Question about GE PVM2070SMSS Microwave Oven
The active vent for my GE Profile microwave PVM2070SM4SS won't close. Wondering if spring placement is wrong since we took them off in hopes to replace interior halogen light. How do I trouble shoot
Replaced springs that we removed which I thing are reinstalled correctly but the vent is not closing.
MicrowaveSvc
  • 9098 Answers
SOURCE: Glass Surface Light Lens Cracks from Halogen lights use
The lights do get very hot, so they must be a sufficient distance from the lens. Was there an instruction sheet with the new lens? You may need to adjust the sockets upward. You might call a local GE-authorized servicer to see. Concerning the vent fan, this is a problem with the control panel assembly, which we repair nationwide for $39.95. Details are at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Sep 23, 2007
  • 579 Answers
SOURCE: Ge Spacemaker microwave - Model # JNM1851
They sometimes have a plastic cover over the bulb cavity that you can take off from the oven interior
Posted on Jan 02, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Spacemaker 2.0 Microwave
If it goes dead or blows the breaker or GFI when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GE xl1800 active vent bulb replacement
I think the key is pulling the vent to the left.
From page 36 of the online version of the owner's manual, which also mentions the active grille's presence on some models:
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Posted on Jan 11, 2009
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
My 3 year old ge profile microwave model pvm2070sm4ss made a buzzing noise and stopped heating. What can be the likely cause? Do you repair this in detroit? If yes, what would be the cost and need a...
Before you try getting it fixed, try unplugging it from the wall and let it sit for an hour, then plug it in and try it, the safety switch will sometimes re-set and it will go back to normal.
Mar 18, 2015 | GE Microwave Ovens
JVM2070SH02 GE profile microwave touch screen non resposive
:) Luckily, these GE touch screen models can now be affordably repaired.
Full official details on the fix are at http://www.microwavecontrol.com/jvm2070.htm.
Let me know if you have other questions.
William Edward Miller
pupista@gmail.com
August 2016
NOTE: This information applies to ALL of the General Electric touch-screen models below:
CVM2072 SERIES
CVM2072SM1SS
CVM2072SM2SS
CVM2072SM3SS
CVM2072SM4SS
JVM2070 SERIES
JVM2070BH
JVM2070CH
JVM2070SH
JVM2070SK
JVM2070WH
JVM2070BH001
JVM2070BH002
JVM2070BH01
JVM2070BH02
JVM2070CH001
JVM2070CH002
JVM2070CH01
JVM2070CH02
JVM2070SH001
JVM2070SH002
JVM2070SH01
JVM2070SH02
JVM2070SK001
JVM2070SK002
JVM2070SK01
JVM2070SK02
JVM2070WH001
JVM2070WH002
JVM2070WH01
JVM2070WH02
JVM2071BH01
JVM2071BH001
JVM2071CH01
JVM2071CH001
JVM2071SH01
JVM2071SH001
JVM2071WH01
JVM2071WH001
PVM2070 SERIES
PVM2070DMBB
PVM2070DMCC
PVM2070DMWW
PVM2070DM1BB
PVM2070DM1CC
PVM2070DM1WW
PVM2070DM2BB
PVM2070DM2CC
PVM2070DM2WW
PVM2070DM3BB
PVM2070DM3CC
PVM2070DM3WW
PVM2070DM4BB
PVM2070DM4CC
PVM2070DM4WW
PVM2070SM1SS
PVM2070SM2SS
PVM2070SM3SS
PVM2070SM4SS
These models utilize one or more of the following part numbers:
WB07X10731
WB07X10732
WB07X10733
WB07X10972
WB07X10973
WB07X10974
WB07X11113
WB07X11131
WB07X11139
WB07X11143
WB07X11192
WB07X11194
WB07X11195
WB07X11196
WB07X11302
WB07X11303
WB07X11304
WB07X11305
WB07X11306
Jun 24, 2010 | GE Microwave Ovens
Active Vent opens and closes continuously while unit is idle
I had GE look at the problem today (my microwave is less than a year old and under warranty). He replaced the cam louver and that seems to have fixed the problem. This is a small motor accessible by removing three screws and the active vent door. The whole visit was less than 15 minutes.<!-- from fixya rte -->
May 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Can this microwave be vented to the outside?
Yes, this microwave will vent either out through the top or the back. A damper will be needed if it was not saved when the unit was installed. A list of other items are listed in the installation instructions at this link To GE.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF
Nov 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I took the cover off my GE profile microwave and the vent unit that opens when the unit runs. I fixed the microwave but can't get the vent unit back on. It has 4 keyed tabs along the bottom but won't...
look where it is catching you will find it keep trying....i had a bag of a time too just relax go slow... lite.. helps(bud lite)get someone to help balance it and thumbs up
Aug 14, 2009 | GE Profile Spacemaker Over-the-Range...
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
GE PVM2070SMSS Microwave Oven Logo
65 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
