Question about Samsung TV Remote Control
Samsung LN46B530P7f. Tv not respond to remote or channel volume buttons tv changing channels and volume on its own
Removed back look for burns or damage
    Top Expert:
  • Samsung Master
  • 75,581 Answers
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Dec 02, 2014
SOURCE: samsung remotes
is there a text center
Posted on Aug 24, 2008
SOURCE: remote won't work
Hi I had the same problem last night, so I took the batterys out  and left it for a Day, have just put them back and its working for the moment, hope that it keeps on working !!! good luck with yours.
Posted on Feb 20, 2009
bernardlunda
  • 318 Answers
SOURCE: My samsung tv is not responding to my remote control
your turning section is not responding to any input, hence needs to be checked by a technician. every thing you have mentioned are controlled by one ic, with its respective voltages.
Posted on Mar 27, 2009
andy4254
  • 226 Answers
SOURCE: Remote control has stopped working.
your remote needs to be put back in TV mode. press the tv button or slide the switch to tv
Posted on Apr 28, 2009
  • 5 Answers
SOURCE: remote will not turn tv on and off
this is not the original remote for this product it is a cheaper version
Posted on Jun 22, 2009
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
My samsung le32r74bdx remote control wont change channels and cant turn volume on tv up or down
You can verify that the remote is working. Get a digital camera with a LCD display.
Aim the remote at the camera lens and press the volume and channel buttons. If you do not see
a flash through the camera the remote is bad or the batteries are dead.
If you know someone with any samsung hdtv remote, you can borrow it and try the volume/channel
to see if the tv remote receiver is good.
Feb 08, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
My samsung tv is not responding to my remote control, actually even when I go and attempt to change the channel from pressing the up/down buttons on the tv it won't respons, some menu screen would come on...
Mar 21, 2009 | Samsung Remote Control
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
Changing channels by itself
bought beko 32 wlu520hd when i change channel or volume the white indicator light on the tv flashes and starts going through all channels or volume just keeps going up .as if im holding down the buttons when im not , buttons on tv and remote do not respond. until i rub my finger over the senser on the tv, it stops but as soon as i press any button on the tv or remote it starts all over again .is this a fault in tv or is it static build up, does any one have the same problem , ive been on the beko web sight and cant find anything about this
Oct 05, 2008 | Beko 324250WN 28" TV
No volume
Normally when you have only one channel with audio the cause is usually SAP is turned on, either on the television or the cable or Sat elite box.
If you were pushing buttons on the remote, I would suggest that the SAP button is on the remote.
On a Samsung remote, the MTS button identifies this function. It may be labeled stereo.
Make sure the remote is in the TV mode to change or check on the TV.
It may also be a button on the remote for the Cable or Sat elite box. If not then you may have to search in the menu's of the Television or the boxes.
If the set is only two weeks old (the actual set, not how long you have owned it) then it probably has an ATSC turner labeled Air that will receive local HD by using rabbit ears. If the set is over 3 years old, it will not have this feature.
It's difficult to give a full de script explanation of a solution without knowing the model or configuration of the input signal.
If this does not help, respond to this post and I will reply.
Nov 18, 2007 | Televison & Video
Samsung TV Remote Control Logo
137 people viewed this question
Jerry Greenberg
Jerry Greenberg
