Question about Kenmore Kitchen Ranges
Why does the terminal block keep melting on my kenmore range left front burner.
When it first acted up I took out the element and found the terminal block melted, so I replaced it. A few months later it melted again, so I replaced it again along with the surface element. Later it melted again so I replaced the element control switch and the terminal block., and once again it melted the terminal block. Can you help before I get rid of it once and for all.
  • 1,171 Answers
Brother Jeff, this happens all the time because the connections are not perfect, causing arcing at the point around the connection. This arcing makes for excessive heat and melts the block. I replaced the connections on my Mothers stove top with crimped connectors and it lasted a lot longer. They didn't burn out any more, she just needs a new stove. So your best bet is to use crimp on connectors instead of the OEM block that's melting from a loos connection.
Posted on Dec 01, 2014
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
SolutionGuy
  • 331 Answers
SOURCE: I have a new ge range. When I turn on the left
mvek,
If you could see through the glass, you'd see "temperature sensors" located near the elements. They're very sensitive little guys, and rightly so! Their job is to detect temps and energize the warning light on the cooktop so users won't get burned.
To answer your question... It appears that there is an issue with the front left sensor (and possibly the right as well). The temp warning lamps should NEVER go off immediately. Please call for warranty repair (1-800-GE-CARES). This is an unsafe condition for you and your Family. The warning indicators are there for a reason and should indicate high temp's as long as high temp's are present.
SG
Posted on Apr 12, 2009
Maytag317
  • 1136 Answers
SOURCE: 0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
Posted on May 17, 2009
  • 291 Answers
SOURCE: My question is in regards to my Kenmore electric
It is usually always an infinite switch, Rarely is it a surface element. The fact that the power light does not go on is also a good clue that your switch is bad. If it was a problem with the wiring to the element, your light would be on. When you order the switch, ask for the exact origional replacement. They have some generic switches that have shafts that have to be broken off to the right size for your range. These are not as reliable as the origional which usually has a much stronger shaft. Good Luck, Appliance Specialists.
Posted on Jan 26, 2010
My 4 1/2 month old Kenmore Range's burners fail to heat up. I "play" w/ the switches, and sometimes get them to start. What's going on? Thanks, M. Lowenkopg
Is it just 1 "burner" (element), or do they all act funny? If they all act intermittently, check the input power wires (240V supply) and the screw terminals (or nuts) that hold the wires; make sure they are tight (unplug your range first!). If it's just 1, then it is a defective control (called an infinite switch).
Oct 01, 2014 | Kenmore Kitchen Ranges
Burners not working
Kenmore 30" Drop In Model # 911.45565791. Turned on the r. front burner and it sparked at terminal block. Swapped coil with the other one and it still did not work. Did not see any broken wires. Replaced terminal block, any ideas? All other burners, etc. work fine.
Jan 02, 2014 | Jenn-Air Kitchen Ranges
Hello. We have a Whirlpool Accubake range and we heard a pop and saw a spark under one of our 8" burners. What ever happened tripped the circut. After resetting the circut, the rest of the oven and...
I had a problem with my Whirlpool range. It would not regulate temperature properly on the two large 8" burners. I found the problem was the "infinite switch". The infinite switch regulates temperature of the electric stove elements.
I found this video (see youtube link below) informative and it solved my problem. I found the correct infinite switch on Amazon (my infinite switch was this $21.00 one: https://www.amazon.com/gp/product/B004XLEJ7M/ref=oh_aui_search_detailpage?ie=UTF8&psc=1). The fix to replace 2 infinite switches (both 8" burner switches) took me 1 hour, including cleaning the floor under the stove (nasty!). All was well afterward.
https://www.youtube.com/watch?v=F4gCWNdu2io
Apr 14, 2017 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Left front element not working ordered new element and replaced and it still isn't working. the element on light comes on but does not heat at all
Did you check the receptacle that the burner plugs into? Sometimes they get melted or corroded. If that looks good the problem is likely in the switch. They are easy to check and replace. Here is a couple links that should help
Testing an infinite switch
Burner and receptacle
Oct 14, 2010 | Kenmore Kitchen Ranges
Kenmore drop-in electric range plug melted
Hello- Yes it can be fixed- first, make sure outlet is not damaged. If it is, it will need to be replaced. Next, plug is wired into a terminal block on back of unit. With care, this cord is easy to replace. And safer than it was before. A loose plug, or wire caused the fireworks. Let me know if this info helps- have more if needed. -Thanks- ED
Mar 03, 2010 | Kenmore 45062 / 45069 Electric Kitchen...
Left front burner on kenmore electric range doesn't turn on!
It is possible that it is the element as they are the first items to fail
next is the switch which is a thermostat operation
elements cost upwards from $30.00 and the switch upwards from $60.00
you may have to get a technician to come and advise the problem
May 24, 2017 | Kenmore 95172 / 95174 / 95179 Electric...
Large electric burners not working on lowest "LO" setting
Unplug the range and remove the problem elements.
With a flashlight, look inside the element receptacle for burned or disfigured terminals.
If they are damaged they can be replaced.
If the element terminals are OK you have defective switches.
Mar 18, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Kitchen Ranges Logo
235 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
