Question about House Brand Ice Xtreme Radiator for Water-cooling System Black
House radiator nut is stuck
Need to know how to remove stubben nut
  • 31 Answers
Try and use some wd 40. You can also use a pair of pliers our vice grips and get a good grip and turn. The WD 40 method should allow to sit for at least 8 hours.
Posted on Dec 01, 2014
Waterpump 2002 ford turaus 3.0 durtec
3.0L Engine
VIN S Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Drain the cooling system.
  3. Remove or disconnect the following:
  • Splash shield
  • Lower heater hose
  • Radiator lower tube bolt
  • Radiator upper front tube bolt
  • Air cleaner assembly
  • Battery and tray
  • Water pump belt
  • Upper radiator hose
  • Engine vent hose
  • Transaxle 10 pin connector
  • Radiator bypass hose assembly
  • Thermostat housing
  • A/C compressor brace, if equipped
  • Water pump mounting nuts
  • Connector hose
  • Water pump
To install:
  1. Install or connect the following:
  • Water pump
  • Connector hose
  • Water pump mounting nuts and tighten them to 15-22 ft. lbs. (20-30 Nm)
  • A/C compressor brace, if equipped, and tighten the nuts to 15-22 ft. lbs. (20-30 Nm)
  • Engine vent hose
  • Water pump belt
  • Battery and tray
  • Lower heater hose
  • Splash shield
2. Fill the cooling system.
3. Start the engine and check for leaks.
Dec 06, 2015 | 2002 Ford Taurus
Tip
Water pump
To remove water pump loosen serpentine belt with a 3/8 breaker bar and set out of the way remove the 4 nuts on the pump housing and the 3 bracket bolts along with the upper and lower radiator hoses the small heater hose. The lower nuts can be reached thru the wheel well. Remove the allen bolts that hold the pump in the housing clean gasket area and replace. You may need to double nut a couple of the housing studs and remove for room on the housing
on Jan 16, 2015 | 1998 Ford Taurus
Need to know how to change the water outlet housing.
Remove the water hose, take off the two bolts holding the housing, bang off sideways if stuck and remove the housing, replace gasket after carefully scraping off all residue of last one and reinstall housing and hose. And properly refill the radiator with coolant.
Remove radiator cap and run engine till thermostat opens - then add water till it overflows and then put on cap and tighten. U done!
Sep 01, 2015 | 2001 Oldsmobile Alero
Replacing Thermostat Where is it ?
It's under the housing shown below on the back side of the engine. Instructions taken from autozone.com. I recommend you also read my post at http://www.fixya.com/cars/r5929960-s_thermostat and let me know if you have any questions.
3.1L Engine
  1. Disconnect the negative battery cable.
  2. Drain the cooling system, into a suitable container, to a level below the thermostat housing.
  3. Remove the air cleaner assembly.
  4. Remove thermostat housing-to-intake manifold attaching bolt and nut, then remove the housing.
Fig. Remove the two housing-to-intake manifold bolts and remove the housing
  1. Remove the thermostat.
To install:
  1. Clean all gasket surfaces completely.
  2. Insert the thermostat in the intake manifold.
  3. Attach the thermostat housing to the intake manifold.
  4. Install the mounting bolt and nut. Tighten to 18 ft. lbs. (25 Nm)
  5. Install the air cleaner assembly.
  6. Connect the surge tank line to thermostat housing.
  7. Refill the cooling system.
  8. Connect the negative battery cable, remove the radiator cap, then start the engine. Allow the engine to run with radiator cap removed, until the upper radiator hose becomes hot (thermostat open). With the engine idling, add coolant to the radiator until the level is up to the bottom of the filler neck.
  9. Install the radiator cap, making sure the arrows line up with the overflow tube.
Dec 08, 2010 | 2000 Chevrolet Malibu
How do you replace the thermostat
Partially drain coolant level to below thermostat level if nessasary. Follow top radiator hose over to engine. Where the top radiator hose stops at engine is where the thermostat is. Hose is connected to a pipe ( called a thermostat housing) that bolts to the engine. Remove components if they are in the way of accessing the two bolts or nuts that hold down the thermostat housing. Remove thermostat housing. Thermostat is under the housing. Replace thermostat and paper gasket or rubber o-ring. Be sure to clean surfaces of area where the gasket is mounted. Reinstall thermostat housing but do not over tighten the housing bolts or nuts. Reinstrall components removed and refill coolant to proper level. Do not forget to close radiator drain. Do not put radiator cap on at this time. Start engine and let run for a few minutes to get air out of system. Stop engine and refill coolant if needed. Install radiator cap and check coolant resevoir and fill to proper level if needed. Hope this helps.
Nov 26, 2010 | 2005 Pontiac Grand Prix
Where is the thermostat ?
Please see my tip at http://www.fixya.com/cars/r5929960-s_thermostat . These are generic instructions. Specific instructions are provided below. If you get stuck, please get back to me.
  1. Disconnect the negative battery cable. Drain the radiator to below the level of the thermostat.
  2. If necessary, remove the air cleaner assembly.
  3. If necessary, disconnect the coolant temperature switch at the thermostat housing.
  1. Remove the upper radiator hose.
  2. Remove the mounting nuts, thermostat housing, thermostat and gasket.
Do not pry the housing off.
To install:
  1. Clean the thermostat housing and the cylinder head mating surfaces.
  2. Insert the thermostat into the rear cylinder head housing with the jiggle pin at the top. The spring side of the thermostat should face the housing.
  3. Position a new gasket onto the studs with the seal print side facing the rear cylinder housing.
  4. Install the thermostat housing and 2 nuts. Tighten the nuts to 14-22 ft. lbs. (19-5 Nm).
  5. Install the upper radiator hose.
  6. If detached, connect the coolant temperature switch.
  7. If removed, install the air cleaner housing.
  8. Fill the cooling system. Connect the negative battery cable, start the engine and check for leaks. Check the coolant level and add coolant, as necessary.
Nov 19, 2010 | 1994 Mazda MX-3
Replacement of thermostat
This is for 3.1L....if this is not what you have, please let me know the size of the motor!
3.1L Engines
To install:
Nov 19, 2009 | 2000 Chevrolet Impala
How do you replace a thermostat on a 2002 toyota celica
Toyota Celica, Corolla, ECHO & MR2 1999-05Toyota Celica, Corolla, ECHO & MR2 1999-05
2002 Toyota Celica 1.8L MFI DOHC 4cyl
The thermostat is located in the water inlet housing that is connected to the lower radiator hose.
The thermostat is equipped with a by-pass valve. If the engine tends to overheat, removal of the thermostat would cause a decrease in cooling system efficiency.
CAUTION NEVER drain coolant directly onto the ground! NEVER open, service or drain the radiator or cooling system when hot; serious burns can occur from the steam and hot coolant. Also, when draining engine coolant, keep in mind that cats and dogs are attracted to ethylene glycol antifreeze and could drink any that is left in an uncovered container or in puddles on the ground. This will prove fatal in sufficient quantities. Always drain coolant into a sealable container. Coolant should be reused unless it is contaminated or is several years old.
Fig. The oil filter must be removed to access the thermostat on the 5S-FE engine
  1. Position a suitable drain pan under the radiator drain **** and drain the cooling system.
  2. On the 7A-FE engine disconnect the engine coolant temperature switch harness from the water inlet housing.
Fig. Disconnect the engine coolant temperature switch wiring located on the side of the thermostat housing
  1. Remove the oil filter on 5S-FE engines.
  2. Loosen the hose clamp and disconnect the lower radiator hose from the water inlet housing.
Fig. Loosen the radiator hose clamp ...
Fig. ... then slide the hose off the thermostat housing
  1. Remove the two nuts from the water inlet housing and remove the housing from the water pump studs.
Fig. Only two nuts hold the housing to the cylinder head
Fig. Pull the housing straight out to remove
  1. Remove the thermostat and rubber O-ring gasket from the water inlet housing.
Fig. Then pull the thermostat and gasket out
Fig. Sometimes the gasket is stuck and has to be pried out of the head
To install:
  1. Make sure all the gasket surfaces are clean. Clean the inside of the inlet housing and the radiator hose connection with a rag.
  2. Install the new rubber O-ring gasket onto the thermostat. On 5S-FE engines, align the jiggle valve with the upper side of the stud bolt. Insert the thermostat into the housing.
Fig. Only use the correct temperature range thermostat when for replacement
Fig. Align the jiggle valve within a 10°gap of the stud bolt-7A-FE engine
Fig. Align the jiggle valve within a 5°gap of the stud bolt-5S-FE engine
  1. Position the water inlet housing with the thermostat over the studs on the water pump and install the two nuts. Tighten the two nuts to 78-82 inch lbs. (9-10 Nm).
Don't forget to install a new O-ring onto the water inlet pipe. Apply soapy water to the O-ring prior to installation.
  1. Connect the lower radiator hose to the inlet housing and install the hose clamp.
  2. Attach the water temperature switch connector.
  3. Install the oil filter and check the oil level if removed.
  4. Fill the cooling system with a good brand of ethylene glycol based coolant.
  5. Start the engine and inspect for leaks.
  1. Remove the right hand cover under the engine.
  2. Drain the engine coolant.
  3. Remove the fan and generator V belt.
  4. Remove the generator assembly
  5. Remove the water inlet via the two nuts.
  6. Remove the thermostat.
To install:
  1. Install a new gasket onto the thermostat.
  2. Install the thermostat with the jiggle valve upward. It can be set within 10 degrees on either side of the prescribed position.
  3. Install the water inlet via the two nuts. Torque to 8 ft. lbs. (11 Nm).
  4. Install the generator assembly.
  5. Add engine coolant.
  6. Inspect for leaks.
  7. Replace the cover under the engine.
I hope help you with this (remember rated this help) Good luck.
Sep 29, 2009 | Toyota Celica Cars & Trucks
Replacin the thermostat
Follow the lower radiator hose from the radiator to the engine. It connects to the engine at the thermostat housing. Remove the hose and the nuts holding the housing on. The thermostat in in there.
May 16, 2009 | 2006 Toyota Corolla
I need to know where the location of the thermostat is on a 1999 chrysler 300m so i can replace
The 2.7L engine lower radiator hose, connects to the thermostat housing.
To Remove:
1.Disconnect the Negative battery cable.
(Engine COLD!)
  1. Drain cooling system.
  2. Remove radiator lower hose from thermostat housing.
  3. Remove nuts from heater tube flange studs.
  4. Loosen starter bolt at heater tube bracket.
  5. Pull heater tube out of thermostat housing and position out of the way.
  6. Remove bolt and two studs.
  7. Remove thermostat housing, O-ring and thermostat.
  8. Remove thermostat housing bolts.
To install:
A.Clean gasket sealing surfaces.
B.Install thermostat with the bleed valve located at the 12 o'clock position, between tabs on seal.
  1. Install thermostat and seal into thermostat housing .
  2. If removed, install two studs.
  3. Install thermostat, thermostat housing and O-ring and bolt. Tighten attaching bolts to 105 inch lbs.(12 Nm).
  4. Lubricate new heater return tube O-ring with coolant.
  5. Position heater return tube flange over two studs. Install nuts.
  6. Tighten retaining nuts to 53 inch lbs.(6 Nm).
  7. Tighten starter bolt to 40 ft. lbs. (54.3 Nm).
  8. Connect the lower radiator hose to the thermostat housing. Install hose clamps.
  9. Refill cooling system.
  10. Inspect for leaks.
  11. Connect negative cable.
3.2 and 3.5L engines:
Disconnect the battery cable. (Again engine COLD)
  2. Raise vehicle on hoist.
  3. Disconnect electrical connectors from engine oil and power steering pressure switches.
  4. Disconnect radiator and heater hoses from thermostat housing.
  5. Remove thermostat housing bolts.
  6. Remove housing, thermostat, and gasket.
The OEM thermostat is staked in place at the factory. To ensure proper seating of replacement thermostat, carefully remove the bulged metal from the thermostat housing, using a suitable hand held grinder. It is not necessary to restake the replacement thermostat, into the thermostat housing.
To Install:
  1. Position gasket on thermostat and housing.
  2. Install thermostat housing, gasket and mounting bolts onto block. Tighten attaching bolts to 105 inch lbs. (12 Nm).
  3. Install radiator hose.
  4. Install bypass hose.
  5. Connect electrical connectors from engine oil and power steering pressure switches.
  6. Connect negative cable.
  7. Fill cooling system.
  8. Inspect for leaks.
  9. Lower vehicle on hoist.
From AutoZone Repair Guides
I feel this way, I can give you an accurate description, and have taken into account your safety.
May 12, 2009 | 1999 Chrysler 300M
House Brand Ice Xtreme Radiator for Water-cooling System Black Logo
57 people viewed this question
Top House Brand Computers & Internet Experts
David Payne
David Payne
Are you a House Brand Computer and Internet Expert? Answer questions, earn points and help others
