Does model ps19t still exist? If not what is the replacement power star unit?
    Problem Solver:
  • 19 Answers
The PowerStar AE115 unit replaces the PS19T model which has been discontinued.
Posted on Dec 01, 2014
I have a Hitachi Star Board Model: FX-E90W and it won't power up. Is there a wiring diagram/schematic to check connection and conductivity.
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Hitachi Office Equipment & Supplies
Tip
Star Trac 4000 Treadmill Deck Bushing Replacement
Replacing a Deck Bushing or Deck Stop Delrin Rod on a Star Trac 4000 TreadmillTools Needed: Phillips Screwdriver, Pliers (optional). Tools needed may vary depending on your hardware.
  1. Switch the power off on the unit.
  2. Next, unplug the unit from the wall.
  3. Loosen and remove the old deck bushings.
  4. Stubborn deck bushings can be removed with the assistance of pliers, once the screws have been loosened completely.
  5. Install the new deck bushings. (Check with mfr. for proper torque during install process.)
  6. Now, plug in and power on the unit.
Video of Replacing the Deck Bushing on Star Trac 4000 Treadmill
on Feb 11, 2015 | Star trac Exercise & Fitness
Plotter hp designjet t 1100 tiene una falla 47:01
Suggestible for tech guys: Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf its look like difficulty, replace star wheel unit..
Jun 16, 2011 | HP Designjet T1100ps Printer
Opa boa tarde tenho um T610 que apresenta este erro Designjet T610 47:01
Apr 19, 2011 | HP Designjet T1100ps Printer
A local contractor is selling a new PS19T. Why was it discontinued? I'm looking to heat my workshop infloor heat system. should I be wary?? thanks for any help. jeff
This model is known to have problems with its Thermal Cutout this regulates the maximum water temp and can cause the unit to overheat when it does not shut off the heat source. In some residences low water flow and or a obstruction (common if you have well water) in the filtration and water treatment system can cause the same problem. Basically the unit can have overheating problems and the heat exchange coils are be prone the effects of hard water (if that applies to your water supply) and can lead to future service of descaling the units coil/coils (can be expensive). Buying any used unit with many mechanical parts and other components always have the potential to have problems new so i would not recommend a used unit of this type.
Also, This unit is limited due to the fact that the unit require­­­ incoming water to be cold and you cant use any sources of pre heated water (many people are starting to utilize alternative energies such as solar water heaters, wood boilers, and other relatively free or low cost). For example, using recovered heat from a boiler or indirect hot water tank or other to reduce the energy (cost) by raising the systems initial water temperature.
Are you heating a concrete floor with radiant heating? if so it would be far more cost effective to use either a loop off your existing system (a new zone) or you could add a oil fired or LP (gas) fired water heater and utilize the efficiency of a separate system and the fact that a hot water heater stores and super insulates the water it heats.
if you have any questions please feel free to let me know
Feb 06, 2011 | Bosch PowerStar AE115 Tankless Water...
Desingjet T770 44 Pouces Hard Drive - The Code error on front panel is 47:01 (?) Thank you (I'm french and im not speak english, sorry)
Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf you feel this difficulty work just replace star wheel unit..
Jan 25, 2011 | HP Designjet T1100ps Printer
Boa tarde Tenho uma plotter t1110, quando ligada ele demora a carregar e quando carrega, da um erro 47:01 e pede para entrar em contrato com o support da HP
Star wheel motor faulty,( to remove star wheel unit open left cover,formatter,power module,spitton)Normally most of the cases motor wont go gear unit pensions breakage observed mostly, replace star wheel motor unit or if you are tech guy you can make alteration see the snap shot how pinion got breakage..Find out metal pinion suitable for the same and fix it properly. 11_19_2011_4_07_20_am.jpg11_19_2011_4_07_49_am.jpg11_19_2011_4_08_22_am.jpgIf you feel this horrible work just replace star wheel unit..
Jan 12, 2011 | HP Designjet T1100ps Printer
I have a HP Designjet T1100ps Plotter. Front panel shows messgae as below 47:01 Restart the printer. If the problem persists, Call HP Support.
Dec 15, 2010 | HP Designjet T1100ps Printer
Our PowerStar PS19T tankless water heater
The PowerStar AE115 unit replaces the PS19T model which has been discontinued. Now's the time to upgrade...
Nov 08, 2009 | Bosch PowerStar AE115 Tankless Water...
Star SP 2000 Printer
Make sure the dip switches are set identical on each printer. Use your old printer as the example They are located at the bottom of the printer near where the interface cable plugs into the printer.
Oct 29, 2008 | Star Micronics SP 2000 Matrix Printer
jasbo
jasbo
