Question about Ovens
I have a GE 24 inch wall oven model number JRS04B0W5BB that when bake is selected the broiler element comes on and then after awhile it looses temp and does not cook anything.
  • 69 Answers
Ovens often use broiler element to preheat, then shut off when set temp is reached. Check fuses for and bake element itself.
Posted on Dec 01, 2014
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Sep 27, 2014 | Frigidaire 24" Single Gas Wall Oven with...
I have a GE oven that the oven part only doesnt come on, the top burners and broiler come on, is this something I can fix?
Most likely a bad bake element. Turn off the power to the range. Remove the oven racks. Remove the retaining screws holding the bake element to the rear wall. Carefully pull the element terminals out of the rear wall. CAREFUL now,the wires will be short. Remove the wires. If you have a volt ohm meter you can test the element for continuity. Set the meter for ohms or continuity and touch one meter lead each to the element terminals. If you get no reading replace the element with a new one. If you do get a reading your ERC clock is bad.
Nov 08, 2009 | GE JKS05 Electric Single Oven
I have a GE Single Wall electric oven.(JTP25SOH2) The heating elements just stop getting hot. unit is about 4 years old purchased brand new. first the broiler stop getting hot then the baking heating...
First your broiler heating element may have gone bad and now you oven heating element may have gone bad. Using an OHM meter disconnect them and test for their value.Full scale on the meter means it is shorted. No meter movement means that it is open.Eitehr means to obtain a new element(s) and replace it/them.
Jun 11, 2009 | Ovens
Broiler element comes on when "bake" is pressed
does the bake element come on at all?
if so, try the oven out. do a bake @ 350 allow it to pre-heat, and see if once the pre-heat is comlete, id the broil shuts off.
on many ovens at the beginning of the cycle during pre-heat both bake and broil elements are powered.
other than that it may be a control board, or a burnt and crossed wire in the harness.
May 28, 2009 | GE JTP15 Electric Single Oven
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
GE Model JKP12G0P2BG Wall Oven Bake Element Not Working Properly
The temperature sensor is bad. The broil element will work even if the temp sensor is bad but the bake element will not. If you measure the resistance across the contacts on the sensor, it should be around 20 ohms, if it is much higher (1000+), then it is bad and should be replaced. It is just as easy to replace as the elements and looks like a small pencil sized rod in the inside top of the oven. Let me know how this works out for you.
Benjamin
Nov 19, 2008 | GE JGRP17 Gas Single Oven
Bottom /bake element will not come on
Check the connections to the element. If power is going to the element, and it is not working, the element needs to be replaced
Jul 21, 2008 | GE JKP15 Electric Single Oven
Jenn Air wall oven-Broiler element comes on and will not turn off....
Boone, by the sound of your post it sounds like the power relay board could be bad. If you had a stuck or shorted keypad, you should be getting a different code. The F2 code means an overheated condition. If it's a double oven it could mean a secondary board failure. The way to go on this would be to ohm out the temp sensor first. Should read about 1100 ohms at room temp. Another way to check it is to swap the bake and broil wires on the power relay board. They will be marked BA and BR. Fire the oven up again and if the bake element comes on then you know that the broil relay is stuck or shorted. Without being there to do the tests, I believe that the problem lies in the power relay board. The part number for the board is 71003431. Priced around 116.00. Jenn-Air usually has a 5 year warranty on these parts. Hope this points you in the right direction. Catriver..post back
Apr 10, 2007 | Jenn-Air JJW8527C Expressions Collection...
Ovens Logo
177 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
