Question about JVC Televison & Video
JVC HD-61Z575 sound has suddenly stopped functioning. Is there a way to check if this is a menu select issue. If I reboot to factory settings will it possibly fix the problem?
    President:
  • JVC Expert
  • 300 Answers
Reset the audio menu.
Is there a selection for EXT speakers or AMP? May be a place to look.
Posted on Feb 27, 2015
BMW Rider
  • 232 Answers
SOURCE: jvc hd ila model hd 52g886 red light blinking, and wont turn on
Hi, don`t know if you`ll be able to find this but D9405 a surface mount diode on the main power supply board is a known issue for yours and many other models, it has to be re-soldered not replaced, other joints in area may also need to be "touched up", other than that I had one where connector CN310 was not seated correctly, one side of plug was cocked way up, other than those 2 you may have a bad ballast (board that the lamp is connected to), Be sure that the lamp door is securely closed as they have a switch built into them and if the switch is not closed the set WILL NOT start, hope this helps you out, BMW Rider
Posted on Dec 12, 2007
SOURCE: model 51f59a hd widescreen aspect settings dont take and picture too big
I called Hitachi and the solution is in your cable remote not your tv remote. Your tv has a aspect menu as does your cable remote. Based on your cable provider you should have a settings or menu button to change the zoom or aspect of your screen. I had the same problem and have Comcast as cable and this worked for me.
Posted on Sep 20, 2008
  • 556 Answers
SOURCE: my tv don't have sound', who can help me !
check and see if you have the center channel on in the menu if you do turn it off and also see if you have the internal speakers turned off if so turn them on.
Posted on Sep 15, 2009
  • 115 Answers
SOURCE: jvc hd-61z575 green and pink screen
I know exactly which 2 dollar part you need to replace. digital-dump@hotmail.com
Posted on Oct 06, 2009
DrewPalmer04
  • 325 Answers
SOURCE: I have a JVC HD-ILA
I only have bad news for you. This tv uses an engine assembly. It is impossible to replace the color wheel only. The entire assembly is quite expensive and wouldn't be worth replacing for a tv of that age. (By expensive, I mean roughly $400-$600, before labor). To replace the assembly the tv is basically broken completely down for this repair too and thus very expensive for labor as well.
Sorry for the bad news, but with no warranty you seem to be out of options. Some people choose to just live with the color issues, while saving for a new tv.
Thank you and have a nice day! :)
Please rate
Posted on Apr 06, 2011
I have a hole in my screen its a jvc
You need to replace the screens. Call JVC with the model# of your set and JVC will tell you the part# so you can ordere a replacement
Mar 15, 2013 | JVC HD-61Z575 61" Rear Projection...
Blue colors are bright green
This model did have problems with : missing color (red,green or blue) and other issues like inverted picture-----it may need the main cpu reprogrammed which is done with a jig and two sd cards loaded into the set that way.
Oct 29, 2012 | JVC HD-61Z575 61" Rear Projection...
My jvc camcorder screen wont work
Sounds like a software issue of your hd camcorder. Which apps do you have loaded? I would try a hard reset. Menu > Settings > SD card and Phone Storage > Factory Reset. If you still have the issue, get the phone swapped out.
Jan 24, 2012 | JVC GR-D850 Mini DV Camcorder
MY jvc kw-nx7000 turns on i get video dvd usb and radio to work propperly with all of the functions however i have absoloutely NO sound!!!! The last time it worked was before i change batterry on my...
first check the volume to be on ..and razed...if this seam not to be the issue ..get into the av menu ..and select sound ..and in there check the out-put ...and select the out-puts in use..
The volume you should select it on the screen and raze it ..not with the remote...
If all these seam to be in order..but you have no sound..you should check the speakers wires to be plugged in ok ..and have no damages..
In the end you can make a reset to factory settings ..and default all ..If it does not have it in the menu ...select the initial settings ..when you first open it ..(probably have to be disconnected to display this menu ..)
I will link the manual for it here ..and you can check it for any other questions ..
http://www.manualnguide.com/dl/21319/
Jan 12, 2011 | JVC KW-NX7000 Car DVD Player
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
Lost the original remote for my sylvania tv and the closed caption is on. how do i get this off my screen without remote?
If there is no on screen menu option, accessible from the console, that you can switch off, the answer to your
question is "You can't".....without obtaining a universal remote that you will install using the codes for the
function of your particular set, and since you have a rear projection model (61 inches, wow!!) every universal
remote normally used for the purpose of home entertainment theater setups will have the code for your set.
Enjoy!!
Apr 17, 2009 | JVC HD-61Z575 61" Rear Projection...
Jvc hd-61z575 green and pink screen
Dec 21, 2008 | JVC HD-61Z575 61" Rear Projection...
JVC Rear Projection
If you still can see the DirecTV guide and menu, the problem could be on your satellite receiver and not the TV. Unplug your receiver and plug it back.
If the rebooting did not work, I would suggest to swap the satellites receivers and see if it works.
Good Luck.
Mar 14, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Jvc hd61z575 61in. rear projection tv won't come on
ok you have defective power supply in hotside section! maybe they have abnormal oscillation!
Oct 11, 2007 | JVC HD-61Z575 61" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
