Question about SES Trims Pillar Posts Chevy Trailblazer 2002 2003 2004 2005 2006 2007 2008 2009
I have a 2006 chevy trailblazer. Sometimes when I turn the key nothing happens, then I do it again and it starts up. Today I was driving and the truck just stalled out in the middle of the street.
I took it to my mechanic and he said he thinks it is something with the ignition, but he is not sure he recommends I take it to the dealer. However, I don't trust them and they are very expensive. What could this be?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 174 Answers
It can be either a fuel problem or electrical. Your best bet is to research the internet. Is the check engine light on? if not, then start trouble shooting the fuel system from the tank to the injectors. The other issue would be electrical. check battery connections from the battery to the starter to the coils. 2006 is near the end of poor parts that GM used, so check ignition starter. Unfortunately there is no easy answer. Check the internet to see if others had the same issue and had a solution
Posted on Dec 01, 2014
How would i check to see if my fuel pump in going out on my 2006 Chevy trailblazer? What are some of the symptoms?
If you have a way to check the fuel pressure, that's a good starting point. I'm not sure if a 2006 Trailblazer has a fuel filter or not, but if it does, you should consider replacing that to make sure that's not the cause of the symptoms. Often the symptoms of a failing fuel pump are long starter cranking times before the engine starts, or the engine won't start at all. Additionally, a cold engine may start just fine, but after driving for a bit, shutting off the engine, then starting it again within a few minutes, the engine will fail to start. The duration of the short rest would be something like running in to do some grocery shopping, etc.
Nov 21, 2016 | 2006 Chevrolet Trailblazer
2003 chevy trailblazer wont start or crank but has power to the dash
Is the anti-theft light lit on the instrument cluster ? When you turn the key to start , nothing happens ?
Oct 28, 2016 | 2003 Chevrolet TrailBlazer
Jump start trailblazer will run that day but next day it is dead there is a short some where
2006 Trailblazer won't start - Discussion on Topix
www.topix.com > Chevrolet TrailBlazer
Sep 6, 2012 - My 2006 Trailblazer will not start, bought a new battery, still will notstart, not even with a jump. ... i get a jump i drive it and charged the battery it seemed fine but then i went ... Then, next morning, when I turn key, all lights come on and radio... back a day and 360$ well that pos still will crank but will not start. 02 trailblazer a/c problem
Jul 21, 2011
2003 trailblazer key is stuck in ignition
Dec 21, 2009
2003 Chevy Trailblazer will not start
Jul 21, 2009
2002 trailblazers won't start
Aug 24, 2007
More results from www.topix.com
Oct 29, 2015 | 2005 Chevrolet TrailBlazer
2006 chevrolet trailblazer stabilitrak off message
Have you had the systems control module scanned for fault codes, to guess is just a waste on these complex systems.
Nov 06, 2013 | 2006 Chevrolet Blazer
Trailblazer wont start
check your battery might need a replacement and check also your alternator might be faulty and check electrical wiring from your battery,ignition going to your starter, check fuse and relay.
Sep 30, 2012 | 2006 Chevrolet Trailblazer
How to reset oil warning light on a chevy trailblazer ls 2006
The way to reset the oil light on your Trailblazer is.You first turn the key on but do not start the vehicle.Press the gas pedal 3 times all the way to the floor within 5 seconds.The change oil light will flash several time then go out.The oil life has been reset.Remember don`t start the vehicle just key on engine off.Hope this helps.Good luck.
Dec 09, 2011 | 2006 Chevrolet Trailblazer
My 2002 Chevy Trailblazer loses power at times. I wil be driving 60 MPH then suddenly I cant drive more than 30MPH it sounds like I have a flat tire. If I shut my car off and wait about 5 minutes it runs...
the running issue seems to be the convertor clogging up. need to have backpressure test done to see for sure. the electrical issue sounds like the ignition switch or the orange ,pink,or yellow wire going to the switch. both are common problems with the trailblazer.NOTE if the vehicle has less than 80000 miles the convertor will still be under factory warranty (EPA guidelines)
Aug 05, 2011 | 2002 Chevrolet TrailBlazer
2007 Chevy Trailblazer won't start
the ignition switch is a very common problem with these vehicles. when the problem is occuring check the pink wire coming off the ignition switch and see if there is power. the computer controls the starter on this vehicle and if there is insuficient voltage going to the ecu it will not power up.
Jul 08, 2010 | 2007 Chevrolet TrailBlazer SS
2006 Chevy Trailblazer makes THUD when accelerating
Check your coolant level, low coolant or air in your cooling system will make a "thud"noise in your heater core when the engine is under load from acceleration. The coolant rushes in to the heater core where the air pocket is trapped and then your hear the noise.
Start with the simple and make sure your coolant level is correct and then try to purge the system to remove the air out for your coolant system.
Thank you for using fixya and good luck
Jun 15, 2010 | 2006 Chevrolet Trailblazer
06 Trailblazer that will not start
Try putting the geashift in neutral when starting the truck. If it starts every time this way, your neutral safety switch or park interlock switch is broken. Let me know if this helps :)
May 06, 2009 | 2006 Chevrolet Trailblazer
SES Trims Pillar Posts Chevy Trailblazer 2002 2003 2004 2005 2006 2007 2008 2009 Logo
509 people viewed this question
Top SES Trims Computers & Internet Experts
john h
David Hoff
Andrew Taylor
Andrew Taylor
Are you a SES Trims Computer and Internet Expert? Answer questions, earn points and help others
