Question about Bush Televison & Video
Flat screen has gone black but sound is fine
Taken all connections off and checked them put them back screen still black and sounds is still ok
    New Friend:
  • 5 Answers
Suggest that you borrow a monitor from someone and try it on your system. If it works , you may have a defective backlight on your monitor , which means that you may want to replace the monitor. If the replacement monitor also is black , you probably have a video output problem , which would require repair of your computer.
Posted on Dec 01, 2014
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
milkburp
  • 416 Answers
SOURCE: no sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Posted on Mar 26, 2010
  • 8457 Answers
SOURCE: No sound on my Polaroid flat screen
Unplug,replug the tv about an hour later.Go in ur tv menu.Go to AUDIO,go down to reset it,well go back to factory setting.Ur sound should return.Not,than ur Tuner board is dead.Trires websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacenent.
Posted on May 04, 2010
SOURCE: Hi, Maxent P420142x3. Screen picture has gone....
my maxent p420142x3 i have sound but no picture any answers
Posted on Jun 29, 2010
joeymille916
  • 143 Answers
SOURCE: I have a Vizio P50HDTV20A. I came back from a
My guess from this little information is the buffer boards are bad. The Y Buffers... (3 boards, main, lower, and upper should be checked). The main buffer could just be out, but usually when we replace one, we replace all three. If you are tech savvy and are going to try to fix this yourself, I would start there. Here is a pic of the Y main.. Part # LJ92-01399A . 086lj9201399a.jpgthe Y lower and Y upper are connected to this.. Usually on the left side of the TV (from the back).
There is a fuse on this board, so it could have blown, but more likely, it's time to be replaced.
The Upper and Lower Y Buffers are part #'s LJ41-05121A and LJ41-05122A. I recently replaced mine on my Philips Plasma and it's been working fine since!
Good Luck!
Posted on Oct 12, 2010
Testimonial: "I'm a techno but this gives me somethin for repairman. now to start to find him in my little town of 3200!"
Pn60e530 Samsung plasma tv when turning on screen flashes pink then goes black Sound is on no picture
screen drive on back of the screen has gone. they do over heat. the pink is the plasma lighting. replace the screen driver board and should be fine, when replacing put a bit of heat sinc on the top of the 2 or so chips big square ones on the board should help it last longer.
Sep 14, 2013 | Televison & Video
JVC LT-52P789 no picture just sound
If this is an LCD TV, show a flash light on the screen from a safe distance. If you can see picture, it means the backlights have gone off and the TV might need servicing.
Aug 23, 2012 | JVC LT Televison & Video
Hi my Samsung PS-50C96HDX/XEU was working fine and we went out of the room and came back in and the picture has gone but the sound is working fine. I turned it off for a few hours and turned it back on...
You will need to purchase a board called a y-sustain witch controls the buffer boards on the unit, but first you will need to check the power supply board as well. Now just because it does not appear that the caps are dead does not mean you are getting full power to the rest of the TV. I would check into the Y-sustain board at www.partstore.com or www.shopjimy.com . I hope this information does help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Nov 23, 2011 | Televison & Video
Pavilion dv9700, screen goes black if Iclose it. Take it apart, put it back together and works fine. Close top. goes black again. Take screen apart screen ok. What the heck. Inverter connections look ok....
Sounds like a loose lcd cable, I'd check to make sure it is secure (back of lcd) and where it connects to the motherboard. Usually a piece of tape right where it connects solves the problem ;)
Oct 09, 2010 | HP Pavilion dv9700t Notebook PC
Picture went black
The backlight inverter board may have gone out, or the power supply for the inverter may have gone out. If it is two years old, you should look at the power supply first for bad capacitors.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find. What is themodel number anyway?
Nov 12, 2009 | Televison & Video
Screen goes black, while the rest of tv works fine, sound is ok, can change channels.
Back lights are gone or the voltage 2 them is not present. Cheaper to buy a new one.
Nov 04, 2009 | LG 20LS7DC 20 in. LCD TV
Screen went black and could smell electrical burning,still have sound
It sounds like your inverter has gone bad, this is what powers your back light. If you replace this, your television should be ok.
Oct 27, 2009 | Sanyo 42 in. LCD TV
My sound as gone on my toshiba regza tv
Does the sound icon move up like it should on the screen when you increase the volume?
Dec 09, 2017 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Sound but picture is black. Checked cables. Everything else is OK
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
Jul 07, 2009 | Toshiba Televison & Video
Televison & Video Logo
51 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
