Question about Toshiba Canvio Plus 3.0 1TB USB 3.0/2.0 Portable Hard Drive - Bla
My hard drive will not connect to my laptop. Why will it no work?
Tried connecting to other computers, tried restarting the computer. Nothing seems to be working. Not sure what else to do. Not sure of model number
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Is this an internal drive or USB drive?
Posted on Dec 01, 2014
  • 1019 Answers
SOURCE: Toshiba Hard Drive Crash
if the datas aleady deleted, then you have nothing to lose. Right ?
What you need is a 2.5 to 3.5 inch IDE ribbon cable connector.
this will enable you to put the drive into an IDE slot on the PC internal motherboard ( primary/secondary )
Unless it,s already 3.5"
boot the computer, see if it recognises the drive. And format it.
then you may be able, to re-fit back into the external casing, and use as an external again.
Mike @ compurepair.
Posted on Feb 25, 2008
  • 1019 Answers
SOURCE: How to get my hard drive to work.
external USB Drives, sometimes lack Power to perform properly.
you can purchase a lead that splits into 2 USB cables, using the dual cable, into 2 USB ports, can sometimes remedy This.
Mike @ compurepair.
57 varieties
  • 1653 Answers
SOURCE: I have an external hard drive, Toshiba 160gb,
Buy yourself a USB to IDE & SATA disk adapter from eBay fro a few $$$. Then open the Tosh case and unplug the drive and power supply connectors and remove it from the case - carefully. Plug it into the USB to IDE /SATA adapter and lay it flat on a non conductive surface and connect the USB to your PC should see it as a new drive. This will allow you to get the data off the drive, check for errors and reformat it. If you can’t see the drive from the PC then it is likely that the drive is fatally faulty.
Posted on Oct 13, 2009
eng_darwish1
  • 233 Answers
SOURCE: external hard drive won't connect to computer
first of all you should try it on deferent pc , if its ok then thatleads us to insufficient power provided through usb ports , try usingback usb ports not the ON-front, and if the problem still try usingdual-usb cable like thishttp://www.cooldrives.com/usb-power-cable-mini-b.htmland if the external hdd doesn't work at all it might be the usb controller board inside the hdd cage needs to be changedif you cant find a similar one you may buy a new empty cage
Posted on Mar 22, 2010
  • 24 Answers
SOURCE: My portable Toshiba 320gb Hard
Unfortunately, this usually means you have some type of hardware problem. If you hear the drive spin up and just never connect to the computer, you are in better shape than most. The usual tricks to get around this are as follows:
  • Plug it into a different USB port, preferably on in a different part of the computer. The motherboard's USB hub might have flaked out.
  • Unplug it from the computer over night and try again later on. You may have tripped a thermal fuse on the USB line and sometimes they take a bit to reset.
  • If that fails, then remove the disk from the enclosure and hook it up to a machine with a free port. If you don't have one, I use Aprocorn DriveWire 3-in-one Disk interface to get on loose hard disks.
Unfortunately, there's really not much that can be done other than this. Good luck.
Posted on Feb 28, 2011
Power Light comes on, no function what so ever
Check to make sure that the FireWire or USB cables are
correctly attached and firmly seated in both the drive and
computer's FireWire or USB ports. Disconnect them, wait 30
seconds, and reconnect them. If the drive is still not
recognized, restart your computer and try again. If they are
correctly connected and your drive still does not power on,
trying using the optional power sharing cable, described in
section 2.3 Connecting the Optional Power Supply of the LaCie Mobile Hard Drive User Manual.
Feb 17, 2013 | LaCie Computers & Internet
My Avastor HDX Portable HD drive just crashed. I had it connected to my Mac, and when finished using it I wanted to eject the disc but it wouldn't, whatever i tried. So i disconnected it anyway. But...
Hi!
i dont know if your drive is dead , but try to connected to an Other Pc with different System (windows Xp Or 7 ) and see if it work try to formate it , but if he didn't work that's mean is dead ,
good Luck
May 23, 2011 | Avastor HDX-800 400 GB FireWire 400...
I have a toshiba satellite a-105-s2091 and i got the black death screen problem. I have tried to restart and reboot with the f8, the f12 and nothing seems to work... what else can I try please help!!!
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 01, 2011 | Toshiba Satellite A105-S2031 A105-S2091...
My camera worked before by uploading pics onto the comp. Now it doesn't let me at all. I tried to upload tonight and first noticed the problem. So I restarted and got back on tried it again it worked but...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 18, 2010 | Kodak EasyShare V1073 Digital Camera
I was using my HDD to watch a movie and it accidently fell of the table disconnecting it from my laptop. Now when i try to reconnect it, it isnt recognised by my laptop or computer and starts making a...
Problem!
Ur HD just got internal problem, when it drops it created more than 5 g of shock and might have dislocated the LENS ARM that reads the disc inside!
The only one that can open and repair it is the manufacturer themselves!
my advise is to bring ur unit to ur nearest service center to have them open it and repair the internal damage part, so that they could save ur data and unit itself!
Hope that helps u out!
Dec 03, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have a Plumax enclosure I am trying to use. When I hook up my WD800 ide drive nothing seems to work. The power comes on, and the HDrive spins but my vista 64 desktop does not recognize or show the drive...
Try hooking it up to a different USB port. Go to computer on the start menu and see if your computer sees it. Try restarting your computer with the hard drive already connected and turned on, the computer may recognize it then.
Aug 23, 2009 | Plumax PM-350SI-PJS SIlver 3.5" Combo...
Computer won't start up
hmm have you tried taking the bottom off and making sure nothing got hot and melted or ruined anything...???
Jan 09, 2009 | Dell Inspiron 1501 Notebook
Dead pc
try to remove all external device connected to your computer. just leave the keyboad, mouse and monitor connected.
restart computer.
if still a blank screen
remove everything connected to your computer (mouse kyeboard and monitor) restart if nothing happens
open your computer and remove all devices (hard drive, optical drives, memory... restart,,, you should be hearing beeping sounds indicating motherboard is looking for memory. try putting back 1 memory at a time and checking all mem slot. to identify if one of the memory could be causing the blank screen. if both memory will not work try to use known good working memory. if you dont get to hear the beeping sound using a known good working memory. your memory is the problem.
give me more info
Jun 19, 2008 | Dell XPS 200 PC Desktop
Light doesn't turn blue at all
Plug it into another computer if possible, clear ALL files on it.
You must of been sending something to it when you flicked the switch, they would normally go off straight away.
(Backup on the other computer first)
If this does not work then you may want to see if you can see a usb stick in your USB ports. If you can it's a fault with the harddrive, nothing else you can do.
Mar 31, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Computer seems to be restarting endlessly
Its seems any one of the key of your got stuck. So please check out your keyboard first.
If problem still not fixed then, try to re-install your RAM: remove the RAM clean its connection point to the board, and placed it agin gently. then try to re-boot.
Please let me know your feed back.
Thanks
Iqbal
Mar 29, 2008 | Computers & Internet
Toshiba Canvio Plus 3.0 1TB USB 3.0/2.0 Portable Hard Drive - Bla Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
