Question about Gemini Sound Products Gemini Cdj-210 Tabletop Scratch Mp3/cd Player
What,s the problem when a CD is stuck inside after it stopped reading the disc and jammed on Gemini CDJ 210 and you can't eject it?
When i switch it off it only eject the disc then,that's the only way of getting it out!!!!
Fostex LR-16 has locked up!
Does it come up with DRIVE INIT or does it go straight to please wait???
I had a problem like this when i didnt eject the media properly from my PC. It would not turn off and just said please wait..... until finally i switched it off waited 5mins then turned it back on. If you can get your PC/MAC to see the drive you should delet the file you uploaded. Did you put the stereo file in the "2mix" folder of directly into the project folder?? To be honest The Fostex LR16 is a pain in the ****!!!
Apr 25, 2012 | Fostex LIVE DIGI MIXER 16-TRK HD RECORDER...
Numark CD DJ IN A BOX w/2-NDX200s/M1a/HEADPHN - NUCDDJINABOX ONE OF THE CD WONT EJECT
Was it working at first, and it just stopped? Try unhooking everything and just isolate the one cdj and plug it in see if it will eject. If its Brand New and this just started happening my sugguestion is to take it back to the store. you get what you pay for and numarks whole dj in a box line is the bottom line stuff.
Jun 14, 2011 | Numark Industries Numark CD DJ In A Box...
Numark KMX02 left hand CD will not eject
Usual cause is a little rubber belt either deteriorated or is slipping that drives the carriage to do the eject. Open unit and recover the CD and the drive belt will be obvious...
Apr 14, 2011 | Numark Industries Numark KMX02 Dual Deck...
Hi my mixer on the right hand side doesn't work, it keeps telling me that its an error and wont eject the disc that it has in it.
Some of the failures to eject a disk problems are due to failure or slipping of a little drive belt that moves the carriage out. Also sometimes the alignment is bad and the disk hits the front escutcheon.
Mar 15, 2011 | Music
I get disc error when inserting a disc into my Denon DN S700
Are you using the correct format of discs? It requires Standard compact disc (12 cm), types CD-TEXT, CD-R, CD-RW (CD-R and CD-RW disks must be finalised before using - but even then will not always be accepted) It will not work with CD+R or CD+RW
If it will not work with ANY CD (including professionally produced CDs) then the lens may need cleaning. Purchase a CD cleaning disk (a computer CD cleaning disk will work fine) pop it in the slot and hit the play button.
You can download the manual here http://www.denondj.com/Assets/Dimages/Products/Manuals/ab8715a8c0d742f0ab8c9afed5bf90e0.pdf?ts=012725
Feb 08, 2011 | Denon DJ DN-S700 Compact Tabletop CD/MP3...
Hi. How do I fix a CD deck that wont open if I press eject? The deck refused to open with a CD inside. The deck wont play the CD if I press play and wont eject if I press eject. please help. Thanx TC
To retrieve the CD safely, the safest way is to open the unit. A common problem is that a tiny belt from a motor that drives the eject deteriorates and slips so there isn't sufficient drive to move the mechanism. The unit is probably in a mode expecting to eject and has commanded the motor but it doesn't complete... Do as I say and open the unit to do the retrieval. Then get unit serviced.
Dec 04, 2010 | Gemini Sound Products Gemini CDM-3700G /...
Keeps switching off and showing tocread on display
That probably means it can't read the "Table Of Contents" which is essentially the directory of the disc.
MAKE SURE any disc you try to read has been "finalized".
Any disc that you have burned that can have stuff added is NOT finalized and may not work in certain CD players.
May 08, 2010 | Tascam CD Gt1mkii CD Guitar Trainer
You have to tilt it to get cds out, and even that dont worksometimes
The ejection mechanism must have a problem. I would take it in for servicing as eventually further damage could be done or a CD damaged.
Feb 09, 2010 | Stanton C314 Tabletop CD and Mp3 Player
My stanton c324 after i put a dics in it reads "no disc" what happend to it and how can i get it fixed?
Had same issue with mine, talking with retailer it seems to be a common problem. I am in New Zealand and have been waiting 2 months for parts to arrive. Something wrong with laser and servo. Good luck getting yours fixed.
Oct 28, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Cd wont eject
Obviously it's the thickness of your labels. Use printable cd's or just get a cd pen and print on the cd.
Good Luck
Aug 29, 2009 | Stanton C314 Tabletop CD and Mp3 Player
Gemini Sound Products Gemini Cdj-210 Tabletop Scratch Mp3/cd Player Logo
21 people viewed this question
Top Gemini Sound Products Music Experts
Vito Vacirca Jr.
Colin Stickland
Colin Stickland
D. E. Hev
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
