Question about Cell Phones
<!-- from fixya rte -->How do i replace battery o my jidelai phone - Cell Phones
I have a free government ZTE N817 phone. Is the battery replaceable? I can't seem to get the back off of the phone.Can I replace the battery or do I need to get a new phone?
All phone battery can be replaced. Some battery are removable by users while others are not. However, most non removable batteries have the same way of removing them. Check this out. How To Remove Tecno Camon C8 Battery DEVICETECK
Jun 23, 2017 | ZTE Cell Phones
Goes from full battery to no power when speaking, power lasts approx 15mins !
Hi, when a phone battery is fully charged and it does not stay long to power the phone,You might need to replace the phone battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unable to power up the phone for too long and the phone will go off..
To solve the problem of charging a battery and not lasting too long,you will need to replace the phone battery with a new one.
You can get a replacement battery from nearest outlet store around your area...
Warning before you buy a new battery, make sure that the phone does not get hot when you insert the battery inside the phone...Because that is not a battery fault. It's a phone board problem.
Take care and thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
My battery seems to low batt easily
Hi, when a phone battery is always to low and it does not stay long to power the phone,You might need to replace the phone battery.
You can get a replacement battery battery from nearest outlet store around your area...
May 24, 2011 | Motorola Mobility RAZR V3i Cellular Phone
After full charge, battery lasts about 1 day, with only "device usage" on the battery.
Phone batteries has cells inside them that determines how long the battery life will last..When these cell dies, it will be unabletopower upthe phonefortoo long and the phone will go off..
To solve the problem of charging a battery and notlasting too long,you will need to replace the phone battery with a new one.
May 23, 2011 | HTC Snap S522 Cell Phone
Periodically, the phone will say Warning Check
Your battery is nearing the end of its useful life. If you replace with a new battery, you will likely solve this trouble.
Find replacement at a FixYa.com advertiser, Radio Shack, www.batteries.com or other file retail outlet that sells batteries.
May 14, 2010 | AT&T (00373) Model E2125 Digital 2.4GHz...
It runs low battery every 30 mins
problem can be solved.Does the phone get hot?, If yes,it is a board problem and will definitely run the battery down.
But i if no, that means the cell of the battery is very weak and can power the phone for too long, that is why it goes off.
You need to get new battery.And make sure after purchasing a new battery, you charge the battery for longer hours until it shows 100 percent charged before using it, otherwise the cell of the battery will not work properly.
Have a nice day.
Mar 19, 2010 | Nokia N70 Cellular Phone
GE cordless phone showing low battery (model 27958GE2-A)
Your phone may have a faulty sensor. If the only notification is that your screen displays low battery, and there is no interruption or disruption of service or quality to the product you can most likely leave it as is. If your phone is still under factory warranty, do not replace the battery, ask for a replacement for a faulty product. I would personally test the lifetime of your phone by leaving it off the charger for a day, and if it lasts the entire day without dying, then it is a problem with your phone's sensor / battery indicator. If the phone dies after a few hours of use or standby, then there is a problem with your battery and your battery tester.
Jun 15, 2009 | Uniden Cordless Phone
CARKIT
Perform reset of device:
  1. Remove the battery.
  2. After 3-5 seconds, replace the battery.
  3. Test phone.
If vehicle or wall charger is availalble:
  1. Plug charger into the phone.
  2. Power cycle the phone.
  3. Attempt to place a call then remove charger while call is active.
  4. Test phone.
Attempt to clean the contacts:
  1. Check charging / data port for corrosion / damage.
  2. Remove the battery.
  3. Using a dry clean tooth brush, remove any corrosion from the charging port.
  4. Replace the battery.
  5. Test phone.
If device has been damaged by water, attempt to dry the phone:
  2. Leave phone in a warm dry place for 8 - 10 hours.
  3. Replace the battery.
  4. Test phone.
If nothing works, take to your nearest retail store for additional troubleshooting or replacement.
Sep 06, 2008 | LG VX5300 Cellular Phone
SOS!
Jun 29, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
