Question about LG DLG5932W Gas Dryer
Knocking dryer drum
Done nothing.
    Genius:
  • 1,554 Answers
The counter weight might be loose
or the load balancing hydraulic arm is bent or leaking
or you left a brick in the dryer,
it will have to be opened an run while watching it likely.
Posted on Dec 01, 2014
Kitchenaid prestige dryer not heating
I worked on a similar dryer with the kenmore brand on halloween. nothing had been done to the dryer since it was new. Take a look:
Kenmore 4-wheel drive dryer de-mystified!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 05, 2013 | KitchenAid Dryers
My whirlpool cabrio dryer is making a loud knocking noise
Check to see if one of the paddles are lose in the dryer drum.
Nov 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Frigidaire heavy duty electric dryer started with sqeaking noises now is knocking belt appears in place drum turns mannually feel somthing loose between drum and rear cover
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 14, 2011 | Frigidaire GLGR642A Gas Dryer
My dryer is knocking.
Most of the time a "clunking" or "knocking" dryer is caused from a cracked drum (the actual area that the clothes sit in) It is usually a broken weld or simply a cracked drum. You will need to peek inside the dryer with a flashlight and look for a crack in the drum area.
Mar 23, 2011 | Amana Dryers
I have an electric frontload dryer. If I turn it on with nothing in it, it sounds like there is a shoe tumbling around. If I open the door and spin the drum by hand, each revolution the drum makes, there...
heatman101
Asker
Nov 22, 2010 | GE Dryers
Drum is making a knocking noise
it could be the rear drum bearing going out or the rear drum rollers going bad or the roller wheels beginning to flatspot or the front rollers in the same shape,you would need to remove the front cover on the unit by removing the lower kick panel screws,then remove the top cover and removing the drum belt,then remove the drum from the machine to examine all the above issues noted
Apr 27, 2010 | Kenmore 63942 Dryer
Drum
repl/ drum rollers that its should fix the knocking noise
Dec 30, 2008 | Kenmore 74602 Gas Dryer
Dryer
This sounds like something is loose in the drum or has gotten into the housing. Check the drum thoroughly. Next: With the power off, remove the back of the unit. Power on...listen...but touch nothing. I suspect you'll find the criminal.
Dec 17, 2007 | LG DLE5977 Electric Dryer
LG DLG5932W Gas Dryer Logo
62 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
