Question about Smeg Dishwashers
What does two solid lights on the right hand side of my smeg df 612 se mean
I took the back off and had a look, I've drained it and I'm now stuck
  • 6 Answers
SOURCE: BMW 318 SE warning light
I drive a 2000 5series and the only light that sounds similar is the radiator low water warning light. worth a check.
Posted on Jan 12, 2009
SOURCE: I want to change the door on my Smeg fridge from a
just look how you taken it off easy as that mate
Posted on Nov 15, 2009
  • 8404 Answers
SOURCE: the right side front and back signal lights are on
Please check your flasher. It is round, about 3/4 inch in diameter and about 1/2 inch high. It plugs in.
Expect to pay less than $5.00 for a replacement at an auto parts place of at your Harley Dealer.
If this does not solve your trouble, please post a comment to this question and we will try something else.
Thanks for using FixYa.com
please vote
thanks
a
Posted on Dec 04, 2009
old marine
  • 2126 Answers
SOURCE: What is the hand icon on the bottom right side of
See pages 20 and 39 in the manual. According to this, the hand symbol indicates that you have Image Stabilization set in the 'Continuous' mode (always on). The other modes available are 'Shoot Only', 'Panning' and 'Off'. You select the desired mode at 'IS Mode' on the Menu for Record (camera silhouette at the top) .
Posted on Feb 25, 2010
  • 1218 Answers
SOURCE: Epson 1280 Solid red mainteance light
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5005876-epson_stylus
Posted on Oct 04, 2010
My smeg Module DF 612 SDX7 dishwasher tripped the circuit last night early into its cycle. We could smell burning coming from the dishwasher. Any ideas and what we can do to fix it?
If you can get it to operate for a few seconds, that will at least tell whether the motor is still good and turns freely. Otherwise it sounds like board may have failed.
Jun 21, 2015 | Smeg Dishwashers
Smeg dishwasher leaking from front right hand side, cold leak
The door seal may need replacement, the hot water may soften the seal and fix the leak.
Feb 23, 2015 | Smeg Dishwashers
Smeg D1 612 CA dishwasher wont run
You may have to give a little more information.
Have a look at the manual, here -
http://www.manualslib.com/manual/343502/Smeg-Di612ca.html
and check for error codes/lights etc (p17; faults E1-E9)
Hope this helps
Oct 28, 2013 | Smeg Dishwashers
Loud smeg spin cycle
Open the loading door and place your hand at the top of the inner tub, close to the door opening and lift slightly. Inner and outer tub should move as one solid unit. If there is play between inner and outer tubs, you likely have a tub bearing issue. That is bad news, but repairable if you have the ability to DIY.
If the tubs seem good, then look for a sock between the inner and outer tubs. Often it is in the upper left corner (but could be anywhere) close to the door opening so that you can grab it with your hand or needlenose pliers. If you give the tub a spin you may be able to locate it by sight and feel, or with a flashlight from inside the tub through the drain holes. Also look for an object that may be stuck in one of those drain holes, like a screw, etc. Let me know if this is no help, we will look for other causes.
Jan 25, 2013 | Smeg WDI12 Front Load Washer / Dryer
Error Message SE or 5E, I've cleaned the filters and changed many times the tube of outgoing water, but still no any resolutions, because I still receive the same message, any solutions please?
SE is actually 5E and means that the water has not pumped out of the machine in the time period allowed. It can be caused by a blockage so check the pump by taking off the black cover at the bottom right hand side on the front of the machine, be aware that if there is still water in the machine this will let it all over the floor. There should be a smaller white plug, twist this and pull and a small hose will come out to allow you to (slowly) drain the water.
Aug 14, 2011 | Samsung B1245 Front Load Washer
Dishwasher has a overfill problem rinse light flashing
An Idea: the Overflow sensor or float is bad, stuck, disconnected and its messages to STOP filling aren't getting thru to the CPU
This is usually located in the right frony of the machine or in the side wall. Float types get gummed up with 1/2 dissolved soap powder (god what we do tho the water systems) see if it moves. Sensor types have a hole that feels or senses water. If clogged, they lie. Clean out with toothpick and blast with a bit of hot water and air. Retry
If fixed, let me know... if not, see the yellow pages for parts dealers ;-)
Cheers
Mar 26, 2009 | Smeg 24 in. DWD612SS Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Smeg DF612S
Check to make sure there r no kinks’ in the drain line or that it is not clogged it sounds like the sensor is tripping because there is too much strain on the pump just like a breaker.
Nov 07, 2007 | Smeg 24 in. DWI612 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
