Question about Sunbeam Bedding, Rest and Relieve Therapeutic Twin Heated Mattress Pad
Just bought one what is the problem with putting a foam pad on mattress under the Sunbeam heated bedding???
My question is there a problem with putting a foam mattess pad over the mattress before installing the heated Sunbeam bedding?
SOURCE: the controller on my heated mattress pad blinks
I had same problem. Make sure plug is all the way in and locked.
Posted on Nov 25, 2008
SOURCE: new heating pad not working
have same problem with heating pad . reset control by unplugging unit for 1 minute , while holding down power button plugged unit back in . sometimes this takes 3 or 4 tries.
Posted on Jan 10, 2009
  • 53 Answers
SOURCE: only 1 side of my sunbeam H85KQ mattress pad will
If your model has two heat control thermostats, its possible that there is a fault with one of the thermostats.
Worse would be that the electric cable that runs thru the blanket is broken.
You would need specialised test equipment to find where the break is, unless you can actually feel the cable is split when you run it through your fingers.
Normally, if the electric cable is broken, the blanket is not servicable, because you would have to cut into the cover material to try find the break and replacing the cable is impossible outside of the factory.
Posted on Nov 18, 2009
SOURCE: F2 Fault Code On Heating Pad
I am trying something now as I was told F2 requires you to check the blanket for wear and tear and plug it back in. 3 times doing this should be sufficient. If it still reads F2 it's "gone" Ours is new so it shouldn't be "gone" but here's what I found...Where the plug goes into the blanket there are 4 holes for 4 silver pins. I noticed the 3rd pin was a bit lower than the other 3. It will not move up with pliers so don't force it just return it. check there
Posted on Feb 02, 2010
  • 7 Answers
SOURCE: I have a king sized Sunbeam mattress pad and this
Maybe the machine of yours is broken sir and you need to bring it to a technician before it's too late.
tou can check this url to find any kind of mattress:
http://www.bestmattressreviews.com/
I am looking for a replacement for 1 of the controls for my heated mattress pad. Where can I find 1?
www.sunbeam.com/.../bedding/controls/bedding-contr...
Sunbeam ProductsHow do dual controls work? The dual ... What if my control does not regulate my side of the warming product? ... Where can I purchase replacement controls?
Finding Replacement Cords and Controls for an Electric ...
www.thriftyfun.com/Finding-Replacement-Cords-and-Controls-for-an-El...
... blanket. Finding a replacement cord or a control for an electric blanket can be difficult. ... My blanket was under warranty and I got one for free. If yours is out of ...
Finding Replacement Controls for a Heated Mattress Pad ...
www.thriftyfun.com/Finding-Replacement-Controls-for-a-Heated-Mattre...
This is a guide about finding replacement controls for a heated mattress pad. It can be very frustrating to find replacement ... Read all 1 Answer ... Where can I findreplacement controllers for my Living Quarters heated mattress pad? By Steve.
Replacement Controls for a Sealy Electric Blanket ' ThriftyFun
Dec 07, 2015 | Sealy Heated Queen Size Mattress Pad - -
My legs are tingling /tired when I lie down at night. upon getting out of the bed and walking about 15 steps the tingling starts to go away. could my 1-2 inch thick mattress pad be a problem like smel
Tingling in limbs is usually due to poor circulation. If the pad is pressing on the leg blood vessels then that effects circulation. Try to sleep a few days with a pillow under your legs so that feet are slightly elevated. Consult your medical practitioner to confirm no physiological issues.
Sep 24, 2014 | Furniture
What is the best "value" mattress
The best value mattress is that which would provide you a comfort and high-quality sleep without causing any disorders like body and muscles pain.
I would like to suggest you some most used high-quality mattress:
a. Needle and Tuft Mattress
b. Zinus Green Tea Mattress Memory Foam 12 Inch
c. Independently-Encased Coil Mattress Signature Sleep Contour Inch 10
d. Signature Sleep Memory Foam Mattress 12 Inch
e. Mattress 10-Inch Memory Foam Mattress, etc.
If you also want to get these high-quality mattresses, you can buy them directly from Best Rated Mattresses at best deals..
Apr 03, 2013 | Furniture
I have a Rest and Relieve Therapeutic King Heated Mattress Pad that I have lost the remote control for. where can I purchase a replacement remote?
You should try to contact the supplier of your mattress cover. If they have a website, you can check their website to check if they provide the separate remote for that particular mattress. Even if they don\'t, you can contact them asking the solution.
Jack
Jan 21, 2013 | Sunbeam Bedding, Rest and Relieve...
What type of mattress is best to buy for a sofa-bed?
The best type of sofa bed mattress are:
1. Latex Mattress
2. Spring Mattress
3. Foam Mattress
4. Pillow Top Mattress, etc.
It is really a tough task to choose a mattress for a sofa bed. You can consider color combination and several factors of the mattress to buy the best one for you and your house.
Aug 16, 2012 | Furniture
What is the difference between an air mattress and a sleeping pad?
Sleeping pads are commonly smaller than air mattresses and come in both inflatable and foam models. Most sleeping pads are made for one person, while air mattresses are constructed to mimic traditional beds.
Jul 31, 2012 | Camping, Backpacking & Hiking
What is a mattress pad?
A mattress pad is essentially a very thick sheet, or thin mattress, that is used as extra support to an existing mattress. It is a great shield between the mattress and your bed sheets, helping to minimize wear and tear to the mattress.
Jul 25, 2012 | Furniture
I need instructions on operating a remote to Sunbeam,Cal-King, electric mattress pad.
Which model Sunbeam mattress pad do you have? Sunbeam has some of their manuals here: http://www.sunbeam.com/manuals.aspx . The electric bedding share a manual. The direct link is http://www.sunbeam.com/BeddingManuals/SunbeamBedding/Universal.pdf .Make sure that you are using the master control for your side of the bed (that's the one closest to the plug for the wall outlet).
You may need to turn on the second control and set it to 0 at night. If you still are having a problem with the heat being uneven, you might need a replacement mattress pad. I know we've replaced several electric blankets or mattress pads due to problems with the control/uneven heat.
I hope this helps.
Jan 25, 2012 | Heating & Cooling
Sunbeam Bedding, Rest and Relieve Therapeutic Twin Heated Mattress Pad Logo
99 people viewed this question
Top Sunbeam Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Sunbeam Furniture Expert? Answer questions, earn points and help others
