Hi! I have a whirl pool thin twin washer/dryer combo model # ltg6234aw1. The washer will stop before it rinses. Ive tried stoping it and starting it again and nothing. Ive tried putting knob all the way to the beginning and it will fill with water but then stop again. It will not go full cycle. THEN the dryer stopped working. It wont work on any of the different heats. Please Help!!! We dont have the money to get a new one or pay someone to come here and fix it.
Your water filter outlet is blocked up
or the pump has something inside it stopping it rotating
so you have a blockage
inside the wirlpool on top of the dryer unit youll see two disks
bolted on that have 4 wires
you need first too check all screens and clean any lint from the whole heater assembly
anywhay at the center of the two disks {over heat sensors} is two small red plastic cyclinders
just press both back in and then the heating is reset
some machines will need these replaced instead
anyway you need to also check the motor brushes and
replace them if needed and clean the motor with a dry brush to remove any carbon dust
now once your sure the drain and heater paths are aok and free from any blockages
your good to go
you can reset the machines controller by turning on the mains at the plug / socket while you hold in the start stop {or sometimes power } look up this detail in google
hope this helps
Posted on Dec 02, 2014
5 Suggested Answers
  • 1314 Answers
SOURCE: Washing machine wont stop filling up
see if the water coming in is hot or cold by turning the water faucets off and on to see if one fills and the other dont and replace the valve
Posted on Feb 16, 2008
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: whirlpool lte5243dzo washer combo thin-twin
Try this:
http://en.allexperts.com/q/Major-Appliances-3603/Whirlpool-ThinTwin-Stackable-Washer.htm
Posted on Nov 30, 2008
megarza
  • 88 Answers
SOURCE: older maytag wahser water level and agitate cycle
you need to replace the water level switch
Posted on Sep 23, 2009
Overflowing Washing Machine, water does not stop filling, overflows to floor. This is a Whirlpool Thin Twin Stackable
sounds like you have a bad water level pressure switch part 3362987
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-dryer-combo-Parts/Model-LTE5243DQ6/1198/0152000/W0604125/00001?blt=06&prst=&shdMod=
go her part number 10 in diagram or there could be something in the hose,the hose could have fallen off or could have a hole in it,i can't find a video with a stack machine but this explains your problem
http://www.youtube.com/watch?v=jzKBUI5D0Vs
Mar 30, 2013 | Whirlpool LTE5243DQ Combination...
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Whirlpool Thin Twin WET3300SQ (water stops coming in)
  • We are sorry to hear of the problem with your Whirlpool washer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Wash cycle does not start!
if only rinse cycle work. it mean the cycle timer in no good. you need to replace it. i will tell you the cost of it later.
Feb 05, 2008 | Whirlpool LTE5243D Top Load Stacked...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
