Question about Tablets & eReaders
My tonbux 10.1 will not switch on
Tablet will not turn on even with charger plugged in or without have left charger plugged in for a long time to check not charging problem
  • 1,268 Answers
Most likely the charger is not functioning. Test it with a meter where it goes into USB port and plugged into wall outlet.
Posted on Dec 01, 2014
Gort007
  • 1187 Answers
SOURCE: Gateway M1300 tablet pc will not charge in the
Question 1: Will the tablet operate on the docking station (or power cord) without the battery in place?
If not, the power circuit on the tablet motherboard is broken.
Question 2: If you plug in the power cord into the tablet, is the connection "loose"?
Check the other tablet to see if it is the same loosness at the tablet power connector.
If it is loose, the power receptical in the tablet can be soldered back onto the motherboard.
Recommend taking it into a shop to re-solder.
If under warranty, get it repaired.
If not under warranty, your choice if you want to use it they way it is.
Hope this helps...
Posted on Sep 03, 2009
  • 35645 Answers
SOURCE: charger gets hot while plugged in and does not charge tablet. tablewt is dead wont turn on.
The battery may be unable to charge
Posted on Sep 29, 2012
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
Posted on Feb 20, 2013
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
Posted on Apr 02, 2013
  • 183 Answers
SOURCE: I have an Asus Memo Pad HD 7 which I purchased 3
the more programs you install and run in the back ground the more the battery is drained. It comes to a point where there are so many programs running the gadget cannot run & charge at the same time. It might charge better if you uninstall a lot of programs or do a factory reset but that is drastic
Posted on Oct 30, 2013
Testimonial: "I did do a factory reset but the icon is still not showing and it still is slow at recharging. I didn't really have many programs anyway, a few simple card games, crossword puzzles and some weather apps. Right now, I think I have maybe 4 simple apps on the tablet and it is still not charging when on. I checked the battery status in settings and it says "not charging". However, if I turn it off and then plug it in, a red battery indicator shows it as charging."
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
Why did my RCA 10 inch tablet power down and now will not turn back on? It does not show any sign of charging - no battery symbol, no lights, nothing.
battery have residual power which last few minutes to allow safely switch off, as you used this power, it shut down. this residual reserve is usually between 3% to 5% of capacity.
and do not fiddle with it till you recharge it, reset will not work while there is no power, any other "trickery" will not work either.
now, plug battery to known good charger and charge it for 24hrs, do not switch it on during that time nor disconnect from the charger.
after this it should be starting and working normally, if it does not - it is still under warranty and you should return it to the place of purchase for repair or replacement, even if you do not have receipt. tablet have it's serial number and can be traced in the store to day, and even hour and minute when it was sold...
hope this short info will help you - do not forget to vote...
Feb 02, 2015 | Tablets & eReaders
How can I change the battery in m9100 kocaso
Try the follow to see if it will fix it:
There is a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
After performing the power reset on the device the device will behave in one of the following ways:
1. The tablet will turn on like normal.
2. The tablet will show the battery icon only.
3. The tablet will show nothing on the screen at all.
All of these are normal for the device and should not be cause for alarm. If the device still fails to power on after being left on the charger for 4-6 hours,
Then most likely the battery will need replacing.
Here is a link to where you might be able to get a new battery:
Replacement 4000mah Battery for Kocaso M9100 M9000 9 MID All Winner A13...
Jan 23, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
I have a Nabi that all of the sudden even if the green light is on saying its charged the screen stays black
Sounds like you have a good charger/cable, so try resetting the Nabi that's giving you trouble. Hold the power switch down for 10-20 seconds to reset the unit.
I have a couple of NABI-2 tablets and they both react differently to the charging cables; I often have to shut the NABI off completely to charge them. Also, getting the charging cable to connect can be challenging - I will plug the cable in and out several times waiting 10 seconds or so to see if the green LED will go red.
Dec 31, 2014 | Nabi 2
What's wrong with my device? It powered off even with batterly life left and won't turn back on even when plugged into the charger.
can you pull the battery out for awhile (30 mins to an hour) the put the battery back in and charge the device without turning it on until it is fully charged.
Oct 01, 2014 | Tablets & eReaders
How to reset SVP TCP-1020 tablet
In most cases, the battery comes loose from the main connection. Those tablets do come apart, the back just presses on.
Jul 30, 2014 | SVP 10-inch Tablet
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
My 7 inch Samsung galaxy tablet will not come on.
have you tried turning off tablet with charger plugged in and letting it charge up. You should see a battery symbol come onto the screen with a pulsing level indicating the battery is being charged. hold in power till unit turns off then plug in charger cable into tablet and switch on charger at power point . Do not try and push power switch to power up tablet see if screen indicates charging is occurring. I have experienced this exact problem on a samsung tablet !
May 03, 2014 | Tablets & eReaders
Unable to switch on my samsung T210 tablet
Feb 17, 2014 | Samsung Galaxy Tab 3 SM-T210 8GB 7"...
Tablets & eReaders Logo
264 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
