Question about Whirlpool Refrigerators
How do I change the Pur water filter on a Whirlpool Frenh door refrigerator
    Sergeant:
  • 304 Answers
Pull down the lid using the tab and twist it to the left . Turn the new one to the right then filter on 10-12 glasses of water
Posted on Dec 02, 2014
watugot
  • 290 Answers
SOURCE: whirlpool profile refrigerator
Unplug it and see if noise stops. Leave it unplugged for at least 10 min. This will tell you if it is the fridge. Be sure and check your batteries in smoke alarms if you have any. I have made several calls for noisy appliances that ended up being smoke alarm battery warnings.
Posted on Oct 06, 2007
SOURCE: Water filter light on refrigerator
Found this site and the fix worked for mine. You need to press a combination of buttons and this tells you which ones
http://www.partselect.com/water-filter+reset-change-filter-light+repair.htm
Posted on Aug 08, 2008
  • 78 Answers
SOURCE: Plastic Taste in Refrigerator Water
Hi there, I noticed the same condition when I left the filter in ours a little too long. The optimal performance from the filter is achieved (I have found) when you change it after 3 months. This is about the same amount of time it takes for the light to change from green to red on the filter light.
Hope this helps. ~Steve
Posted on Feb 25, 2009
  • 26 Answers
SOURCE: How to replace pur water filter on a kenmore refrigerator
On my Kenmore, you have to press the light switch 5 times in order to reset the timer on the filter.
Posted on Jul 05, 2009
SOURCE: HOW TO TURN OFF THE "CHANGE WATER FILTER LIGHT"
Press light and lock and hold until light blinks release and the light will go out
Posted on Aug 27, 2009
I changed my filter, PUR 4396841 and now it is vibrating when I stop dispensing water. Any suggestions? Do I have it installed correctly?
The vibration is a tiny bit of "water hammer." Previous to your filter change, the water flow was restricted, and therefore incapable of causing water hammer. Now that you've changed the filter, the flow is large enough to cause a little water hammer when you shut off the flow.
How to fix: shut off the flow SLOWLY. Water hammer is caused when the flow of water is shut down quickly. This is just as true with large flows (as in fire engine pump panels), as it is in itsy bitsy
filtered water lines & filter housings.
May 13, 2011 | Whirlpool 4396841 Whirlpool Refrigerator...
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
I have a Whrilpool refrigerator, model #
the drain hose to the base is plugged that sends water to the lower area by the floor to evaporate
Aug 01, 2010 | Whirlpool Refrigerators
Replaced a waterfilter in my ref with wrong filter model
The new filter you used will not damage anything in the refrigerator, the only difference will be in the fill rate, it may fill slower than you like.
Apr 18, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cant get the cap off to change the water filter? Can you help
Filter on the bottom? Turn it CCW a quarter turn and pull it out. The cap slides off and attaches to the new filter.
Eric
Nov 23, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Ice maker
filter its on the kick plate @ the bottom of the freezer door,push the side button and the filter unlocks
Jun 17, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Problems after replacinf waer inlet valve...
yea that is common just switch the wires and then try to get water out the door.. no biggie you wont hurt nothing... the water just wont come out the same place...
Apr 30, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Refrigerators Logo
57 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
