Question about iLO Televison & Video
No sound on ILO TV
Bought from private owner-no remote. However, can use manual buttons. There is no sound. Have gone into Menu and checked language, checked Muted Sound and still no sound. However, when finding a station that is Spanish, there is sound! HELP! I am a single mom that bought this for my son and his family for Christmas and do not have any money to pay for service call.I am VERY good at fixing myself if someone can tell what to look at.
    Top Expert:
  • iLO Master
  • 74,211 Answers
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Dec 02, 2014
SOURCE: ILO-26HD
We had bought the extended warranty, so we took it back and got a new TV of a different brand. We had to pay the difference, but it was worth it. The warranty even carried over to the new TV.
Posted on Apr 20, 2007
SOURCE: ILO LCT27HA36 No Manual
I have a manual for a 32" same model number. How can I get a copy to you?
For the Campells' question on the remote hit the button "MTS" to get the audio you want I hope this helps you out
Lynda
p.s. I posted a question too, perhaps you all may have an answer for me too.
Posted on Jan 11, 2008
SOURCE: Remote Sensor on TV Doesn't Work and Can't Manually Adjust Menu
I just realized that there is no usb port on this tv. Called tech support at vizio since I'm still under warranty. They're sending a new remote. I know it's not the remote because neither the verizon nor the vizio remote works, although the vizio remote will intermittently work if I'm one foot away from the sensor on the tv and holding the remote on a downward angle. Tech support says they will send a new remote to rule that out before they send a tech over. I'll check the posts to see if you find a solution when I finally get the tech guy out here. If not, I'll let you know what he does.
Good luck.
Posted on Aug 13, 2008
SOURCE: Need owners manual
Have ilo32hd no manual...can't get into menu
Posted on Feb 03, 2009
Rick Racer
  • 5 Answers
SOURCE: TV remote codes
press menu and go to settings. select remote, code search and follow the on screen instructions it may take a few minutes to locate the correct code but it is in there.
the installer told us that the remote could not be programed to our ILO tv, he was wrong I made it happen without any trouble.
Posted on May 03, 2009
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
ILO TV REMOTE CONTROL MISSING
Go to this webpage.
Here you can buy the original remote contol for your TV
http://www.remotes-express.com/Ilo/ILO2600.html
Jan 12, 2008 | iLO 2600 Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
It's unlikely that a setting you changed in the user menu would have locked out both the remote and the panel.
It sounds to me like the micro has gone bad. One other option, is a stuck or damaged button assembly. Corrosion on the button board can lock the micro.
Nov 22, 2007 | iLO 3200 32 in. LCD Television
Need remote codes
You may be able to get help here. This is a link for the owners manual in PDF.
Hope this helps!
http://dukeelectronic.com/Manual/IWT3206.pdf
May 30, 2009 | iLO IWT3206 TV
Ilo tv remote only displays menu
Check all the buttons on the TV and see if they all feel the same. Some times a stuck button can cause the problem
Mar 24, 2009 | iLO V27DMBX Television
My tv is in spanish
The only remote I was able to find that work all Ilo features is the GE universal remote #24914 works to change your Ilo tv from analog to digital and switch to vid1 or vid2 ect.... The code is in the book that comes with the remote. I use this remote myself. This remote can be bought at Target for under $10. This remote will let you get it back to english. You should also be able to do it from the menu button on your tv.
Mar 11, 2009 | iLO IWT3206 TV
I just bought a wirelss headset for my ilo Tv and there is no audio outlet on this TV. Is it called something else/or how can I hook this up.
Oct 15, 2007 | iLO LCT32HA36 Television
ILO-26HD
take your tv back to the supplier you bought it from let them rectify the problem.i suppose that your tv is still under warranty.good luck.
Apr 19, 2007 | iLO 2600 Television
I recently bought an ILO 32 HDTV with the same problem. I searched every site I could find for a solution. I finally found someone that gave me the direction to replace the Main Board for the TV. This is the board that you can plug your exteranl devices into, computer, dvd, HDMI etc.
The phone # to Digital Age is 909-974-2859. These are the people who can send you the part you need. Also the remote that I have is RC-500, which is the newest remote control for the new Main Board. I would suggest getting this remote.
The price of the board was $123.89 with $10.00 shipping. It only took 4 days to get the board from Ontario California, and yes they do speak english.
I removed the backpanel myself and then removed the metal cover over the Main Board. Remember to mark all of your wires and screws so you can put them back in the same location. The connections are all quick disconnects and the board is one piece. I had the board replaced and the back panel back on within an hour. All buttons working on the TV and the remote control, and the TV is working great with sound.
But I do not have the Manual......does anyone have the manual? I am willing to help anyone with a fix for their TV for a copy of the TV Manual.
I hope the information I have given helps in anyway possible,
Johnny
Aug 08, 2006 | iLO 3200 32 in. LCD Television
Televison & Video Logo
106 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Jaime Hernandez
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
