Question about Chevrolet 2006 Chevrolet Cobalt Radio
Dose the wires to the radio have anything to do with the dash not working
Tried to install a after market radio did not work so I put old one back and now the customer says the dash don't work
  • Chevrolet Master
  • 1,388 Answers
This could be true. The radio fuse may also be the fuse to dash lights also. Check the fuses. One fuse will cover 3 or more difetent things. Like My Toyota pickup with automatic trans, when wipers quit working because the fuse blew, I had no overdrive either.
Posted on Dec 01, 2014
2004 Pontiac Grand Am SE dash back lights quit working I installed an aftermarket radio. Wiring OK no blown fuses.Every thing else works fine plugged factory radio back in lights still did not work.
check that dimmer is turned up ---and check connections around where radio work was done for damaged disconnected line connector also check dash fuses not just fuses from radio --or your radio may not be compatible to your dimmer circuit -most oem radios display are Incorporated with dash functions and after market ones are not
Jul 23, 2015 | 2004 Pontiac Grand Am SE
I've asked this earlier but not sure if it went in I have a 2005 Suzuki Verona the radio works but no lights on the radio what would cause this issue
the dash has a dimmer, this is dash park lights
and runs all radio back lights.
so if the dial is low, its dark
if the dash cluster glows good the dimmer is ok
and the wire to the radio called, dial
on after market radios its the orange wire. not 12v, its dead.
http://knowledge.sonicelectronix.com/car-audio-and-video/accessories-and-installation/wiring-harness-color-standards/
suzuki uses different colors.
turn on parks, with a voltmeter measure 12vdc at DIAL wire.
at radio.
0v bad, 12v good, if 12v then radio lamps are Blown out.
Mar 01, 2015 | Suzuki Cars & Trucks
Dash light doesn't work
Check fuses for dash light / instrument display. If the fuse is good, you may want to check if stereo share an illumination wire with dash. You may have broken the connection behind stereo.
Jan 06, 2014 | 1992 Honda Civic
After Market Radio Installation
Hey man, you have an amplified system. use a 70-1858 wiring harness and jump the blue/white wire from the aftermarket radio to the pink wire on the second plug. this will power on the factory amp with the aftermarket radio.
Chris-
May 04, 2013 | 2000 GMC Yukon XL
2002 Mitsubishi Gallant - installed after market stereo with wire nuts. Stereo works great, but the dash lights are out. Any Help?
pull the radio back out and remove the wire marked dimmer control on the aftermarket radio then replace fuse
Apr 24, 2011 | 2002 Mitsubishi Galant
My alarm system doors locks dont work consistently. some lock some dont. my radio stays on all the time and windshield wipers wont work. it sonds like sizzleing under my dash
Was there an alarm system or after market radio installed recently? I would diconnect the battery before anymore damage happens. And take the part that was recently installed. and get back behind the Radio/or follw the alarm wires and your gonna find alot of burnt wires. You will find the arcing wires. replace them . Have you noticed anything not working? If you have ? 10 to 1 that's the problem.
Please leave a good feedback for me.
Thanks
Jan 06, 2011 | 2000 Ford Expedition
I put in a cd player everythings connected but there is no sound coming out of the speakers
check your wiring, make sure its not grounded behind the dash somewhere
Sep 18, 2010 | 1993 Lexus Es 300
Radio is on, but no sound. 2003 Olds Silhouette.
I had avery similar problem with my radio. At first I would lose audio but it would eventually come back. Then I lost it for good. I replace the radio and that work for a bit and then replaced the speakers and they worked for a bit. Eventually no audio. I took the radio and speakers back to the tech who installed them and he found a short in the speaker wiring to the passenger speakers. He installed a jumper around the short and the new radio and speakers worked fine. Then I had him put in the original raidio and speakers and have had audio ever since.
Doug Crail
dscrail@yahoo.com
May 18, 2009 | 2003 Oldsmobile Silhouette
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Wiring diagram
First, goto a store and buy a snap in wire harness and a mounting kit. There are wire diagrams in the packaging. Wire your wire harness into the radios wire harness (everything is color coded). Follow the intructions to install the mounting kit. It should tell you what screws to remove from your dash and so forth. Just remeber were everything goes. Next, after you remove the old radio, snap in you wire harness to the cars wire harness. Then, test the radio to see if it powers up and all speakers are working. Lastly, put you radio in your dash, and put everything back togeather. The number one rule in installation is take your time. If you rush, you will brake something.
Jun 02, 2008 | Pioneer DEH-P2000 CD Player
Chevrolet 2006 Chevrolet Cobalt Radio Logo
77 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
CrisO
Lawrence Oravetz
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
