Question about Konica Minolta Office Equipment & Supplies
What is reset procedure for konica minolta b162
  • Points To Ponder Dec 03, 2014
    What led you to inquire of the reset procedure? Specific questions tend to get specific answers. What is the printer displaying, doing, or not doing?
    Master:
  • 149 Answers
In order to reset the printer (or the error code), power on the machine while continually pressing stop & reset buttons.
Posted on Dec 01, 2014
Testimonial: "the printer did not work after reset as I was instructed"
Konica minolta bizhub 195 shows M2 error after changing the developer how to reset M2 error?
Did you also replace the drum, clear the developer counter first before installing the developer, and run the required F 8 procedure after the developer was installed, As the machine uses the counter to control voltages to certain assemblies, not replacing the parts and resetting the counter will cause codes and image issues.
Jan 19, 2016 | Konica Minolta bizhub Office Equipment &...
Konica minolta 2300w change toner
You will find the step-by-step procedure on the following link, on the page 57 (48)
http://printer.konicaminolta.net/drivers/manuals/2300w/user_es.pdf
If you need anything else, let us know.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Aug 21, 2014 | Office Equipment & Supplies
Minolta ep 1030 error e1
Imaging unit toner detection failure - during concentration read operation (F8), the result is less than 1v. Replace the developer and retry the F8 procedure.
Aug 18, 2014 | Konica Minolta Office Equipment & Supplies
How to run f 8 bizhub 211
Follow the procedure below:
1. press the Utility
2. press the following keys [Stop] 0 0 [Stop] 0 1
3. choose 'Functions'
4. choose 'ATDC Auto Adjust'
Aug 15, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta bizhub c451 service mode password reset
Hello there if u enter the service mode and it shows and password it means that the user or the service before has activated the CE password that means that you can enter if you do not know the password. Either way you have to try to enter the default CE password that is 92729272 or 00000000 or 123456789 the first one if not change should open acess to the service mode if not you have to call the konica minolta for NVRAM reset procedure there is no other alternative.
Mar 14, 2014 | Konica Minolta Office Equipment & Supplies
I have one Konica Minolta bizhub c250, unfortunately I forgot the administrator password can I reset it to system default.
There is no procedure to restore the admin password. It is possible to reset and enter a new password, and for that you will need a technician to make the adjustments on SERVICE MODE (stop,0,C).
Jan 27, 2011 | Konica Minolta bizhub C250 All-In-One...
NEED TO RESET THE DRUM LIFE AND STARTER . NEED THE PROCEDURE TO RESET THESE WARNINGS
Unfortunately The minds at Konica Minolta have figured out how to make the machine Inoperable if you reset the drum and or developer counters, the only way to reset the "change drum" condition on a Biz 350 is to replace the drum AND the developer and calibrate them both when you do it automatically resets the counters... sorry.
Sep 29, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
My printer is showing a code c-38-51 and will not work
Hi, C-3851 is related to the fusing unit. Specifically, the lower roller is at an abnormally low temperature. Unfortunately you cannot reset the code in a normal manner. Konica Minolta, for health and safety reasons, make fuser related codes engineer resetable only.
I'd rather not post the procedure here, so drop me a private email and I will advise on the procedure.
Regards
Tam
Mar 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Network configuration for a minolta konica c451
If you know the IP of the machine, just type it in the browser address and you'll have access from there.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
Dec 10, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
56 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
