42 in Phillips tv will not power up. I had to unplug and push the on off button 20 times then plug it back in to get it to work. Now that doesn't help. Do I need a new power supply?
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 02, 2014
scottyfixit
  • 186 Answers
SOURCE: Hitachi 42HDS69 42 in. Plasma... Problem
Describe the past - How did it fail? One day or acting up for a while? Could be a weak power supply - a bad capacitor on a power supply too. Look for popped up capacitor top inside.
Posted on Apr 29, 2008
  • 4234 Answers
SOURCE: phillips 42 inch tv
The stand base part number is 310430814621 and is available for $71.58 from tritronicsinc.com
Dan
Posted on Jul 30, 2008
SOURCE: 5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Posted on Jul 31, 2008
SOURCE: 42 plasma panasonic
DUDEEE this exact same problem happened to me!!!! what happened was it was workin fine then it started turning on and off, then now it goes through these weird phases where i cant turn it off using remote or the power button. every button on the side of the tv and the remote doesnt work. so i have to unplug it to turn it off, what a messedup problem!!! im taking my LG 32LB9D to the tv shop tomorrow i hope to get it assest and possibly fix, ill tell u how to solve the problem if my tv is fixed. :)
Posted on Nov 02, 2008
SOURCE: LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Posted on Nov 22, 2009
I own a phillips plama tv 42 inch , it works fine looks good , only one problem after 10 or 15 mins it click off and wont come back on untill its been unpluged at the wall , and plugged back in .
You have a component in the power supply that is getting hot and changing in it's value, look for bulging caps first or burnt spots around resistors.
May 03, 2011 | Philips 42 in. LCD TV
My Vizio VW42L LCD television turns itself completely off
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Feb 01, 2010 | Vizio VW42LF 42 in. LCD HDTV
Power suddenly went out on the tv - the standby/power button flashes and the there seems to be no way to turn the tv on again.
What you should try is unplugging the tv, then push the power button. After about 10-20 seconds plug the tv back in. The tv should work now and if not, let me know and I can help you further.
Sep 30, 2009 | Sony KDF-E42A10 42 in. LCD Television
Doesn't always come on the first time.
Power supply issue, it can be solved by adjusting a preset on the p/s have a tech do it, Julio milleniumtvsvc@gmail.com
Jul 26, 2009 | Philips 42PF9630A 42 in. Plasma Television
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Tv does not turn on
Kindly check the powersupply area for a burn fuse & also check for the bad solder on the board...
Thank you
May 29, 2008 | Philips 27PT543S 27" TV
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Sony KV-32FS200
I read the manual and it says in the FAQ.
Q- TV doesn’t turn on
after disconnecting
the TV and timer
LED flashes
❏ Press the POWER button on your remote control or in the TV front
panel, one more time.
Tell me if it works...
Oct 09, 2007 | Sony FD Trinitron WEGA KV-32FS200 32" TV
My 42 inch plasma wont turn back on after power cut?
We purchased a phillips plasma 50" in july 06 and it cut on and off 5 or more times a day I called phillips customer service they told us it was due to the cable company they came out and changed the tv jack gave us a new box and tested the lines said everything was ok. The problem still kept happening got back to phillips and they sent us a flash drive to update the info in the tv. still kept happening told us it was due to tv being sensitive to power flutuations. well we are now 5mths out of warrenty and the power board blows up! phillips will not do anything to help the person I spoke with admitted we were given bad advice the bill was estimated at over $500 so if I were you if its still under warrenty make them send someone out to look at it, Reading up on phillips tv complaints this seems to be a common thing By the way phillips customer service sucks dont rely on them to help you much. good luck
Jul 02, 2007 | Philips 42PF7320A 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
