Question about AOL Instant Messenger
Change Expessions image (won't allow now)
I presently have the fall image and want to change it to a winter image and it won't allow me to change. Help!
  • Colleen Parrish
    Colleen Parrish Dec 01, 2014
    Hi Helen Orr, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Are you getting an error message?
    New Friend:
    Problem Solver:
  • 7 Answers
Go to settings then display then wallpaper and save
Posted on Dec 03, 2014
Change clock in ferrari california
this is a load of rubbish
Jan 27, 2015 | Home
Transporter turns over but won't catch
the fuel is proberly stale drain tank and replace
hope this helps
John
Jun 15, 2013 | Volkswagen Transporter Cars & Trucks
Ano ang power point
PowerPoint is a presentation program developed by Microsoft. It is included in the standard Office suite along with Microsoft Word and Excel. The software allows users to create anything from basic slide shows to complex presentations.
PowerPoint is often used to create business presentations, but can also be used for educational or informal purposes. The presentations are comprised of slides, which may contain text, images, and other media, such as audio clips and movies. Sound effects and animated transitions can also be included to add extra appeal to the presentation. However, overusing sound effects and transitions will probably do more to annoy your audience than draw their attention. (Yes, we have all heard the car screeching noise enough times for one lifetime.)
Most PowerPoint presentations are created from a template, which includes a background color or image, a standard font, and a choice of several slide layouts. Changes to the template can be saved to a "master slide," which stores the main slide theme used in the presentation. When changes are made to the master slide, such as choosing a new background image, the changes are propagated to all the other slides. This keeps a uniform look among all the slides in the presentation.
When presenting a PowerPoint presentation, the presenter may choose to have the slides change at preset intervals or may decide to control the flow manually. This can be done using the mouse, keyboard, or a remote control. The flow of the presentation can be further customized by having slides load completely or one bullet at a time. For example, if the presenter has several bullet points on a page, he might have individual points appear when he clicks the mouse. This allows more interactivity with the audience and brings greater focus to each point.
PowerPoint presentations can be created and viewed using Microsoft PowerPoint. They can also be imported and exported with Apple Keynote, Apple's presentation program for the Macintosh platform. Since most people prefer not to watch presentations on a laptop, PowerPoint presentations are often displayed using a projector. Therefore, if you are preparing a PowerPoint presentation for a room full of people, just make sure you have the correct video adapter.
Jul 12, 2011 | Microsoft Computers & Internet
I have a 1998 Honda Valkyrie F6. After taking it out of storage for the winter I cleaned it up changed oil and filter. I pushed it outside to let it warm up. Got on it went to pull the clutch and no...
That is normal and common, over the winter besides temperatures go up and down , most importantly BR pressure goes up and down like a air plane as different storms and weather conditions change,even in controlled storage can change unless it is in a 100 percent controlled room. This lack if that, can cause air bubbles to form in lines. Just bleed line and go for a ride and be safe. Mike
Jun 02, 2011 | 1998 Honda F6 C Valkyrie
Winterizing motor
Winterizing generally consists of draining the fresh water from the engine block and/or refilling with RV type antifreeze (propylene glycol) and disconnecting and removing the battery for inside storage and maintenance charging. Theories vary on whether it is better to change the engine and outdrive oil in the Fall or the Spring.
Sep 20, 2010 | Boating
When i hit change display image it does not change the image
try to remount again the path of the image you want to display to override the present image displayed.
thanks
Aug 03, 2009 | Microsoft Windows Vista Home Basic Edition
Mac desktop image wont change
on the main drive there is a folder called "Library" in that folder should be another folder called "Desktop Pictures" I suggest checking that folder to make sure the images are present. Also try checking permissions using "Disk Utility" located in "Applications" --->"Utilities Folder" select the main disk in the list on the left and select repair permissions. As a last ditch effort you can reinstall the base system and then restore to time machine as time machine will not restore system components
Apr 19, 2009 | Apple Computers & Internet
Oil change
When storing for winter oil should be changed before so as to remove contaminates (certainly would not hurt to change-falls under the category of severe usage), then you don't have to worry in spring when you pull your bike out. Hope you drained the carbs and kept the battery charged or you could be looking at spending more money.
Nov 10, 2008 | 1985 Yamaha FZ 750 FT (U.S.)
AOL Instant Messenger Logo
50 people viewed this question
Top AOL Computers & Internet Experts
ray gallant
Paul Chana
Bonded Repair
Are you an AOL Computer and Internet Expert? Answer questions, earn points and help others
