Question about Health & Beauty
I have recently bought a Craftmatic CC4 which is 10 years old and am wondering if I should be checking the oil level in the transaxle unit. Whilst it runs fine, there is a clicking sound sound consistent with the wheel revolution after a few minutes of operation. Thanks
  • 1,263 Answers
Hi,i don't advise this...the fluid used is normally a semi fluid grease , however reassembly must be done correctly otherwise you could do some real damage, if there is a click on a complete resolution then i would say a bearing is worn, the worm gear that driven from the motor will be worn and that could be making the click as well but as long as it not slipping and excessively noisy i would leave it alone, the motor also has a bearing that can become noisy ... one thing to note is so you find a worn or damage gear, what are you going to do ?? unless you know someone who can recreate another one ?
if it is noisy the noise could be the sum of all the gears noise so replacing just one gear wouldn't be enough
Regards
Rob
www.gewizrepairs.co.uk
Posted on Dec 02, 2014
Is the engine oil and the transaxle oil the same oil
No they are not the same. The dipsticks for checking the levels are color coded . The transmission is RED and the engine is YELLOW
Jun 04, 2017 | Cars & Trucks
How to check transaxle oil level on troy build riding mower
Most of these transmissions are sealed units requiring no user intervention.
May 04, 2015 | Troy Garden
1996 Honda Accord EX Manual trans. Where is oil level plug. what kind of oil?
All Honda manual transaxles use the Honda Manual Transmission Fluid (MTF) as the original factory fill. This oil is similar to a 10W-30 or 10W-40 viscosity engine oil, and this oil can be substituted temporarily. However, the manufacturer recommends the use of their MTF when changing the fluid.
Level Check
The transaxle fluid should be changed every 90,000 miles (144,000 km) or 6 years under normal driving conditions. In severe driving conditions the fluid should be changed every 30,000 miles (48,000 km) or every 2 years, whichever occurs first.
Make sure the vehicle is on a level surface. If the vehicle is raised, make sure the vehicle is safely supported and level
NOTE: Do not confuse the drain plug with the fill plug.
The fill plug is in the mid section of the transaxle. The drain plug is near the bottom of the transaxle.
  1. The oil level is checked by removing the oil fill plug on the side of the transaxle. The transaxle fluid should just meet the lower threads of the transaxle fill hole.
  2. Remove the oil level check bolt from the side of the transaxle. If oil runs out, or if oil can be felt near the threaded fill hole opening, reinstall and retighten the bolt to 33 ft. lbs. (45 Nm).
  3. If the level needs to be topped off, pour oil in slowly until it begins to run out then, install and tighten the filler bolt to 33 ft. lbs. (45 Nm).
Cheers,
"Please rate this solution or kindly leave a Testimonial"
Sep 05, 2011 | 1996 Honda Accord
Hello i recently bought a 2.8CRD grand voyager and have noticed oil patches on my drive way about the size of a coffee mug, any ideas
firm your description it sounds like oil pan. Did you recently have oil change? Sometimes there's residual (old oil) in frame valleys etc. Just for peace of mind check oil level.
Mar 07, 2011 | 2005 Chrysler Town & Country
Just got 1996 chevy cavalier. Where do you add transmission fluid?
the transmission fluid goes down the dip stick hole ,either use a small funnel or special tranny fluid refill top up bottle
Feb 04, 2011 | 1996 Chevrolet Cavalier
How to check trasmission fluid no dipstick just a red cap
4T40E Automatic Transaxle CAUTION
Removal of the fluid level screw when the transaxle fluid is hot may cause injury. Use care to avoid contact of the transaxle fluid to exhaust pipe. The fluid level screw is intended to be used for diagnosing a transaxle fluid leak or resetting the transaxle fluid level after service that involves a loss of fluid.
  1. The fluid level should be checked when the transaxle is near room temperature or at 104°F (40°C). To acquire this, left the car idle for 3-5 minutes with all of the accessories off. Fig. 5: Location of the fluid level screw and the fill/vent cap needed to check the fluid for the 4T40E automatic transaxle 87951085.gif
  2. Apply the brake, then move the gear shift selector through all gear ranges, pausing three seconds in each range. Shift the lever into P.
  3. Raise and safely support the vehicle.
  4. Place a suitable drain pan under the check plug to catch any fluid that may drip out.
  5. Remove the oil check plug. The oil level should be at the bottom of the oil check hole. Because the transaxle operates correctly over a range of fluid levels, fluid may or may not drain out of the screw hole when the screw is removed.
  6. If fluid drains through the screw hole, the transaxle may have been overfilled. When fluid stops draining, then fluid level is correct and the check plug may be installed. If fluid does not drain through the screw hole, the transaxle fluid may have been low. Add fluid at the vent cap location in 1 pint increments until the oil level is at the bottom of the oil check hole.
  7. Install the oil check plug/fluid level screw and tighten to 10 ft. lbs. (14 Nm).
  8. Carefully lower the vehicle.
Jan 21, 2011 | 1997 Pontiac Sunfire
Where is the transmission dipstick in my manual 1.3 liter 1993 suzuki swift located and where do i fill it up?
LEVEL CHECK With Oil Level Gauge Fig. 1: Manual transaxle oil level check - with level gauge 84241046.gif
  1. Drive the vehicle to bring the transmission up to operating temperature.
  2. With the engine stopped, remove the oil level gauge front the side case of the transaxle.
  3. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  4. Wipe off oil level gauge with clean cloth.
  5. Fit the oil level gauge to the transaxle side case so that the threads rest on top of the case.
  6. Remove the gauge and check oil level. The level should be between FULL and LOW level line.
  7. If the level is below LOW mark, add oil until the proper level is reached.
With Oil Level/Filler Plug
  2. Raise and support the vehicle safely.
  3. Remove the transaxle oil level/filler plug.
  4. Check the color and smell of the oil. If it is black in color or smells burnt, further transmission service is needed.
  5. Transaxle oil level should be even with the bottom of the plug hole. If oil level is low, adjust oil level accordingly.
  6. Install transaxle oil level/filler plug and tighten to 40 ft. lbs. (54 Nm).
  7. Lower the vehicle.
Oct 17, 2010 | 1993 Suzuki Swift
Have craftmatic bed with wireless remote. It stopped working....
while setting ours up last night I noticed that the 3 plugs that go into the moter unit do not like to stay in. have you check to make sure they have not come loose?
Jan 27, 2010 | Health & Beauty
How's YOUR oil pressure behave? ('95 XJ6)
get the oil pressure checked with a master gauge at a garage if ok will be oil gauge sender unit at fault if low with master gauge check oil pressure relief valve on filter housing i assume you have checked oil level
May 17, 2009 | 1986 Jaguar XJ6
I can not locate trans.dip stick on a 1998 Olds Cutlass.
Sorry I think the 1998 cutlass has a 4t40e trans. It has no dipstick. You have to remove a plug by the passenger CV shaft and fill the trans until fluid runs from the plug.
Apr 05, 2009 | 1998 Oldsmobile Cutlass
Health & Beauty Logo
108 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
