Question about Acer Aspire 5552 Laptop
I have an acer aspire 5552-5898 and i am unable to enable the wifi even after hitting FN+F3 to turn it on
It stopped working one night when i turned the laptop off after watching netflix. Once I turned it on again I tried FN+F3 and F2 in some cases. I have done the system restore numerous times. Ive disabled the broadband since thats the only connection available after it was turned back on.
    Problem Solver:
  • 10 Answers
From what I can find on your notebook it looks as though there may be a physical switch for your wireless as well. Be sure that this switch/button is turned on prior to using the Function F3 keys to turn on your wireless.
Posted on Dec 01, 2014
SOURCE: Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Posted on Oct 21, 2007
SOURCE: Embedded numeric keypad
To toggle the embedded numberic keypad Hold down the blue Fn (function) key and press NumLk.
Posted on Oct 25, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Wirelless Mini Pc Card Not able to Enable It
Does this website help when you need to download the drivers:
http://www.atheros.cz/download.php?atheros=AR5007EG&system=1
Posted on Jun 14, 2008
  • 74 Answers
SOURCE: Fn F5 not working
Check the BIOS - some laptops can be set in there to start with the LCD, monitor or both.
Hope this helps
Posted on Apr 30, 2009
  • 52 Answers
SOURCE: Want to restore my Acer aspire 4720z!
From Acer direct
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
How do I activate Bluetooth on Acer Aspire 4810TZ-4696?
Check to see if there is an "Fn" key to enable Bluetooth. Most Acer's have a bluetooth icon on the F3 key. By pressing Fn-F3 you are able to enable or disable bluetooth.
Dec 18, 2015 | Acer Computers & Internet
Fn + f3 problem
There is a specific piece of software you can get from the acer website after you put in the serial number that will enable these features.
Jul 11, 2012 | Acer Aspire 5742Z6682 Notebook
Unable to activate wifi, unable to connect wifi from my acer one d260
Check if device driver is installed:
1. press windows logo + R 2. type devmgmt.msc 3. check network adapter if there is a wireless device available
If there is a missing driver, pop in the acer driver CD and install the wireless driver from there.
to run the wireless manager, press Fn + F3 to turn the wireless on
Jun 26, 2011 | Acer Aspire One PC Notebook
My wifi isnt working how do i turn it on and off
press Fn+F3
some acer laptop use this code to turn on-off the wifi and bluetooth
i hope this helpful
thank you for using fixya
Feb 14, 2011 | Acer Aspire 5335-2257 Notebook
My acer aspire 5810tg says wireless capability disabled and dont know how to turn back on
1. Check out BIOS settings, if there is any option like enable wireless etc.
2. Check "Device Manager" if the wireless drivers are installed and enabled.
3. Try 'Fn+F3 and see if the wifi indication on the right side near power button turns.
4. i dont think there is wireless on/off button. although u may inspect the machine for it.
Nov 01, 2010 | Computers & Internet
Where is the wireless switch on a Acer Aspire 5735
Usually, if there is no HARD SWITCH for wifi, there is an equivalent keyboard key combination to turn wifi radio receiver ON. Look at your laptop's Function Keys: F1, F2, ... F12. Among them there is an icon for WIFI, something that looks like an antenna with wave signals. Now press and hold the FN key and press that function key with the wifi icon. Example, if the wifi icon appears at F10, then press FN + F10 to turn your wifi ON or OFF.
Nov 17, 2009 | Acer Aspire 5735 Notebook
Acer Aspire 5552 Laptop Logo
135 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
