Question about Philips Televison & Video
Philips 42PFL5432D/37 - When turned on it makes a light squeal (hum) - no picture or sound. Turns itself back off after a bit.
Turned off, unplugged for extended period.
    Top Expert:
  • Philips Master
  • 74,251 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 02, 2014
  • 132 Answers
SOURCE: Philips 42" PFP5332D/37 turns on then cuts out on pic and sound
It sounds like your High Voltage transformer is arcing.
Sometimes it can be repaired if not it is an expensive fix.
If you can see in the back of it look for sparks inside but do
not remove the rear panel, you can get zapped with 40,000 volts!
Posted on Mar 26, 2009
freetek
  • 5568 Answers
SOURCE: Philips lcd tv 42pfl5432d/37 no picture
If you feel you have isolated the problem board, you might check here for a replacement:
Jimmy's Parts
Posted on Nov 22, 2009
  • 3 Answers
SOURCE: Philips 42PFL5432D-37 black screen
A local repair shop, recommended off ShopJimmy.com, repaired ours with the exact problem for less than $250 total. Inverters were bad. The parts were $50 each at Shop Jimmy so the shop dx'd the problem and repaired it for less than $250 total! Very happy.
Trick they showed us.... turn off lights in the room and shine a flashlight down the t.v. The picture can be seen which means it's not all the horrible problems you might think.
Posted on Dec 23, 2009
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
  • 22 Answers
SOURCE: Model #42PFL5432D/37 Not receiving power? when
i was a tv engineer for many years quite a while back now and when a led is flasing or pulsing it usualy means the tv's power supply is in over current mode wherebye it shuts down to prevent any further damage due to a part of the circuitry drawing excess current, high voltage transformer etc, you need to get a techie in, sorry.
Posted on Nov 03, 2010
Philips 42pfl5432d will not turn with remote, I have to unplug power chord and plug back in and press power button to turn the tv on. sometime no picture just sound. I have to keep repeating until tv turns...
Power supply regulator board [SMPS] fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 16, 2014 | Televison & Video
Philips 42pfl5432d/37 tv chirps when power is on
Usually stems from a short on the power supply board. I have a 37MF337B/37 37" that had the same problem. Turned out the set had 5 leaky capacitors and a shorted diode on the power supply board.
Jan 10, 2013 | Philips Televison & Video
I have a Philips Model 42pfl5432d with a picture
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Dec 18, 2009 | Televison & Video
based on what you clarified and my experience I'd bet the problem is in one of the inverters, most likely the main inverter.
Look at the board part number - it's usually imprinted on the board itself - and look on eBay or Google for it.
Another way to go about it is to type in the model number (usually without /37) followed by the word "inverter", e.g. "42pfl5432d inverter".
My search yielded result board number VIT70023.80 and from there you start searching for this on eBay...find a reputable seller (like me, except I don't think I have it) and buy it.
It might be the slave inverter, it might be the master, but from what you describe it's more likely the master.
It's possible to nail it down, but it will require multimeter and some extra time.
Hope that helps!
Nov 15, 2009 | Philips Televison & Video
Red Lights on the Power button blink and picture goes dark
60PL9200D/37 When I unplug it for a while and turn it back on, the picture starts to come on, but it turns dark. And the red lights on the left and right side of the power button blink. Sound but no picture.
Feb 02, 2009 | Philips 60PP9202 60" Rear Projection...
Philips flat screen tv will not power up.
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or
not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
RCA Mode D52w19 Makes humming noise wont come on
unplug
short in tv or break....call uno who$$$$$$$$$$$$$$$$$$$$$$$we luv it
Aug 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv turns on has sound but picture
Rest the tv by unplugging it from the wall for a hour. If the picture is still gone replace the small signal board.
May 30, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Televison & Video Logo
60 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
