Ny bizhub 750 giving error c-2401 sometimes its oky sometimes error coming what will i do sir
3 Suggested Answers
SOURCE: bizhub konica 500 malfunction c-6702
trouble code c3904
Posted on Apr 09, 2010
resonatom
SOURCE: i wanna know how to reset the maintenance time konica minolta bizhub 750
bizhub c252 how do you reset enter serial number
Posted on Mar 09, 2012
How do i fix error code c-2401
If you wish to get some details; check the site linked here. Pull up older posts......
http://electro-medical.blogspot.com/
Apr 22, 2016 | Konica Minolta bizhub 750
What is error code c-2401?
Clean the drum sensor that monitors the drum, and the surrounding area. also has the developer and drum been replaced.to clean the drum sensor the drum must be removed. do not use a vacuum cleaner as static electiricty can destroy the senor, use a clean brush. located under the drum to the rear has a white cover over it, the clear sensor in the middle is for paper jams.
I have a konica minolta, bizhub 750 that is showing an error massage 'c2401. can someone help?
Thread Bizhub 750 error code 2401
Maybe the link above will help. I found it by a google search, and unfortunately I am not familiar with that model.
Apr 22, 2016 | Konica Minolta bizhub Office Equipment &...
I have a problem in bizhub 750 code error c-6708 how can i fix this code error
Might be the Exposure lamp the bright light that comes on under the document feeder make a copy with the doc feeder up does that bright light come on? Or mite be CCD (this is the device that read the original document before it is sent to the LASER) the big black assemble under the big glass. Either one or both mite need to be replaced.
Mar 13, 2015 | Konica Minolta bizhub 750
Have bizhub 750 and its giving me a code C - C111. Can someone help me please
Have you recently done a firmware upgrade? This code is sometimes linked to the incorrect firmware being applied to the copier.
Feb 16, 2015 | Konica Minolta bizhub 750
How to reset error code 3505 in konica minolta bizhub 600
When you reinstalled the upper and lower fused rollers mite have flipped the sensor so it's not riding on the fuser roller
Dec 31, 2014 | Konica Minolta Bizhub 600 750 Image...
Codigo 2401 bizhub 600
The erase lamp (EL) is unconnected. Did some one recently replace something in the image unit. There are two small connectors that need to be connected. when the Charge Corona Assy.is installed above the drum that assy houses the Erase lamp.
Mar 19, 2014 | Konica Minolta Bizhub 600 750 Image...
How to reset error code c-3803
Sir/Mam,
POWER off the machine Main power switch is inside the machine. Keep the sub power switch on one located on the side of the control panel. Now hold down Utility/Counter button and turn on main power close cabinet then wait for trouble reset Touch it get OK then power off WAIT TEN SECONDS then power up IF IT COMES BACK DO NOT RESET IT. IT IS BROKE AND MACHINE IS TELLING YOU THAT. THIS CODE deal with the FUSER (Hot part) Can catch fire!!!!!!!!!!!!!!!!!!!!!
Apr 30, 2013 | Konica Minolta Bizhub 600 750 Image...
I have a konica Minolta bizhub 750 and its giving me error code c2401 what may be the problem
Sir/Mam, The Erase lamp is disconnected. have you had anyone recently replace the drum or developer? if so the erase lamp connection is not seated properly or you do have a bad erase lamp. You will have to remove the drum cartridge open front door life up small pipe unscrew the main nut hold nut unscrew (When screwing back in do not allow the nut to turn to the right) Any way once the cartridge is removed check two connections above the drum to the rear to small connectors (BE CAREFUL DO NOT SCRATCH OR NICK THE DRUM DO NOT EXPOSE TO SUNLIGHT) ensure the two connectors are secured! Re-install. if the code comes back you mite have a bad Erase Lamp. Contact a Technician!
Feb 05, 2013 | Konica Minolta Developer 02xk Dv710 for...
jasbo
jasbo
