Time macine hanging
Switching of at the wall
  • 3 Answers
Try to run very fast and head-jump into the wall...
LOL
Posted on Dec 01, 2014
How do I hang a picture on a Durock cement board wall?
Please provide more information.
Cement board is usually used to as a waterproof wall.
many different 3M Brand Command hangers might work.
if you need to hang a picture in your shower, you may be spending too much time in the shower to require the need for entertainment, possibly need to "phone a friend"?
Command Products
Sep 19, 2014 | Masonry Tools
L7780 cannot get dial tone on 2-line outlet. Are there any work arounds to this problem?
There is a problem either with the Line Interface Unit (LIU, also known as the fax/phone line connector) or the fax hardware, because the unit is having problems sending or receiving faxes. The unit may hang on "Initializing." This document explains how to troubleshoot the LIU and fax hardware. SOLUTION: Please perform the following: Front panel hangs on "Initializing"
  1. Pull the power cord connector from the back of the base unit to recover from the error.
  2. Unplug the LIU from the back of the ADF. It is located on the left side (facing it), and is where you plug in the telephone lines.
  3. Plug the power cord back in, power it up, and see if it hangs without the LIU inserted.
  4. If it does not hang without the LIU inserted, power the unit down, plug the LIU back in, and power it back up. If it hangs, the LIU is faulty.
  5. If it does hang without the LIU attached, unplug the ADF from the base and see if it hangs. If it does, the base is faulty.
Testing the LIU The primary test for the LIU is whether or not you get a dial tone. Sometimes, you need to re-seat the phone line several times to get a good connection. If after trying the things below, there is still no dial tone, or initialization hangs, the LIU may need to be replaced.
  1. Verify that the phone line is connected directly from the wall jack to the plug in the LIU that says "To Wall Jack."
  2. Verify that the LIU is plugged securely into the product. If it is not, there will be a message at power-up saying the LIU is not connected. If it is, the date and time will display.
  3. If the LIU was re-seated, cycle the power on the unit. The unit should display the date and time.
  4. Unplug all other accessories, like a telephone answering machine or modem. If the LIU appears to work fine after unplugging them, these accessories may be interfering.
  5. Place a document in the Automatic Document Feeder (ADF). The display will flash "Document Loaded."
  6. Press Start Fax to verify there is a dial tone. If so, try sending a fax.
  7. If there is not a dial tone, unplug the product from the wall jack, and plug in a regular telephone to verify there is a dial tone at the wall jack.
  8. If there is no dial tone on the telephone, the wall jack or phone line may be faulty
Oct 26, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I have a Fresh Start Oasis model fstb-p60-100 coffee maker at work. Problem is, sometimes it brews only a partial pot of coffee then the next time it will overfill the pot. I am looking for user and repair...
There is probably a scale deposit around the tank outlet that leads to the sprayhead. Unplus the macine from the wall. Remove the top cover. Pull on the black rubber connector that leads to the sprayhead until it comes off. Insert a Bunn Deliming spring into the black rubber connector and feed it into the tank, run it back and forth several times. Remove the deliming spring and reconnect the black rubber connector. make sure it is on all the way around. Replace top cover. Pour in a pot of water. you should get an instantaneous flow of water from the brew basket.
Oct 16, 2010 | Oasis FreshStart 80 oz 10-Cup Coffee Maker
How can use to LG LCD tv in wall hang
First you get the wall hanger. Screw one part to the wall. And then screw the other part to the TV. then you hang the TV on the part screwed to the wall.
Hope this solution has been helpful?
Sep 26, 2010 | LG 42LC2D 42 in. LCD HDTV
How do I locate the switch for the Canon L100 fax machine?
wich switch, the macine is automatically turnd on when gets the current.You only have the copy buttton that you need to press if you want to copy, and for return yust red one two times.
May 19, 2010 | Canon L120 Fax Laser Printer
The machine is not filling and all the display lights are flashing.Thankyou.
It sounds like ether youre plumbing is not leting water down the pipe or the valves have gone inside youre washing machine try filling the washing machine up via the powder dispensing draw with the front door of the macine shut and the macine off when the machine is full of water swich it to the program you want and see if it works if it does then its the valves in the machine burt before you do that unhook the filling hose from the wall and see if water is coming out if not its youre plumbing
Nov 27, 2009 | Office Equipment & Supplies
Have figured out that the problem with my washer is the lid switch when I opend the top and pushed on the switch the macine drained and began to spin model number kenmoore 110.20802990 how hard would it be...
check your top for the push tag for the switch
if your able to push it and have it work, make sure the dog on the lid that enges it is good
all toled about 30 mins of work if your unfamilair with the repair
2screws on the control panel roll it over
remove the dogs that hold the cabinet down,,,, they should be on the back wall and look like copper
unplug the lid switch
pull the cabinet forward
the lid sweitch is mounted underneat
ive include the link and picture to order it
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11020802990&productCategoryId=0153200&brandId=0582&modelName=AUTOMATIC-WASHER&diagramPageId=00001&componentDescription=TOP%20AND%20CABINET&documentId=P9060120&blt=06
Oct 23, 2009 | Washing Machines
Brother dcp 135c instalation just hangs and does not complete
first not need to connect usb cable .
First install the driver and software then restart the computer then connect usb cable to computer then if it need driver clik on no at this time .
then install from sleected location browse your folder then locate the driver folder then it install
Aug 23, 2009 | Brother MultiFunction Center MFC-440CN...
How do you take the stand off to hang it on the wall.I can not figure out how to take it off to put the cover on so I can hang it on the wall...it is a proscan 32LA30Q.
hi most of the time ur screen sits on 2 bolts coming from the base and screen sits on top.....
if u cant find it go in contact with PROSCAN and they will help u to get it off
Jul 03, 2009 | Proscan 32LA30Q Television
Will not fill with water
It sounds like the pull-out switch, under the pull-out knob, is not working and may need replaced. Go to Repairclinic.com and type in what your washing macine is not doing and they will give you hints on what to do next. But, it sounds to me like that is what is wrong with your washing macine.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
