Question about Goodmans Televison & Video
My Goodmans free view box GDB18FVZS2 is no longer taking signal to TV? So have disconnected it! What could be wrong? I don't want to lose my recordings?
Checked the fuse and it's ok Disconnected the box now so we have the tv!
redhead7377
  • 51 Answers
SOURCE: Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Posted on Sep 09, 2008
SOURCE: Goodmans 27 inch LCD
Dry joints ???
Fuse blowing on these is due to a transistor going open circuit, blows/trips main fuse in plug/fuseboard and pcb psu component.
Part number HA160T1A1 is no longer avaliable to replace the board after only 14 months service the lesson is you get what you pay for, go for more reputable manufactuer :(
Bad company with cheap and nasty products.
Posted on Sep 11, 2008
  • 191 Answers
SOURCE: Goodmans LD3755HD Picture Problems
for cms voodoo, change your power module.
for tomchik, check your input voltage for voltage drop or fluctuation, if any employ voltage stabilizer, then change your power module. make sure that there is enough ventilation around your tv.
for bananahead , go and change your backlight inverter
Posted on Oct 11, 2008
  • 814 Answers
SOURCE: Losing signal intermittently every 1-5 minutes
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Posted on May 13, 2009
SOURCE: Hi,my LG 26LB75 LCD TV displays nothing at all,no standby
hey man,
i have th same problem. have you find any solution?
Today i will verify, if the problem isn't it in noise filter IF - N06AEW.
I will post a result. Please let me know about your solution.
thanx
mailto: daniberk@centrum.cz
Posted on Jul 16, 2010
Yesterday i lost signal on all my goodmans free view boxes
I was tempted at first to say...Well what do you expect for free?.....lol.
But seriously..........if these are Goodmans Speakers you are referring to then the driving unit has a problem If these are "Free to Air" set top boxes then you need to first check your antenna and cabling.
Oct 30, 2011 | Audio Players & Recorders
Problem with digital tv
The Antenna may be in a weak signal area heres a quick cheap fix
Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak..
You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
Apr 15, 2010 | Goodmans GTVL32W27HDF 32 in. LCD TV
I have had a 32" sony LCD Digital TV with built in free view tuner. I am experiencing a problem where on certain channels the TV keeps switching itself off to standby. Is this a TV fault or a signal one,...
if it says no signal or video not available then signal if its just turning itself off then tv i would go to the shop and get it checked out or replaced.
Dec 04, 2009 | Goodmans GTVL32W27HDF 32 in. LCD TV
No signal, no channels coming up. other TV's on same ariel working ok??????
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
Nov 04, 2009 | Goodmans Televison & Video
How do I retune my goodmans television for
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Oct 01, 2009 | Goodmans W280NS Television
How do I retune my Goodmans 1475TS ?
Sep 25, 2009 | Goodmans 1475TS 14" TV
Cannot get my goodmans 289ns to accept the virgin digital signal
Will the TV go to channel 3? if not you need to reporogram the TV to sence channel 3 or go into the setup and undelete channel 3. Channel 3 is the channel your digital box is set to boradcast to the tv itself.
Apr 22, 2009 | Goodmans 289NS 14" TV
No signal on my goodmans xpro freeview on the flat screen it says
hi there the first thing i would make sure you have a wide band ariel capable of receiving free view if the ariel is old and was there before you moved in and you have been there a while theres a good chance that the ariel isn't a wide-band ariel,
also check here with your post code to make sure free view is transmitted in your area
http://www.freeview.co.uk/availability
if you know you can get it and you have a wide band ariel make sure all connections are secure and that you don't have many leads connected together because you will lose a vast amount of quality though many leads to a point where you wont get a picture also make sure its the only tv on the connection as having a few will also do the same thing. ariel boosters can make a massive improvement on the line these can be bought any where even you local asda/walmart, make sure you have one secure connection right to the ariel socket to your tv. this eliminates any other problems
make sure you have your tv tuned in right if you have just moved house you will need to rescan for Chanel's as they can be on different frequencies from where you last lived
I hope this helps you if you Need a maual for your set please leave make and model number from the back of the set and ill try and get u a online manual for this set
Good Luck Hope You Sort It
Feb 03, 2009 | Archos AV 500 400-Hours Video Recorder
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
Nov 25, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
Top Goodmans Televison & Video Experts
Steven Wander
Steven Wander
Henry  Thomas
Henry Thomas
Jonathon summesfield
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
