Question about 1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch
My 350 cid when cold starts as should, but once hot the starter drags like battery is dead, could this be starter, heat related, battery or connections, James
Engine has headers that are close to starter position
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 26 Answers
If these episodes run the battery down enough that a jump is required after cool down. I would say you have a bad cell in the battery. Providing that your charging the battery properly.
You can place a volt meter on the battery with the engine running to see if your charging system is working. You should get around 14 VDC and it should stay above 13 VDC when you turn things on (heater blower, headlights etc) If it's low or dropping below 13VDC you may have dirty battery connections or a bad alternator.
If your battery is holding good and you do NOT require a jump after cool down, I would say that the starter is failing, this is more common. The heat from the engine makes the starters bearings (bushings) tighter and it looses a lot of pep. But a good battery will recover from the starting attempts and function normally when the starter cools off.
It is also possible that you have BOTH problems. Where as one problems has caused the other for example,
A weak battery can cause the starter motor to pull more current causing damage to the starters armature windings over time.
OR the starter got tight and finished off an already old / borderline battery.
A good rule of thumb.....
IF your battery is 4 or more years old, you may want to start there, because the battery is near the end of its intended live anyhow. installing a new one will do one or more of the following.....
A) solve the problem
B) was preventative maintenance to keep you from being stranded in the next year or so. (that IS what old batteries do)
C) it was the least expensive and the most likely of the 2 solutions
If you decide to have the battery checked or load tested, keep in mind that they sell batteries for a living.
My story....
I had a Buick that did that with a new battery. The battery chain that sold me that battery, load tested it and said that the battery was OK.and that it MUST be the car. They didn't want to admit it was defective and give me a new one. After awhile, I got sick of having to jump it from time to time and just got a new battery at Pepboys and changed it. LIKE NIGHT AND DAY!!
Posted on Dec 01, 2014
    Master:
  • 420 Answers
That is a common problem with many cars, Yes the dielectric coating one the stater or armature coils has broken down and shorts out during expansion, cool the starter and it works, Yes it needs to be replaced
Note: most manufactured engine with the starter very near the exhaust have incorporated heat shields to help stop heat from being a problem, if your have been removed, remedy that with a new shield or tin foil for temporary measures to extend the life of your starter
Posted on Mar 26, 2015
Hard starting cold
Is cranking speed slow? Do a voltage drop test on battery cables.and a high output amp meter to test starter draw. normal ampere draw should be 250-350 amps cold and 300-375 amps hot as engine turns these readings should drop to 200-250 amps if not bad starter.
Oct 20, 2013 | Chevrolet Corvette Cars & Trucks
99 Mazda 626 2.0 changed starter 3x's. No start
Well it could be an engine problem, or a bad connection with one of the battery cables. The engine would require more voltage to crank when it is hot, but not that much.
You might want to have someone check the engine to see how much drag is has when hot, by turning the crank by hand.
Jun 10, 2013 | Cars & Trucks
Starts geat, runs good, but after driving 20 minutes and shut it off, wont turn over, like battery is dead, Battery posts unusually hot. all new parts.
Based on the information provided, it sounds like a bad starter. Even a bad starter when cold will start your car or truck. When a bad starter heats up, it requites more and more power to make it engage. If you've ruled out other possibilities, I'd consider replacing the starter.
Jun 16, 2011 | 1985 Ford F 250
When the car is hot, the starter drags, but wont start. I heard something about a heat shield ?? How can I fix this ?
An older starter will sometimes fail to turn over when hot because the armature bushing expand and are too tight for the armature to spin. At this point it is time for a new or rebuilt starter. Shielding it will not really help because it is bolted to the engine and as the engine gets hot the heat will transfer to the starter through conduction and it still will not start.
Hope this helps.
Rich
Aug 19, 2009 | 1990 Toyota Corolla
87 'C' Class motorhome powered by a ford 460 factory rebuilt motor. When cold starts with no problem. When hot acts like battery is dead. Has new battery,second new starter, ground wires new, starter &...
I had same problem in varius trucks and motorhomes with the same engine size (460)and this is caused by excesive heat from the engine in all 460's,when hot if I stoped at a gas station to fill,once I tryed to start it again it felt like the battery was almost dead and bearly turned the engine over.what I did was that I added an after market engine oil cooler and that fixed the problem.
Jun 28, 2009 | 1987 Ford Econoline
Problem starting 2004 Pontiac GTO
have you had the starter checked
Feb 10, 2009 | 2004 Pontiac GTO
Starter dragging problem
You added an extra ground but did nothing with the positive cable. It's time to replace that one, possibly using better quality cable then stock.
Nov 20, 2008 | 2004 Harley Davidson FXSTS - FXSTSI...
Nov 20, 2008 | 2003 Harley Davidson FXSTDI Softail Deuce
7.3 diesel turbor wont start
It needs to spin over at correct speed so if it is dragging causing slow turn over then yes it can cause
Oct 17, 2008 | 1996 Ford F350 Crew Cab
Starter drags-hesitates
is it shimmed correctly?
Jul 16, 2008 | 1984 Ford F 150
1995-1997 Chevy 3500 Truck Ignition Starter Alarm Switch Logo
66 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
