Question about Garden
<!-- from fixya rte -->How to clear codes out of the systeme - Garden
  • 29 Answers
Try disconnecting the battery
Posted on Dec 01, 2014
What do codes P0411, P1000
P1000 code means the codes were cleared or the battery was disconnected
Powertrain Control Module (PCM) Reset Description All OBDII scan tools support the powertrain control module (PCM) reset.
The PCM Reset allows the scan tool to command the PCM to clear all emission-related diagnostic information. When resetting the PCM, a DTC P1000 will be stored in the PCM until all the OBD II system monitors or components have been tested to satisfy a drive cycle, without any other faults occurring. For more information about a drive cycle, refer to Drive Cycles .
The following events occur when a PCM reset is performed:
  • Clears the number of Diagnostic Trouble Codes (DTCs).
  • Clears the DTCs.
  • Clears the freeze frame data.
  • Clears diagnostic monitoring test results.
  • Resets status of the OBD II system monitors.
  • Sets DTC P1000.
P0411 Secondary Air Injection System Incorrect Flow Detected
neither of these could cause a no start or no crank problem . Is the battery good an do you have good connections on the battery ? Do the headlamps show bright when on ?
Oct 14, 2015 | 1997 Lincoln Continental
CODE DESCRIPTION FOR 2011 BMW 328I SRS SYSTEM 9419H/37913
You can not clear codes or have them stay away,
until you diagnose the system fault, and make the
required repairs
No idea what those codes are
Never seen ones like that
SRS Codes are in Enhanced Data on a professional
scan tool,you can not get them from global generic
code reader
Oct 03, 2014 | 2011 BMW 328i Coupe
2005 keeps getting emission control v1v solonoid malfuncion
Clearing your so called codes, actually clears all stored data
that you need to diagnose the evap system
Seeing as how that systems monitors only runs every few days,
it will be awhile before a professional can work on it with the
proper test equipment,a scan tool.
You failed apparently to google the evap code, to see the possible
causes of that code being set.
Answer: hook up a scan tool.road test forever, until the evap
monitor runs,check for codes,smoke test the evap system,component test the failed solenoid & replace
Mar 19, 2014 | 2005 Chevrolet Cobalt
I have an 06 ford focus st. i have error codes p0102, p0245, p0079, p0076, and p0458. i am aware what each individual code error is, just wondering if this points to a common fault. i have changed the maf...
Why would you clear any codes?
You already know the codes tell you
what component in what system reported
an out of range condition
You only clear data after you component test
& resolve all issues & road test
You need a scan tool to work on that
Clearing codes,of coarse there coming back
& the stored data is needed to start your testing
You can't work on that without buying the factory
manuals,all of them.& learning about the systems
Need a repair shop
You never change any part based on a code or its
implied name of a part. Codes don't even mean
you have a problem or any parts failed
Study OBD2 Systems on the net.
Sep 19, 2013 | 2006 Ford Focus ST
How do I "clear a code" out of my "OBD2" system, MYSELF ?
If you go to a local autozone, they will scan/clear ODB2 codes on your vehicle for free.
Jul 18, 2012 | 2003 Ford Explorer
CLEAR TROUBLECODES 1995 AEROSTAR
The codes should be cleared with a scanner. However, on a 1995 Aerostar, we are talking about an old EEC-IV system. You cannot clear codes on that vehicle with a generic OBD code reader because it is not OBD compatible. You need to get access to a Ford "Star Tester" or an aftermarket scanner that can emulate a star tester.
Codes can also be cleared on that system by disconnecting the negative battery cable, but this is NOT the recommended procedure because disconnecting and reconnecting the battery cable can cause voltage spikes that can damage sensitive computer equipment in your vehicle. If you decide to do it this way, make sure that you leave the battery disconnected for a minimum of 15 minutes before reconnecting the cable.
May 20, 2012 | 1995 Ford Aerostar
What does 2633 fault code mean (charge air system offset drift under engine load
2633 charge air system offset drift.The drift is the temperature inthe charged air system and the offset is the computers inabilaty to control it.Check your air filter.If its restricted or mostly clogged can result in temp drifting out of control.2633 is very hard to clear.Youll have to do a filter initialization,MAF initialization and a dpf regen to clear the code.Until you clear the code your engine will stay in Limp Home Mode resulting in no power ,early shifts.
Jan 30, 2012 | Cars & Trucks
How long does it take for the codes to clear after a computer resets in a 2001 chevy blazer?
Once it is scanned, they should reset. They can reset sometimes when the battery is taken off. Once it is scanned, it should clear instantly.
Feb 23, 2011 | 2001 Chevrolet Blazer
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
How do I reset my engine warning light on my 2006 Caravan? Thanks
The On Board Diagnostic (OBD) system will turn on the check engine light (CEL) when a problem or inconsistency is detected. When this problem is repaired or somehow clears up on its own, the OBD system will clear the code after a series or diagnostic run cycles. If you determine that the CEL is on erroneously, it can be cleared with most OBD code readers. Also, use the code reader to determine what is wrong and repair it. But do not clear the code just because you don't want to see the CEL on, it is there for a reason. Hopefully, this will help to FixYa problem!
Oct 11, 2010 | 1999 Dodge Caravan
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
