Question about Sewing Machines
How do I fix my bobbin winder?
Took off top to clean and oil, put top back on and bobbin winder does not work.
  • Sewing Machines Master
  • 626 Answers
1. Take the top off.
2. Check to see if the bobbin winder has pressure as you move it back and forth. There should be. If not then check for a spring connected to the bobbin and reset it. There will be some kind of post to hook it to.
3. Place the bobbin winder in the "off" position and put the top lid back on.
4. Without putting the screws back in move the bobbin winder to the "on" position and to the "off" position.
5. There should be pressure either way you move the winder.
6. Loosen the hand wheel handle.
7 With the bobbin winder in the "go" position use your foot pedal to make sure it revolves.
8. Replace the top.
Posted on Dec 02, 2014
  • 14 Answers
SOURCE: bobbin doesn't fill in bobbin winder
The bobbin winder question is a frequent one and it is very easy to solve. If you look at the shaft where the bobbin sits on the bobbin winder, you will notice that it has a slot in the middle of the shaft, an opening if you will. This is where you use a flat screw driver and open that space more to give more friction to the bobbin so it is not loose on the shaft. That slot was made for that. There are different bobbins on the market so thats why the slot is there. If it is too tight, grab a pair of pliers and close the gap. The metal of the bobbin winder on that shaft is malleable exactly for this reason. No need to put plastic bag material or anything like that. Use it as it was intended for.
Posted on Jul 08, 2008
SewTechWayne
  • 186 Answers
SOURCE: Bobbin winder won't spin
The two most common problems are that you either need a new bobbin tire, or just need to adjust the position of the winder a little closer to the hand wheel. Remove the top cover and you will see the winder assembly. Loosen the two screws that hold the assembly nudge it closer to the hand wheel side. If you move it too far the winder will constantly spin. Also, examine the rubber tire, it may have a flat spot on it in which case it needs to be replaced. If it is worn out you may not be able to tell just by looking at it.
These winders can be tricky to adjust but why not try?
Posted on Feb 06, 2009
SOURCE: putting the bobbin housing back together
Found your problem while I was trying to solve mine. I can solve yours. Here is the page from my manual about how to remove/replace bobbin housing. I hope you can make this image larger so you can see it clearly. We're limited as to the size of the file we can upload.
Posted on Apr 13, 2009
bargainbox
  • 1388 Answers
SOURCE: bobbin spindle won't spin
Check the bobbin winder rubber, it may be worn or broken and insufficient friction against handwheel to turn.........or a thread jam around spindle is stopping the spin. In this case, carefully unwind, DO NOT cut thread.
Posted on Sep 01, 2009
SOURCE: i have been given a
HI Vera,
I just picked up a 4613 and had the same confusion. The answer is...the bobbin winder is built in!! What you do is leave the machine threaded as normal and simply slide open the bobbin cover about an inch. You will see an arrow on the cover which you line up with an arrow on the machine bed. In this position, push the presser foot and run the machine and the bobbin will wind itself. It's actually really nice as you don't ever need to unthread the machine.
Posted on Sep 25, 2011
I have followed all instruction to take apart machine but dont know which screw releases bobbin winder so that I can replace O rig
Most O-Ring on Bobbin Winders can be changed without dismantling them. If you can get your fingers on the O-Ring, just
(1) Pry off the old O-Ring, usually does not even need a tool. (2) Clean the O-Ring Pulley, (3) Oil the Bushing (4) Wipe of any excess oil off the Bobbin Winder, you do not want oil on the rubber O-Ring, oil will make it slip, get soft and spongy and disintegrate faster). (5) Pop-On the new O-Ring. All this is very easy if the Bobbin-Winder is External, but if it is under the lid (internal), it works about the same, I seldom have to take the Winder out to replace the O-Ring.
Alternative: (a) Pack Kleenex around the O-Ring, to keep and dust from getting into your machine, then (b) Gently scrape or sand the O-Ring a bit, to get any glaze off the surface; even a 3-M Green Scratchy Scrub pot-cleaner will do fine. (c) Clean with Alcohol and dry leaving no dust or paper parts (no finger prints either, fingers leave grease residue). [ if you can find "Rubber Rejuvenater" a pro product, it would be great, now that is not "Belt Dressing", which is a little too much for a O-Ring, since it may gum things up a bit too much (but it may work in some cases)] (d) Put it back like it was supposed to be. (e) Adjust the "Bobbin-Full" indicator so it kicks the Bobbin out of gear (stops winding the Bobbin) when it is just about full. This done, congratulations, you are in business again.
Sincerely,
-- Amender (2016 FEB 23)
Feb 05, 2016 | Brother Sewing Machines
Bobbin rewinder won't work
it's possible that there is a part inside the machine that could be broken, it would be a good idea to have the machine checked.
Jun 23, 2013 | Kenmore Sewing Machines
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
I have xl-2600 model bobbin winding not working what to do
If the winder is on the top of the machine and it is not turning it is either a flat spot on the winder rubber, or the winder has seized, the best way to fix it if it has seized it to put a drop of WD40 on the winder spindle so the oil seeps down, not too much though, place an electric drill over the spindle of the winder and switch on slowly and it should free off
Aug 06, 2011 | Brother Sewing Machines
My machine will not thread any bobbins.
Your bobbin winder has seized. Remove the top cover and oil the area where the bobbin winder shaft goes through the bobbin winder assembly. You might need to force the winder to turn with your fingers for a while, but it will begin to turn smoothly once the oil gets in there.
If the black bobbin winder tire has a flat spot worn into it, you will need a new bobbin winder tire. Costs around a dollar.
Apr 07, 2010 | New Home L-372 Mechanical Sewing Machine
I have a singer inspiration 4228. When I tried to
If you have pushed the winder over and it is not turning either the winder rubber has worn down one side, or there is residue on the winder rubber, or the bwinder has seized through lack of oil which is quite common, with the winder in the off position see if you can spin it by hand, if you can't then chances are it has seized, put some WD40 oil on the top of the spindle and leave it overnight, then put an electric drill over the top of the spindle and switch on slowly, that usually works.
Mar 05, 2010 | Kenmore 11101 Mechanical Sewing Machine
I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Feb 24, 2010 | Singer Sewing Machines
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Bobbin winder shaft won't spin. LCD says bobbin winding.
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Sears Kenmore Sewing Machine Model 385. 1254180 Bobbin Won't Wind
The winding sound is the rubber O-ring against the spinning pulley (back of hand wheel) - do not let this continue, it will wear out the O-ring.
I had the same problem and I found the shaft bushing of the winder dry and needed lubed. Use oil or spray lithium grease and it should work fine. Spin the bobbin shaft by hand (not the hand wheel) to get it freed up after oiling.
You can oil from the top and should take off the side case to clean the excess oil from the O-ring. The shaft bushing is a tight fit and any dry oil will get sticky and prevent winding.
Jan 22, 2009 | Kenmore Sewing Machines
Sewing Machines Logo
385 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
