Question about Cameras
I do not know which details you need from me. Helen Orr This is re: changing IM expressions image, it is blocked.
Tried to change the image from fall to winter and it is blocked.
  • Colleen Parrish
    Colleen Parrish Dec 01, 2014
    Hi Helen Orr, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What operating system and browser are you using? Have you tried clearing the cache or rebooting your system?
I accidently reported the wrong information on my mobile phone centrelink app. Helen
You are on the wrong website for this type of inquiry. This is a self help website for the repair and use of consumer manufactured products
Jun 20, 2017 | The Computers & Internet
Does any know how to take the whole under the hood fuse block off of a 2000 chevy blazer..because im having problems with my fuel relay failing. So im assuming there is a short somewhere in the block.or...
the bolt heads are under the front wheel innner fender plastic cover now be aware this is a common problem for the gm fuel pump and it usually falls to a wire harness fault around the gas tank
May 15, 2014 | Cars & Trucks
Hellow im helen my scanner canonsacan 25ihave nocd and i need to scan some f ile please mail me at helen.ketheren@gmail.com
Click here Click on above link select os and download driver then install. Let me know if you need further assistance. Thanks for using FixYa.
Feb 28, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
I really don't have a problem, I would like to know how to scan photos into my computer and them send them in an email. Could you explain it to me so I can understand it. As you can guess, I'm a...
Hey Helen,
This can be hard or easy depending on which softwre your printer/scanner has loaded.
Firstly, install the software that came with your printer scanner.
Once thats done, you should be able to access the scanners functions either through an icon in the taskbar (bottom right corner of your screen) or by pressing the scan button on the printer.
Once the scanner starts up, it should ask if you want to save the scanned image to your PC or, in some cases, email the image.
Save the image into your "my documents" folder so you can find them later and give the file a name that you can easily associate with the image (like my daughter etc)..
Scanning to email will usually start up outlook or outlook express which is no good if you do not use outlook and use a third party email system like hotmail etc.
So, shut down outlook in this case. otherwise, setup your email as you normally would (receivers email address, subject etc)..
If you use hotmail etc, the procedure is about the same..
Once you are ready to attach the image from your scanner, click on "attach" and select file.
In the dialog box that opens, select browse and navigate to your "my documents " folder if it is not already in that folder. Select the file you scanned and named earlier and click on open or attach.
The file will then upload and appear in the list of attachments once uploading is complete.
Click on send and off it goes..
Jan 24, 2011 | HP Office Equipment & Supplies
Attachments in outlook express
You should change the settings of your browser and the outlook
Jun 12, 2009 | AMD Athlon 64 X2 4600+, 2.4 GHz...
2002 chevy express fuel pump/crank sensor?? how to change
THE CRANK SENSOR IS LOCATED RT UNDER THE CRANK PULLEY. IT IS USUALLYEASIEST WITH AN EMPTY TANK TO REPLACE IT.
Dec 05, 2008 | 2002 Chevrolet Express
Yahoo 9 wont let me display a picture or change nickname
Go to folder
C:\Program Files\Yahoo!\Messenger\Profiles\[your Yahoo ID]\My Icons
It's a list of display images saved by YM. Remember the filename of your desired image.
Open your registry (click Start, Run.., type REGEDIT).
Trace the path
HKEY/CURRENT_USER/Software/Yahoo/pager/profiles/[your Yahoo ID]/FriendIcons
The value of Path should reflect the filename of the current display image in your YM. Change it to reflect the filename of your desired image.
Close the registry.
Restart YM.
Oct 08, 2008 | Yahoo Messenger
Email on outlook express
Hello stayed
Are you attempting to view an email "attachment" or a "hyperlink" in an email?
I believe the problem you're experiencing may be caused by one of two settings (or both).
(01) The option to block images being set in Outlook Express. (This option is a security feature.) If that's the case, the instructions HERE should help to resolve your problem.
-AND/OR-
(02) Unsafe attachments are blocked. If that's the case, you can find instructions HERE for changing this setting.
Let us know if one or both of these options does the trick.
BJ
Apr 03, 2008 | Computers & Internet
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
