Question about Dynex Televison & Video
40 inch Dynex LCD no pic no sound. I get backlight and video for about 1 second approx. 5 seconds after pwr up, then black screen. Help!
    Top Expert:
  • Dynex Master
  • 75,581 Answers
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 02, 2014
Adolph
  • 137 Answers
SOURCE: Blue screen for a second after power on and then black screen again
Check where your plug go's in to your powersupply if it is well fitted. ////sometimes it dosnt make well connection then you will struggle to get it on.
Posted on Dec 22, 2007
SOURCE: Complete black screen on samsung 46 inches
Thats Samsung for you. They are designed to last just right outside the warranty then fail. Typically the LCD panels are bad, and they are the most expensive part on that Korean unit.
Posted on Oct 07, 2008
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
  • 308 Answers
SOURCE: 20" lg LCD backlight turns off after about 5 seconds of use.
First, check the power supply for the backlight. It's usually a 24 volt supply. Look for swollen caps. If that is ok, go to the inverter board and inspect for damage, ohm out the inverter transformers. Last is to test out the lamps seperately with an external inverter. If a lamp goes out this way, it is bad and causing the whole backlight to go out.
Posted on Apr 14, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: sanyo 42 inch lcd dp42647 - turns on, video audio pulse on off
Need s to be replaced the main board.
Posted on Apr 17, 2010
VIORE 32"LCD lc32vh70 Has sound but the screen turned in black
Does it turn black after about 10-15 seconds? My 40" Viore had the same problem. After trial and error, I finally fixed the problem. There is a motherboard with a cable wire coming from one end to another motherboard. 3 wires. If you remove this wire and kind of jiggle it it in, barely touching the contact points, you will see the image stay on longer than 15 seconds. You have to cut one of the wires on the board with all the inputs, VGA, HDMI, power cord, etc. I have taken pics but have not taken them out of the camera yet. If interested, post back here and I'll (hopefully) get them out. But a word of caution: my 40" inch TV motherboard may be different than your 32" inch.
Feb 08, 2014 | Televison & Video
Black screen but i do have sound
HelloCheck the backlight inverter board. If it has damged, most common fault to LCD TVs, there will be no backlight to the LCD screen, and will look black. Your tV has sound output without picture. This means that all other boards ar functioning well. Check the backlight inverter section and CCFL tubes used in backlight assembly. OK.
Dec 20, 2011 | Hisense TL1700 17 in. LCD Television
I have a Dynex 19"
Test: You might see a pic by shining a bright light against the screen. (Halogen can burn a spot if too close for too long like 15 seconds). If so, you probably have an inverter, backlight tube or coil/driver board problem. Some of thse units have a bad ground on the tube driver coil board which can be shimmed and/or tightened. Sometimes a simple car light tester (continuity tester with a 12v bulb) from casing/mount ground to any of the - side of the backlight driver coils will light the screen and reveal which tube is non functional. I leave one dome light running in such ground position one of my TVs at all times for regulation and night dimming.
Feb 07, 2011 | Dynex DX-LCD19-09 19 in. LCD TV
My dynex tv has sound but no picture it happened a day ago i found that the problem might be the backlight inverter board if so how can i fix it
Test: You might see a pic by shining a bright light against the screen. (Halogen can burn a spot if too close for too long like 15 seconds). If so, you probably have an inverter, backlight tube or coil/driver board problem. Some of these units have a bad ground on the tube driver coil board which can be shimmed and/or tightened. Sometimes a simple car light tester (continuity tester with a 12v bulb) from casing/mount ground to any of the - side of the backlight driver coils will light the screen and reveal if and which tube is non functional. I leave one dome light running in such ground position one of my TVs at all times for regulation and night dimming.
Jan 27, 2011 | Dynex DX-LCD32-09 LCD TV
I have a 26 inch Dynex LCD HDTV that the picture fails to work most of the time. On occasion it will work fine while the rest of the time there is sound with no picture only a black screen. I assume this...
Dec 27, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
While watching it, the screen went black (totally). Sound was still there but no pic. When I tried a different channel to see if it was cable or tv, it shut off. Now the green light will come on and the...
The tv have a long board call a LCD inverter board.This LCD long inverter board,it dead.This long LCD inverter board,help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
Oct 25, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
T.v.powers up, sound but no pic. t.v. is only 3 months old.
Tv have a dead long board call the LCD inverter board.This long LCD inverter board,help to get a backlight to the LCD screen panel,to produced a picture.Tv only 3 months old,take ur warrenty repair,call the Dynex corp. for warrenty repair.
Oct 16, 2010 | Dynex DX-L22-10A 22 in. LCD TV
There is a picture for about 5-10 seconds then the
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get picture back.Tries these websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | JVC LT-37X688 37 in. LCD HDTV
Dynex tv no picture screen comes on and then goes black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 18, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Televison & Video Logo
59 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
