compatible HDMI port is identified by the letters "DVI". (eg, "HDMI 3/DVI IN" or "HDMI 1/DVI IN")
What other equipment do I need to enjoy 3-D on my 3-D Ready HDTV?
  • Windows PC with DVI output
  • Compatible 3-D Shutter glasses and IR emitter with VESA compatible sync connector
How do I connect the IR emitter to the 3-D TV to support wireless 3-D shutter glasses?
The IR emitter should be connected to the "3D SYNC OUT" socket. The emitter should be placed on top of the TV with the LEDs facing towards the room. How do I turn the TV into 3-D mode?
Ensure that the TV source is set to "HDMI 3/DVI" (or "HDMI 1/DVI" for 720p models).
Plasma HDTVs Press the Tools button and select 3D Effect. Update from Off to Mode1.
May 04, 2011 | Samsung PN50C430 50Inch 720p Plasma HDTV...
Cannot get my sony KDL 46HX803, TMR-BR100 transmitter and PS3 to play/sync 3d!! The TV does not seem to recognise the transmitter when plugged in.
I have same problem now. Always worked before. Your post is old. Did you ever get it fixed? I don't know if its ok to put my email address here, buy hoping to solve this. rsmor48@hotmail.com
Any help appreciated.
Roger M
Jan 09, 2011 | Sony TMRBR100 3D Sync Transmitter for 3D...
Samsung UN60D7050 60 3D-Ready LED-LCD 1080p HDTV Logo
159 people viewed this question
Jerry Greenberg
Jerry Greenberg
