Question about Honeywell Heating & Cooling
How do I fix central heating
Can only get hot water or heating, not both. To get hot water, I have to switch both hot water and heating "off" on the timer controller, then switch hot water on. To get heating to work, i have to again switch both hot water and heating "off" on timer controller, then switch heating on. Timer is Honeywell ST9400c and 3 port valve is Honeywell V4073A.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
The first thing you need to substantiate is the fact that there is enough water in the system. It will be a closed loop system requiring approximately 10 psi/ floor. (Only a rule of thumb). Usually when one protion of the system works and the other does not, it is an issue of water quantity available to circulate through the combination of loops. If you have to add water, you will probably have to purge air from the highest points in the system. Even if there is an "Airtrol" fitted in the bottom of the expansion tank, bleeding the high points will eliminate air quicker.
The hot water portion of the loop should only be going through a heat exchanger that transfers the loop temp to the domestic water circuit and the three way valve is probably a 'mixing valve' utilized to maintain a certain loop temperature on the primary loop.
Posted on Jan 08, 2015
SOURCE: central heating timer
Does it have batteries?
Posted on Apr 05, 2008
  • 16 Answers
SOURCE: cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Posted on Aug 17, 2009
heatman101
  • 43501 Answers
SOURCE: st6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Posted on Nov 12, 2009
  • 36 Answers
SOURCE: boiler is a baxi control for heating is honeywell.
this will be your diaphram inside your divertor valve.
the one that looks like a spaceship.
it will e split.
Posted on Jan 31, 2010
  • 120 Answers
SOURCE: Have a back boiler. Central heating working fine. Hot water not.
Depends on type of control system but usually you will have a three-way motorised valve somewhere. This is contolled by the tiimer and the thermostat on your cylinder. Look for a box that has one pipe going in to it and two further pipes coming out. I suspect yours is stuck on heating. Some models had a manual lever to put it to just hot water. End of the fday you need to get someone out to fix this one.
Posted on Jul 22, 2010
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
When I have central heating on, why do I also get very hot water in taps even though water heating switched off?
This could be due to incorrect installation, incorrect wiring of controls, or an unintended consequence of combined central heating and hot water supply.
Nov 27, 2015 | Water Water Heaters
Ls80t hot water goes hot cold hot cold heating is ok
http://waterheatertimer.org/How-to-fix-water-heater.html
What kind of water heater do you have? Boiler, indirect?
What brand and model?
Or is this a HVAC unit?
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 17, 2014 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
No central heating. Bled radiators but still nothing. Hit Re-set switch and now no central heating or hot water. Help!
check the pump,circulation not working will stop boiler at flow switch.
if pump working then check flow switch
Oct 09, 2009 | Audiovox Bosch 718 World Cellular Phone
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Siemens central heating control
I have a Siemens "Radio" Room Stat - the receiver has switched itself off. How do I restart it. I have pressed the restart button and the reset - nothing happens except for red light flashing and then off. I do not have the instructions. Where might I get them?
J W-K
Oct 18, 2008 | Water Heaters
Heating & Cooling Logo
122 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
