Question about E-Machines -T1840-CELERON-1.8GHz,40GB Desktop Computer System (1000000127)
No sound I had sound now it says I have no connection-how do I get the hard drive for sound
  • 121 Answers
Give more details plz...
Posted on Nov 11, 2007
No sounds but speaker is connected
Make sure that your sound driver install correctly.and check whether your logo present on your bottom bar.
recovering data from hard drive
Hard Drive Recovery Maidenhead Hard Drive Recovery Services Hard Drive Recovery Maidenhead Hard Drive Recovery Services
Feb 02, 2014 | Acer Aspire M3710
My WD element extrenal hard drive won't open. i can see it in my devices, and the blue light stays on. it also makes the sound saying it's connected but I can't see the device in my comput
First thing, try to change the cable, try a different one, then if it does not work, try to connect the hard drive on another computer, and changing cables as well. This will help you to narrow down the problem to find out exactly what the matter is. If the Hard drive spins properly and it does not produce any click-click sound then it is fine. If all the above fail, then you have to slave the hard drive using its internal SATA connection. You have to open up the hard drive and remove the pin that connects the hard drive to the cable. This will enable you to see the SATA connection. Slave the Hard drive on a desktop computer and see if you can gain access to it. If you can, then consider replacing both the cable and the pin that connects the cable to the hard drive. If your hard drive just spins and you can not access it while its a slave to another computer, then the hard drive has a problem.... Try the methods above, i believe your hard drive did not go this bad...
Mar 26, 2012 | Western Digital Elements powered by WD 320...
Most likely, hard drive failure.
If a portable, re-seat the drive, then reset the bios defaults, and see if the hard drive is detected.
If a desktop/Tower, re-seat the cable connections to the drive and the motherboard, reset the bios and see if the drive is detected.
If the "Noise" from the drive is a grinding sound, a repeating Click, or a laser sound similiar to a star wars movie then almost guaranteed drive failure.
Jul 31, 2011 | Samsung (SP0822N) 80 GB Hard Drive
My computer does not recognize my external hard drive when I connect the usb
HI rvcruz. I've solved a few problems like this. Connect your hard drive. do you hear the "tutin" sound when you connect USB devices? If you don't, that means you have a problem with your hard drive. Either the case is bad so you just remove the hard drive from the casing and put in on another one (it could be any extrenal case for hard drives.. as long it has the same interface - SATA or IDE). If you do hear the "tutin"sound, go to Start - right click on MY computer and click on "Manage". Then go to "Disk Administration" above "services and applications" and verify if you see your hard drive. Probably you have to initialize the disk or Assign a letter by right clicking on it. But first try removing the hard drive and connect it to another computer WITHOUT the case to make sure it's not the hard drive. I hope this helps and don't forget to rate and give positive feedback for our free support today. Thank you :D
Apr 29, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
When I try to connect the harddriveto the PC it
Can be quite a few causes. Have a look at this article on troubleshooting external hard disk problems, maybe it has a fix for you.
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
External hard drive wont connect
There may be a problem with the hard drive now. Please see a licensed computer technician from the company you have boughten the hard drive from.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 02, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My hard drive is making wheezing sounds and won't connect to mypc
It looks like physically your disk is damaged. You have to consulte service center for data recovery. Keep hardisk either horizondally or veritically and try
Oct 13, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
I have a lacie design by F.A. Porsche 250Gig Hard drive - It has failed and is making a buzzing sound follwed by a beep - is this repairable?
Sounds like the hard drive in the Lacie has fauled.
To test the hard drive, remove it and connect it to an USB hard drive adapter and connect it to a working computer's USB port. If it deosn't detect it as an external drive and you connot open folders and files then it is faulty.
You can install a new hard drive in the Lacie and then format in FAT32.
Sep 10, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
My Gateway used computer was working and now it won't boot-up and gives message that Hard drive connection is not good. The computer makes clicking or more of a tapping sound and now won't boot. thanks
It sounds like your hard drive has failed, IE.. the clicking/tapping sound. You could have the hard drive tested to be sure. You could swap out the hard drive to another machine and try it.
Jul 29, 2009 | Hitachi hts548080m9at00 80 GB Hard Drive
I have LaCie 500 GB Exernal Hard Drive. I was transferring some data from my computer into the hard drive. The hard drive fell off and stopped working. When i connect it to power, the power light doesn't...
Sounds like the power supply in the external case has gone bad (or going bad)...
If you have another external case, AND the drive itself is not damaged, you can move the drive to an external case.. Alternately, depending on the connection (IDE/SATA) you can move the drive internally to your computer.
Jul 20, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Computers & Internet Logo
19 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
