Question about Yamaha Music
I am trying to get my USB device to play profesional midi-files on my Yamaha PSR3000 keyboard,it keeps refusing saying(Protected File,though I have used them before on a previous PSR 300?
Plugged in device ,(with midi-file) selected Funtion-Pressed Utility,What next?
    Problem Solver:
  • 62 Answers
Scan your files , check file format too.
Posted on Feb 03, 2017
  • 10 Answers
SOURCE: Electronic drum kit, with USB out, problem
Sounds to me like you have the midi tracks outputting to the microsoft midi mapper or wavetable synth, which is built into the sound chip in your pc, and that this is conflicting with the mobilepre sound card - midi is just data, no audio, needs to drive some kind of synth. what you want to do is disable your internal sound card thru device manager, then just use the m-audio mobile pre as the input/output sound card in ASIO mode - you'll need to monitor via the headphone jack on the mobile pre or plug speakers into the line outs on the interface.
Then do tutorial 8 (in help files) on using soft synths - INSERT>SOFTSYNTHs creates a midi track and an audio track in a track folder.
Good luck.
The dude.
Posted on Aug 07, 2008
  • 5603 Answers
SOURCE: I have PSR-i425 Keyboard from Yamaha. I stored the
The BUP is an archiving format proprietary to the Yamaha apparently containg styles as well as note data and conversion is really not easy.
If you can get the instrument itself to spill out MIDI and use a MIDI interface and software to capture it on the PC is the best plan.
Once it is in SMF format you can play it on the PC.
Posted on Jun 25, 2010
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
SOURCE: how can i play BUP 06PK61 frm yamaha I425 on PC
how can i play .bup file in computer?
ok here is the solution!!!!!!!!
    • we should have a mic pin and audio cable as shown in this pic
    connect these cables,and connect big pin to the piano and small pin to the computer (mic or input jack)
    now take windows movie maker (start-all programs-windows movie maker). click on narrate timeline (as a mic icon below windows movie maker).
    now click start narration on the pc and play your song on the piano. you can see input level highlights. now your song is recording. when your song completes click stop narration and save to the pc. walah if you can't understand this say to me. i can add video. sry for my worst english
Posted on May 02, 2011
jiantonyjose
SOURCE: I want Yamaha Keyboard PSR-2100 USB MIDI DRIVER
how to play with thumb
Posted on Oct 22, 2012
Ctk 810in not able to read or play midi files
If you connect to PC using USB interface, then use a commercial midi player - e.g Melody Assistant or Harmony assistant to play MIDI files to it.
Or else download "SMF convertor" to convert midi files and download compatible file to keyboard.
Aug 10, 2013 | Casio CTK810 61 Key Keyboard
HOW CAN I PLAY BUP FILE IN MY COMPUTER WHICH I TOOK FROM MY YAMAHA I425
The BUP file is proprietary format for each model Yamaha keyboard. Your best solution is to export via MIDI interface and use that format.
Jul 30, 2011 | Yamaha YPT400 61 Key Portable Keyboard...
How can I send recordings to my laptop? I have a usb connector and i want to connect my portable grand to my laptop but the laptop does not detect the piano and i don't know what to press on the piano...
Hi mjaynneb,
I could be wrong here but I have a number of keyboards and the USB connection is usually for Midi control from software like Cubase and the like. If by recording you mean recording Audio then I think you'll find that it won't be possible using the USB port.
Midi is great and I use it a lot. It enables you to arrange music using your computer. Also you can record the music you play on the Keyboard on the computer as Midi. This means that the computer can play back through your arranger what you just played. Bear in mind though that Midi is purely numbers that represent notes, velocities and note duration so is not actually audio.
My keyboards have the ability to record to SD card or a Hard Drive, however if this is not a feature of your arranger then probably your best bet for recording audio from it is by using the Audio out ports of your arranger and using a connecting lead to a good low noise sound card on your computer. As you are using a laptop you can find external usb sound cards/interfaces so that should do fine. Then you could probably use something like Audacity which is free software, to record to a wav file.
I hope this helped.
Kind Regards
mparkyn
Jul 27, 2011 | Yamaha DGX 640 Keyboard Arranger
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
I have same problem. I have recorded my performance on keyboard (PSR I425) when i transfered it to PC it's in .bup format. and the file is not getting played on PC. how should i solve it?
Transfer the data in MIDI format. The BUP format is a proprietary format to the keyboard and can ONLY be played by the keyboard. Either dump the data as MIDI format or using a MIDI interface send it to the PC or lastly, capture the audio using an audio interface on the PC.
Nov 26, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
I want to use my sd card to put my own songs and when i change the song from an MP3 to MIDI file using the program WIDI 3.3 Pro. When i put the MIDI file which is the song, into the Sd card and then into...
You need to understand what the program is doing.
An MP3 file is a recorded music performance like a phonograph record. A MIDI file is a set of instructions for performing music, like sheet music. The converter program is an attempt to turn the record into sheet music. There is no perfect way to do that. You should have gotten something out of the program, though. It sounds more like a computer problem. Try a very simple sound file, convert it to MIDI, and see if you can get something out. If your keyboard can't read it, try putting any known good MIDI file on the card and read that. Possibly your keyboard will only read certain formats or sizes or speeds of cards. See if the manual tells you anything. It might read FAT16 regular speed cards under 1 GB, for instance, and balk at a SDHC 16 GB NTFS formatted card. So, do some detective work.
Apr 05, 2017 | Casio Lighted Keyboard LK90STADMC
I have PSR-i425 Keyboard from Yamaha. I stored the music piece played by my in the keyboard memory. After that I downloaded the stored file to my PC The file is in this format: 06PK61.BUP. Kindly tell me...
Jun 25, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
How can i play BUP 06PK61 frm yamaha I425 on PC
Jan 13, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
How do i edit and store midi files on my tyros keyboard.
Storing is easy... editing is NOT so easy and is better done using a PC with an editing program.
Not knowing which model Tyros you have, either bring the MIDI files on floppy disk or USB stick.
Select the floppy or the USB source on the Tyros while in the song mode. Find and COPY a file or files, then move back to the place you want to store them like hardrive or user space and PASTE. You can create folders before each to keep the things seperate.
Oct 28, 2009 | Yamaha Full-Size Keyboard
Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Music Logo
21 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
