How can I get my Noma oil filled heater to heat up?
When I plug it in and switch it on, the light comes on and the temperature flashes on the screen and then it goes black. It is not responding to the control buttons and will not heat up. And it's cold in here!! Any suggestions ? Thanx.
  • 1,493 Answers
Yes Miss Fiona, take it back and have it replaced. It's an electronic malfunction.
Posted on Dec 01, 2014
3 Suggested Answers
SOURCE: kitchenaid dishwasher KUDS01DJ Rinse only light
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Posted on Nov 01, 2012
  • 1010 Answers
SOURCE: Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Posted on Mar 19, 2013
I have a noma oil filled heater 43-5863-4 and this year when I plugged it in oil came out I unplugged it and waited till the next day but when I plugged it in again the oil still came out in small...
I have multiple oil filled heaters similar to this and if it is leaking oil, any at all, it is dangerous and should be replaced or discarded.
These are closed systems and if there is oil leaking out, you could risk fire because there might not be enough oil covering the heating elements or other ways to catch fire.
These often go on super sale at local home stores so replacement should not be a big issue compared to the safety concern this poses. I threw mine out that had an oil leak so I speak from personal experience.
Jan 17, 2018 | Hardware & Accessories
Tip
Oil Filled Radiator Heater Leaking
<p>A very common and increasing popular source of <b>supplemental heat</b> in the last few years has been the <b>oil filled electric radiator. </b> <br /> <p>These <b>radiator heaters</b> are filled with an oil that circulates through the fins of the heater and is heated by <b>electric heating elements</b>. The result is a steady even type of heat that has a lower surface temperature then many <b>space heaters</b>, making them a great way to get <b>supplement heating</b> into a room when you have pets, small children or combustibles near by.<br /> <p><br /> <br /> <p>One of the big questions that comes up with these <b>oil filled heaters</b> is what to do if they start to leak. The answer is that if the<b> oil heater</b> starts to leak then it is no good anymore and needs to be disposed of. These<b> heaters are filled with oil</b> at the factory and then are sealed tightly. Because of this there is no need to ever <b>refill the heater with oil</b> again. The heaters are sealed with the proper oil inside for the <b>best heating efficiency. </b> <br /> <p><br /> <br /> <p>So what this means is that if you have one of these <b>oil filled radiator heaters, </b>you will never have any <b>maintenance</b> or worries about <b>adding oil to the heater</b>. But if there ever is a leak then the heater is also no good and will need to be throw out and replaced. Very few of these <b>oil filled heat units</b> ever leak, but as is always the case there are always some that do.<br /> <p><br /> <br /> <p>A word of caution about heating efficiency. Always remember that when <b>heating with electricity</b>, the <b>laws of physics</b> always apply. <b>For every 1 KW of electric you will only ever get 3415 BTU's of heat.</b><br /> <p>There is no way to get any more or any less than that, so if anyone tries to tell you that their electric heater is more efficient then the next one they are not telling the truth.<br /> <p><br /> <br /> <p><br /> <br />
on Jan 12, 2011 | Heating & Cooling
Noma oil filled heater manual model EW7507CE
Re. my problem with the NOMA EW7507CE, there is no power, no read-out, nothing. Tried different plug-ins, no evidence of power!
Jan 23, 2013 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
I have the bionaire oil heater boh2513g. I placed a towel over it to dry and I think it's went into overheating safety mode because the three lights are flashing but the appliance wont come on. Is there...
Turn the Master switch to OFF and plug the heater and leave unplugged for 30 minutes, That should give it time to reset itself. If it doesn't work after that, it's probably fried.
Mar 15, 2011 | Bionaire BH3930 Oil Filled Radiator Heater
We started getting fumes from our noma oil filled heater, what could be causing the problem?
Either something has been accidentally spilled on it or it has a slow oil leak somewhere. Also, be sure it not to close to something that may produce fumes when the heater, heats it up.
Feb 04, 2011 | Heating & Cooling
I have a Lakewood Model 750 Strip Heater and the caution light is lit. How do I get the unit working again.
chances are the thermostat has been damaged due to excessive heat or corrosion has accumulated on the connections coming from the temperature dial. it is possible to bypass this component but not advisable, if you choose to do so, please monitor the heater at all times and be sure to unplug it while not in use. replacement parts are still available.
do not attempt to service the heater while it is plugged in to an electrical outlet.
Nov 05, 2010 | Lakewood 750 Oil Filled Baseboard Heater
Pelonis heater does not heat
Hi, Have you checked to make sure that there is power at the outlet you are plugged into? I have looked up some information on this heater and it is in the top 5 oil filled heaters. I do know this, they are maintainence free. They are sealed and no place to fill will oil as the oil is heated to a certain temperature and not enough to burn the oil, so they never have to be filled. Anyway, check for power, and if you have power, check the cord over for any damage. If you can't find anything, you have a internal problem with the control on this heater. This is something you may want to take in to a appliance repair store and have checked out. There is no fuse to replace, so I would say a problem in the circuitry. There is not much for me to walk you through other then what I have mentioned, that it is getting power and cord is good. Please keep me posted.
Sincerely,
Shastalaker7
Feb 02, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
When temperature is placed on HI, very little heater comes from heater
if the fan is blowing air normally, but the heat is less! than you need to replace the heating coil of the heater. i'm sure your problem will solved................have a nice day:-)
May 13, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Heating & Cooling Logo
138 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
