Question about Haier Hlt71 7-inch Handheld Lcd Tv
I accidentally broke the antenna off from the TV while trying to tighten it (always was slipping downward). Tried to attach it again with duct tape, but of course that didn't help (just thought I'd t
This is my first try at getting a resolution. HELP!
  • the great handy man
    the great handy man Dec 01, 2014
    Hi Steena Travis, Can you remove the antenna complately or not if so i may be able to find you a place where you can get a new one, so please look in to that
    Greate Handt manny :)
  • Steena Travis Dec 10, 2014
    The antenna broke COMPLETELY off from the TV. Without the antenna (& it requires a tight fit to make it work) I get the "blank database" msg., & no reception
2002 Chrysler Town & Country antenna installation
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
Jun 04, 2012 | 2002 Chrysler Town & Country
The hood latch cable broke under the hood how can i open it
Saturn Vue hood release can be opened (if the cable is not broken) by disconnecting the cable from the back of the release lever, grabbing the ball on the end of the cable with some large pliers ("channel locks") and pulling hard. A metal "wire keeper" bracket clamped to the cable end under the hood to serve as a spacer and the release lever works.
The purpose of this bulletin is to provide a procedure for opening the hood on the Saturn VUE and ION vehicles should the hood latch release cable mechanism become inoperative.
VUE Hood Opening Procedure Modify the Saturn radio antenna by bending the antenna mast 1 in. (2.54 cm) above the antenna base to a 25 degree angle
Open hood of similar vehicle to locate hood latch release cable to hood latch attachment point.
Using modified antenna, note approximate location that antenna will have to enter in between fascia and hood to access the hood latch cable attachment point. This should be toward the left edge of the Saturn emblem. Also note position of the modified antenna base. It should be angled downward.
Note: Use protective tape on the hood and fascia where the antenna will be inserted to protect the surfaces from scratches
On vehicle with inoperative latch, insert antenna between hood and fascia and depress the hood latch cable until the hood is opened.
Good luck and thank you for using fixya
Mar 15, 2010 | 2003 Saturn VUE
How do i connect the air hose?
Shuld have been a connector with unit. Just slip the hose over the connector and use a large ziptie to tighten it down. You can also use some duct tape also but I always use a zip tie. Rus
Nov 07, 2009 | DeLonghi CF210 Portable Air Conditioner
My antenna broke, i purchased new antenna but when I tried to install new antenna the old antenna fell inside of radiio, I took out all the screws but still cannot get radio apart
On the back panel, there is a black decal located near the center. Warm this decal with a hair dryer (warm it, don't get it hot)Slip a knife blade under the right side and lift it up. Remove the hidden screw under the decal, and the the other five and the back will come off. replace the FM antenna and you are good to go. I had the same problem. mcarmich
Jun 13, 2009 | Eton FR300 AM/FM/Weather/TV Radio
Rewinding starter spring on chainsaw
I was able to rewind the spring steel coil, but it took 2 people, one at each end, to wind it tightly and hold it tightly enough to fit back into the casing. The bend at the end of the coil must be re-inserted into its own retainer. It was not easy, and it takes some time to get this done. RH
Mar 28, 2009 | Garden
How to replace an antenna on a 1988 honda accord.
Ouch! I haven't tried this myself, but would electrician's tape work? Try feeding it from either end...
Jan 20, 2009 | 1988 Honda Accord 4 Door
Picture not clear when playing a recorded program from dvd
I had a similar problem with an Insignia converter box. This is confusing but . . . I was told by an Insignia person that you can only program the channel that you have on and cannot record a different channel. My output channel is 3. My roof antenna is attached to my converter box "From Antenna" jack. Attach the converter's "To TV (RF)" jack to your VCR's "Antenna Input" jack. Attach "Antenna Output" jack to TV "Antenna Input". You will see your programs on your output channel, but if your VCR is like mine, your VCR may not recognize anything but your output channel, no matter which station is actually showing on the TV. If I want to record a show on channel 7 while I'm gone, I have to make sure the converter station is on 7 and that I choose channel 3 as my channel to record. You cannot program shows to be taped on different stations unless you physically change it on the converter box. I put my VCR on "Record" and flipped the stations from one to the next from my converter remote control and I taped exactly what was on the screen from one station to the next. You cannot tape one thing and watch another. Clear as mud??? Hopefully, not.
Jan 02, 2009 | Insignia Digital-to-Analog Converter for...
Radio antenna
You should be able to take the plastic piece going down the inside panel from roof to dash. Usually somwhere in there or under the dash you will find a slip connection. But some go all the way to the radio.
Oct 09, 2008 | 1997 Honda Civic
Haier Hlt71 7-inch Handheld Lcd Tv Logo
55 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
