Question about Spar Food Mixers
Where can I get the bowl cover for a spar mixer model no 80da_b
The web
  • 1,147 Answers
Contact the manufacturer. Or just go to where you purchased it and ask for a replacement.
Posted on Dec 01, 2014
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
What serial number mixers have a plastic gear cover
All of the new style that are made after 2002 0r 3 that are bowl lift models and up untill 2008, They no longer make the plastic as it could not handle the work load all are made now with a cast aluminium cover. Hope that helps
Oct 10, 2014 | KitchenAid Pro 600 Stand Mixer KP26M1X-...
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
After putting flower into mixing bowl large quanity of flower is ejected when mixer is turnon at low speed. Once it starts to mix then it's ok.
Firstly, I think you mean "flour".
Put in your ingredients. Cover the mixer, head and bowl, with a dishtowel. Turn on mixer to "stir" (or lowest speed). But! Mix only for 1 or 2 seconds. Repeat this, with bowl covered, until flour is mixed in enough not to fly out.
Happy baking!
Dec 11, 2010 | KitchenAid Classic Stand Mixer
Need a wiring diagram for a Spar SP-200 mixer
Did you find this already? I have one I can copy and send to you if you like. contact me dalybird@yahoo.com
Mar 29, 2010 | Spar SP200 Commercial Planetary Stand...
Food Mixers Logo
63 people viewed this question
Top Spar Food Mixers Experts
eyecam
Are you a Spar Food Mixer Expert? Answer questions, earn points and help others
