Question about Kenmore Washing Machines
My dryer is a kenmore elite HE3 model number DADT-ELE-2406024-EL54 and is making a loud noise at the bottom in from
I took the front off and the large fan thing in front has pieces broken off? how do i fix it?
    Top Expert:
  • Kenmore Master
  • 14,162 Answers
Posted on Dec 01, 2014
aborcass
  • 2651 Answers
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Posted on Mar 10, 2008
SOURCE: knocking noise
Your problem may not be a broken spider assembly. My Kenmore Elite (model # 110-42822-203) had a kocking problem as well. After taking the back off, I discovered that the nut holding the pulley to the drum shaft (on the outside of the outer basket) was slightly loose. I simply re-tightened this an the knock went away. The pulley was shifting on the shaft ever so slightly, leading to the knock. Cost of fix: $0. :-).
Posted on Apr 05, 2009
  • 6 Answers
SOURCE: Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Posted on Jan 19, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Kenmore Elite HE3 Model 42822 has a leak at the rubber bellow. Do I have to remove the front panel to replace the bellow or just the bottom panel and the spring outside the bellow.
A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
Step 6--Removing the door. After you remove the three screws in Step 5, there is only one screw to remove in step 6 on my model. It was hidden behind a plastic cover that makes the hinge look pretty. You'll see on the inside of the door that two plastic prongs/tabs extend into holes in the hinge. If you push on them laterally and pull out, the tabs will pop out. Outside the door on the left side of the machine, you'll see the plastic cover that is connected to those plastic tabs and is hiding the hinge. On the outside cover piece, there is a flat tab that extends up into the plastic housing above it. If you gently pull the cover downward and out the whole plastic cover will come off revealing the one screw that needs to be removed to take the door off.
Step 7--Removing the Kick Panel. The middle screw is more difficult to reach than the sides. You may need an extension for your screwdriver and/or shims or a helper to prop up the washer while you remove the middle screw.
Step 8--Removing the washer casing. The step says to remove the screws and set the casing aside. My model (2005-ish) has wires connected to it. Rather than being able to remove it, it swings open like a door with the wires as the hinge. I simply used a box to prop up the outside part of the door so it did not sag and stress the wires.
Step 9--After you remove the old rubber bellow, you will likely see a lot of dirt, mold, and junk where the bellow was. Clean that stuff off with a cloth sprayed with a gentle cleanser before installing the new bellow. We replaced our bellow because of mold and mildew and bad smelling stuff. That dirt and junk is part of the problem. Clean it up before you install the new clean bellow.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: I would like to purchase a Kenmore elite steam
Sorry to read about your problem, I hope this helps you out.
In my modest humble opinion, run as fast as you can and stay away from them. you are better off with a rock, at the river
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Dec 29, 2010
Testimonial: "Very helpfull thank you"
The clothing do not toss around the drum and the clothes come out in clumps and wrinkled
You may be over stuffing. Try smaller loads and see if you have better results. Too much stuff in the dryer means that your clothes will have less room to move around, and if they're all crumpled up in the machine, they'll come out, well, crumpled-up-looking.
Jun 13, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
My kenmore elite he3 quit working model number DADT-ELE-2406024-EL54 do you know why?
The heating coil safety switch/fuse may have been activated if it got too hot in there. It is very common for escaped lint to finally build up where it should not be. The first thing is to learn how to remove the front of the machine and inspect for a build up of lint. Happens often over time.
Nov 05, 2014 | Kenmore Dryers
I have a Kenmore HE3 front load dryer number DADT-ELE-2406024-EL54 saying F01 and won't turn on. I cleaned the lint from hose and still nothing. Is there something else I can try before calling a tech
I don't have a specific answer for you, but I'm heading a lot of reports about the new electronic washers and dryers. It seems they are very touchy. If I had one, I would be sure to use a surge protector to protect the circuit board.
Apr 17, 2014 | Dryers
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
I have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he3 dryer
Some coins or other objects may have fallen down in to the blower housing. Unplug the dryer. The Front lower cover has 2 screws holding the outer panel on. There are several screws in the blower housing.
Aug 12, 2008 | Kenmore Elite HE4 Electric Dryer
Washing Machines Logo
50 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
