Question about Food Mixers
Where do I get a K5A mixer repaired near Killeen, Texas?
Have not done anything yet. Runs okay and mixes okay, but just started making a clicking/chattering noise like an old sewing machine this past week. Mixer is at least 35 years old. I am not using it for fear of making it worse. I am at the fix or replace point.
bigg t
  • 640 Answers
SOURCE: Disassembling the mixer
does the plug run through the base or the back of the unit?
Posted on Aug 01, 2007
  • 45 Answers
SOURCE: Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
  • 25 Answers
SOURCE: kitchenaid mixer mades a high pitch squeak when mixing
Take it to a local repair shop and they should be able to fix it in no time.
Posted on Mar 26, 2008
mastatech
  • 478 Answers
SOURCE: my kitchen aid mixer makes a clicking sound when it is on
Check the motor brushes. You'll see two black plugs with flathead screwdrivera small one, Unscrew to check, if only springs or very worn,youll,know.Its a maintenance problem.
Posted on Mar 11, 2009
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
Kitchenaid k5a
These mixers last for years and years. Aside from the fact that you could have a FIRE from a frayed electrical cord, interruption of power to the motor can cause additional problems. Get the Manual with all of the details on repairing the unit. Replace that power cord NOW! When the Housing is open, take a tooth brush or stiff paint brush and whisk out the debris collected inside over time. Check the contacts on the speed selector and look for any black deposits or surface material that may be there.
Mar 10, 2014 | Food Mixers
KitchenAid k5a arcing on control board
it was stuck on high speed because the phase control board went out, your fix may not be absolutely 100% and it is now causing an uneven distribution of the electric charge in the mixer and it is arching. My recommendation is to replace the speed control board (black and copper plate) and the phase control board. i bet it fixes the problem as these are the two parts that regulate the electricity in the mixer. Hope that helps. Buy the way if you don't fix the problem and continue to use the mixer you may have to replace the motor eventually as you can cause the armature and stator to short or burn out.
Feb 03, 2013 | KitchenAid K5ADH 5 Quart Mixer Dough Hook...
My artisan mixer is leaving black bits in my mix?
if its possible to separate out a few samples of the black bits and crush them against some white paper with your finger tip and make a mark on the paper , this is a sign that a few little devices inside your mixer are wearing down and coming off , there called brushes and there made from "carbon" that is only about the second most common element in the universe these tiny "brushes" are a part of your motor that runs your blender , but relax any qualified appliance repair center can install a new set of brushes and clean out the remnants of the old ones for a reasonable cost , im sure well less the cost of a new one then it's good to go for a long time of use again
May 26, 2017 | KitchenAid Artisan Series Tilt-Head Stand...
The capacitor on the speed switch is burning out.
I have found that the capacitor is no longer available, along with
any of the motor parts. Armature, brushes, motor end bearing, etc, are not available.
Dec 18, 2009 | KitchenAid K5AWH Stand Mixer
Leaks oil when mixing. the area where you put the beaters leaks a small amount of oil only when mixing.
The grease inside has liquefied instead of being a paste. This can happen by over heating the mixer, keeping near a heat source or a bad gasket. I suggest getting it repacked with grease and replacing the gasket before you start to ruin the gears.
Also the grease although not something you'd consider edible is food safe.
Nov 16, 2009 | KitchenAid K45SS Classic Stand Mixer
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
Mixer runs but blades slip when you add the food
Hi Victoria. There is internal damage in your mixer's transmission. The unit needs to be serviced, and repaired.
Here is something you can try on your own. Unplug the mixer, remove the single screw that holds the silver band. There are now 4 screws that hold the top cover, remove them, and then the cover.
At the top-front of the mixer you'll find the transmission housing. If this housing is made of plastic, check it carefully for cracks in the housing or near its screw holes. If you find any cracks in this housing, you have found the source of all trouble.
Although Kitchenaid advertises "All metal transmission", the truth is that they use a cheap plastic part to support two of the most important shafts in your mixer. This cheap plastic part will fail at some time when it's mixing cookie or bread dough. When it fails the gears and shafts jump out of position and major damage occurs. This is why it was listed on Craigslist. The previous owner wanted to get rid of it.
Kitchenaid's replacement housing is made of metal. Kinda makes you wonder...
Unless you're mechanically adept, you either need to fix it, or get rid of it. If you're not up to the task of repairing it yourself, then take it to a small appliance repair place for an estimate.
If you're looking for a new mixer, go to consumersaffairs.com and search for a make and model of the mixer you're considering and read the actual customer reviews.
Kitchenaid is not what it once was. Steer clear.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
K5A refurb/repair
First thing check the carbon brushes, when they wear out they arc at the armature. Two black screw covers one either side of the top motor housing. The brushes are keyed to only go back in one way so make a note of which corner of the brush has been shaved off. If you look in the hole with a torch you can see the little blocker in one corner deep down. As a rule it's back top corner on one side and back bottom corner on the other side.
Oct 21, 2017 | KitchenAid K5SS Heavy Duty Commercial...
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
