Question about Chevrolet 2011 Chevrolet Traverse AWD LTZ
How do I get front blower to run to heat the 2011 Traverse. Rear one blows, but front doesn't work on either AC or heat
Haven't tried anything yet. Could it be a fuse?
  • 507 Answers
SOURCE: 2003 chevy tahoe no rear heat
I know the earlier tahoe's have two heater lines running from the engine compartment to the rear under the vechile. Those lines could be clogged or pinched shut. What you do is get two hose locking pliers. Go under your truck, they are two metal lines that turn into rubber and back into metal again farther down the line. First, checked for pinched lines. If none, find where the rubber hoses are, clamp them off, remove from metal lines and drain. Use garden hose to flush fresh water through. When water comes through at high pressure and pretty clear, it should be done. Reconnect hoses, top off radiator fluid and it should be fine.
Posted on Feb 21, 2009
carfreak1217
  • 109 Answers
SOURCE: intermittent rear ac problem
Possibly a problem with rear expansion valve
Posted on Jun 28, 2009
  • 118 Answers
SOURCE: pasenger vents blow warm air while driver side blows cold when ac
Check and replace the right side temp-controller.
Posted on Jul 20, 2009
SOURCE: Front heat does not work, rear heat does?
I'm just a regular diy'er, no training. Had same problem, 2001 Suburban, front blew cool air when heating, rear heat warmed up nicely. After reading other posts on other boards, took off the the heater hose clamps (make sure you remember which is which) at the firewall. With low pressure garden hose flushed left inlet/outlet first till I got good flow, then the right side, and back to left. Reattached hoses, started and tested. Heat blows just fine. I can't think of anything that could be damaged by this, but check with someone who know something first before trying it on your vehicle, but it worked for me. So far so good.
Posted on Oct 25, 2009
Testimonial: "Tried this simple solution and it worked perfectly. Who knows how much repair money I saved, thank you."
kirkx
  • 2019 Answers
SOURCE: blower fan not working. AC still cooling. Not
Sure. But could also be fan switch or motor. Check with a test light to make sure where the voltage stops.
Posted on Apr 13, 2010
I have a 2011 Chevy Traverse that blows hot air.
Depending if it's manual temp control or auto.............
Here's manual
1 - Air Temperature Sensor - Upper Left
2 - Air Temperature Actuator - Left
3 - Air Temperature Sensor - Lower Right
4 - Air Temperature Actuator - Right
5 - Mode Actuator
6 - Air Temperature Sensor - Upper Right
7 - Blower Motor
8 - Blower Motor Control Module
9 - Evaporator Temperature Sensor
10 - Air Temperature Sensor - Lower Left
Here's auto
1 - Mode Actuator
2 - Recirculation Actuator
3 - Blower Motor
4 - Blower Motor Control Module
5 - Air Temperature Actuator
6 - Evaporator Temperature Sensor
Mar 13, 2016 | 2011 Chevrolet Traverse
Ihave a 2011 equinox. The ac panel stoped working. I checked all fuses inside and out. Is there a relay thac controls this?
Chevy Traverse Forum: A/C won't change positions and passenger won ...
www.traverseforum.com > Chevy Traverse > Tech Section > HVAC
Apr 6, 2013 - 20 posts - ‎11 authors
I have a 2009 Traverse LT (w/ 42k miles... ) and we just ... Turn the car on, but DONOT TOUCH the HVAC controls. The AC will come on and ... Dual Climate Control not working properly ...
Sep 5, 2014
Front power outlet (cigarette lighter plug ...
Mar 1, 2013
2009 Traverse Heat Selector Switch Not Working
Nov 13, 2012
Air conditioning problem with 2009 Traverse
Jun 30, 2011
More results from www.traverseforum.com
Compressor : Chevrolet Equinox Common Heating & Air ...
repairpal.com > Problems > Chevrolet > Equinox
GM Recalls 2010 Chevy Equinox and GMC Terrainwww.autoevolution.com > News > RecallsDec 29, 2009 - "The software in the center instrument panel can cause the heating, air conditioning defrost, ... I have a 2007 Equinox, just had the fuel injectors cleaned out..... On 1 February 2011 at 23:32 UTC, al (gonzo) said: .... 60,000 miles I wonder if that will be covered under this recall? does say ac may stop working.Ac Problem: I Have a 2007 Equinox. the Air Conditioner Will ...www.2carpros.com/questions/2007-chevrolet-equinox-ac-problem
Dec 21, 2015 | AC Cars & Trucks
My rear air conditioner on my 2011 Traverse only blows warm air. Front air works good
clogged air condition filter leading to rear unit Possible LOW on FREON
Aug 20, 2014 | 2011 Chevrolet Traverse LS
Blower motor wont run for the air or heat and none of the heated seatswork
I had a 2003 caddy dts same issue the blower motor has probably gone bad u can order them online. What u can also try is kicking under the passenger side glove box area that's where the blower is located sometimes they get stuck. Try kicking or tapping under there and see if it pops on. I did this with my car
Dec 13, 2013 | 2005 Cadillac Deville
Front blower motor doesn't work but works in rear
Change the. Blower motor resistor. $25 part near the blower. Chevy suvs are famous for bad blower resistors
Sep 10, 2012 | 2002 Chevrolet TrailBlazer
2004 CHEVY SUBURBAN FRONT A/C WORKS BUT THE REAR DOESN'T TURN ON
There is a blower motor control processor for the back blower - it takes input from the front control and the rear control and decides the fan speed. That processor could be faulty, or the blower motor, or a 30amp fuse in the engine compartment.
In the front system you have a controller and blend doors that direct air thru the heater core and evaporator. You would need to check the operation of those blend doors.
Aug 17, 2012 | 2004 Chevrolet Suburban
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
Ac/heater blower does not turn on up front but works in the rear.all fuse are good( 2001 odyssey)
Got the same problem, front blower does not work but the rear blower runs great...Need Help!!
Oct 04, 2009 | 2004 Honda Odyssey
2002 Cadillac DeVille, AC/Heat blower not blowing out air
Have you tried smacking the blower motor? If it starts running after you hit it, replace it.
Aug 20, 2009 | 2002 Cadillac Deville
Chevrolet 2011 Chevrolet Traverse AWD LTZ Logo
49 people viewed this question
Top Chevrolet Computers & Internet Experts
Richard Warren
Richard Warren
Terry Hair
Mike Dutton
Are you a Chevrolet Computer and Internet Expert? Answer questions, earn points and help others
