Question about Garden
I Have 5-in- Power center and need it repaired where do I go?
Looking for place to take it to be repaired?
    Sergeant:
  • 337 Answers
Hi Marsha I don't know what area you live in but if you contact the maker they will tell you a recommended service center near you.
Posted on Dec 02, 2014
Lenovo wont power up
Do you have access to a volt-ohm meter? Look at your power supply, it says what the voltage needs to be. Does it have a green led & is it on?
To chk using a good meter, dis-connect your power supply from your pc & from the wall plug. If both ends are not connected you will not got shocked if your in your home, sitting down. Turn the meter dial to the "ohm" setting & begin with the R X 1 scale, place the black lead to the outside edge of the cable, place the red lead to the center pin, if the scale meter doesn't move, then try each of the other scales. After you finally got "a reading", do the same to the end that plugs into the wall. They will be different, but you do have to have a reading on both ends, or the power supply is bad. if all is good, (got a reading), plug the power supply back in to the wall & turn the meter to the dc scale & voltage to the 10 to 50 vdc setting. Very cautiously now, place the black lead on the outside edge again, & the red lead to the "tip" of the pin in you pc end of the cable. DO NOT ALLOW the red lead to make contact with the outside edge of the cable or you will short out the power supply! If you have the proper voltage, (usually 16vdc to 20vdc) the power supply is ok & you'll need to take the pc to a competent repair place to get a quote for repair. BE CAREFUL!
Feb 08, 2013 | Lenovo 3000 C200 Notebook
SANYO VPC-TP1000 CAMERA
Hi please try to do this and let me know. Remove the battery and give a look inside the battery compartment with spot light. Make sure that place are clean and there no damaged mark. Specially look the Battery connector pins. That should in proper place , not bend, not even sulfur layer there. Use ear buds and drop of alcohol for cleaning. After checking if every thing Ok then some how the power supply not able to connect the circuit board. Its happens when the connectivity cable disconnected or damaged, circuit board short or the power transformer stop working. For all this internal fault part confirmation you need to visit electronic repair center.
but before visit for repairing make sure the battery which one you use that's is fully charged with working condition. Thank you
Aug 10, 2012 | Sanyo Cameras
My rebel xsi won't turn on. there is nothing. I used it yesterday and it was fine. I changed the battery and still nothing! HELP!
Aug 09, 2012 | Canon EOS Rebel XSi Digital Camera
The light wont stay on
Aug 09, 2012 | Samsung NV3 Digital Camera
Power windows stopped working
Hi Kristine,
Look under the hood at the power distribution center. Fuse #12 should be for the power windows (or consult your manual).
You may find that the fuse is good, in which case there may be a problem with the ground wire in the harness that is between the body and driver door. Typically, the ground is a larger, black insulated wire in this harness. Because it is larger than the others, it is less flexible than they and is likely to break over time. The place it breaks is where the flexing takes place - the black rubber boot between the door and body.
Pull the boot back to expose the harness and black wire. Locate the break and repair as needed.
Jun 14, 2012 | 2004 Jeep Grand Cherokee
Model- kp 51ws 500 manufactured january 2003 color rear video projector the screen looks 3-d, in the center of the screen it looks fine but on the edges of the screen the words or images look 3d and...
BOTH OF THE STK-392-560 convergence chips need to be replaced; there are also fuses on the power board that protect them--do not look like fuses; if you need photos of the place where the chips are and the fuses, let me know.
Repair takes about a hour and parts if purchased on EBAY will be under 25 dollars.
SD TECH
Jul 28, 2010 | Sony KP-53HS10 TV
Dc power connector seems loose. laptop wont charge. Looking to see if there is a schematic or disassembly guide out there somewhere.
The Power Jack's soldering might have gone loose, that makes this problem. Try contacting near by toshiba service center, and place a repair order and get it fix.
Jun 30, 2010 | Toshiba Satellite P205D-S7454 Notebook
Need to send Skil power wrench in for repair
OK the nearest one to Hayward is the Factory Service Center located at Bosch/Skil Service Center 4980 Landon Dr., Anaheim CA 92807 or call toll free 1-800-346-4103. You can also go to Skiltools.com and type in your zip code to find the nearest authorized center within a specific radius. Hope this helps
Jan 31, 2009 | Drills
Car radio blows fuses
Hello grm4,
The problem you are having is that the power amplifier or one of the driver transistors has shorted to ground and is causing excessive current flow which is blowing the fuse. That being said what is your location and area. Have you tried looking in a phone book or on the internet for a place that is near you. You would be very hard pressed to find a center that repairs Blaupunkt radios exclusively. But if you look in your area you should find a place that can repair this unit.
I hope this helps
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
Nov 27, 2008 | Car Audio & Video
Can't find a Vivitar phone number to repair my 550
No, please. I was looking for the company-related repair center. I think an outfit by the name of Sakar is the official repair center, but time will tell.
Thanks but no thanks
Nov 04, 2008 | Vivitar DVR-550 DV Camcorder
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
