Question about Janome Janoe Deco Coputer 2011 DC2011
Using metallic thread, metallic needle. Bobbin case will not engage bobbin to bring up thread to needle. Bobbin is in correctly.
EVERYTHING! I have a special bobbin case that decreases the tension while free motion quilting. That ALSO does not engage the bobbin to bring up the thread. I know the bobbins are in correctly.
  • Janome Master
  • 627 Answers
When using this slippery thread it is possible you need to change things a little. To change I mean you will have to stay with a straight stitch and place your needle at the left side of the plate. It may need to be placed on the right if the hook is rotating the opposite direction. Give it a try both ways to see which way works better. Anyway, you will need to stay with a straight stitch. When you first attempt to bring your bobbin thread up you need to hold on to the upper thread.
Posted on Dec 02, 2014
  • 84 Answers
SOURCE: Bobbin has no motion
The bobbin will not move unless the thread is being drawn up by the top thread. If the top thread is not bringing up the bobbin thread, but was doing so just fine before it ran out of thread, then most likely the needle has somehow been bent.It may not look bent, but change it anyway. If it was sewing fine before running out, most unlikely that the timing is out. If you removed the black plastic bobbin holder, it may not be seated correctly. Check it for ANY scratches or needle strikes as well. The slightest mark on it will cause dramas. Good luck!
Posted on Oct 22, 2007
  • 5 Answers
SOURCE: Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Posted on Mar 02, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
SOURCE: I recently purchased a Janome1600P
Its the frame, its the open metal frame. I have two machines and have the same problem. Heavier thread, changed needles, raised and lowered. Its the frame you need to frame in like a box and it will work or turn it upside down and ask you husband to screw a large piece of plywood to the bottom to make it square and heavier. The frame will continue to float around, we even screwed it to the floor. For three years I had to go without the quilting. Machine works off stand not on.
Posted on Jun 16, 2012
SOURCE: janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Posted on Sep 03, 2012
I have a euro pro shark sewing machine. I just changed the thread for another project and cannot get the needle to pick up the bobbin thread. Any ideas?
Try installing a brand new needle. Bent/damaged needles will sometimes not pick up the bobbin thread.
Make sure the machine is threaded correctly. Check the bobbin--ie, it is turning the correct direction in the bobbin case and is threaded properly through the bobbin tension.
You might also try pulling the bobbin thread up to the top before beginning to stitch.
How and Why to Bring up the Bobbin Thread
Oct 02, 2016 | Euro-Pro Sewing Machines
My 532 wont pick up cotton from bobbin
First, install a brand new needle. Used/worn/bent needles will sometimes fail to pick up the bobbin thread.
Make sure the bobbin is installed correctly in the bobbin case.
If it still will not pick up the bobbin thread, most likely the machine is out of time (the needle arrives at the incorrect time to intercept the bobbin thread). Take it for service or search the internet for web sites or videos dealing with sewing machine timing.
Sep 03, 2016 | Sewing Machines
Model 7043 Imperial. how do I pick up bobbin tread?
Install a brand new needle--make sure the flat side is facing the correct direction. Remove all the thread. RAISE the presser foot and rethread everything from the beginning. Make sure the bobbin is threaded properly.
Hand rotate the handwheel one full turn and see if it picks up the bobbin thread. If not, make sure you are using the correct needles.
Open the bobbin door and while watching the needle action, watch when the needle comes down, is it looping to catch the bobbin thread? If it's not, then it could be a needle/hook timing problem.
Jan 06, 2016 | Singer Sewing Machines
The thread keeps breaking .
You may have the tension set too tight or are not using the correct needle. Or, the bobbin thread may not be the same as the top thread. If the tensions are o.k., try using a ballpoint needle.
Dec 23, 2015 | Sewing Machines
How do I change the bobbin in a Janome sewing machine?
There is a small plastic plate where the needle goes down through the foot, remove this cover and you will see the bobbin. Remove the bobbin and refill or selecting another bobbin turn it so that when you pull the thread the bobbin turns anti-clock-wise, slip the bobbin into the black plastic casing, pulling the thread towards the small red arrow at the bottom of the casing, slip the thread between break in the silver metal sleeve pulling it to your left between the 2 pieces of metal this is where the tension on the thread is. You have now changed your bobbin. With the plastic plate still off, hold the top thread with your left hand and with your right slowly turn the wheel, this will send the needle (holding your top thread) down into the bobbin casing and will pick up the bottom thread, pull on the top thread and bring the bottom thread up through the hole in the plate. Replace the plastic plate and recommence sewing. Good luck
Sue
Sep 24, 2014 | Janome Sewing Machines
What causes the bobbin thread not to connect with needle thread
make sure the needle is inserted correctly into the needle holder
and pushed all the way up
also the sewing machine could have a timing problem
Feb 14, 2013 | Brother LS-1520 Mechanical Sewing Machine
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
I broke a needle and now it wont pick up bobbin tread
Hello
Make sure the needle is facing in the correct direction,stitches don't form, or skip badly when the needle is turned around.
Put the bobbin in the bobbin case (right way around) leaving a 2-3" tail.
Thread the top of the machine correctly, leaving a 3-4" tail after threading the needle.
make certain your bobbin in locked into position in it's case and the thread is coming from the bobbin in the correct direction. When holding my metal bobbin in my hand, the thread pulls counter clockwise before placing it into my front loading bobbin case.
Also check if the needle is not properly installed in the needle bar,the machine is not threaded properly or the machine needs adjustment or repair..
Feb 12, 2011 | Euro-Pro 416 Mechanical Sewing Machine
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Janome Janoe Deco Coputer 2011 DC2011 Logo
60 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
