Question about Dishwashers
The program button on my HomeKing DW1600 dishwasher is lit up but is not working ( I can't select a program ) and the dishwasher does not start? Nothing else is flashing.
Turned it on/off but no joy.
  • 7 Answers
SOURCE: dishwasher
what brand is it? go to that web site put in model number and download it there. also you might have the controls locked press and hold the heated dry button for three seconds to see if that unlocks the controlls.
Posted on Nov 06, 2007
SOURCE: Smeg Dishwasher STA945.1, flashing lights
have you check the pipe's for blockage
Posted on Sep 11, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Dishwasher not responding
we have a 4 yr. old built in dishwasher,model #665-15812,the lock-on light is blinking,and the wash and rinse lights are on,but if we push start ,it won't,and if we push the clear button,it won't clear,it's like it's stuck ....we've tried un-plugging,etc....any ideas,on what to do??? donnie-sue79
Posted on Jun 04, 2009
VtToolMan
  • 704 Answers
SOURCE: Can't start the dishwasher, lock button is lit up.
Hello Albert, On the Jenn-Air dishwasher you have, you have to hold down the "Heated Dry" button for 3-5 seconds to unlock the control panel.
This should unlock the controls so you can again use the dishwasher normally.
Since you''re likely going to have this dishwasher for some time, I've included a link where you can download a free owner's manual for it.
I would print out a copy for your future use and reference. I also have a file on my computer that I title "Home Appliances and Equipment" which is where I download and save an electronic copy so I always have a backup copy saved, since manuals aren't always readily available on the web, as the appliances get older.
http://www.jennair.com/assets/product/6_920374_A.PDF
The info on locking and unlocking the dishwasher can be found on page 13 of the manual.
I hope you find this Very Helpful and best regards!
Posted on Nov 23, 2009
Testimonial: "Thanks for the detailed info about my question, VtToolMan, I greatly appreciate it. However, I tried to unlock it that way, but it didn't work. "
Technika wash
disconnect the power cord from the mains (not the switch) and press the power button for 3 seconds. Connect it back and check.
If the issue persists, you will have to provide more details; does the machine stars? is it heating the water? it does nothing?
Also check for any filter blockage and the water intake.
Aug 31, 2013 | Asko Dishwashers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
My dishwasher from ikea renlig dw 60, is 6 month old and now the light to select the programs stay red all the time and pressing the selection button doesnt do anything. Thanks for your help
Similar just happened to us. Turned power off, waited a while, opened door. pressed and held power on button then pressed and held also the select button. Brought it back to life. End leds lit up and i could then select and worked when i shut the door. Ours is a smaller Renlig. Good luck.
May 27, 2011 | Dishwashers
Hoover hnd315 dishwasher program buttons not lit or working.
I have the same problem, did you manage to fix it, and if you did what was the problem?
Mar 23, 2010 | Dishwashers
Year old Bosch SHU33A0UC won't start. Lights on
Light's on mean you have power.
Initiate the self test program by doing the following -
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on
by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press
ON/OFF button.
To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each
program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended
and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault – note circulation motor stops shortly after it started
during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil,
measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays
at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain
where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150ºF) and water won’t stop
circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end
shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Let me know what you figure out. I can repair these boards most of the time.
Dec 18, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
Sep 19, 2009 | Miele G880 Dishwasher
The program light goes off and the BF162 doesn't start...
When you keep the button pressed for a few seconds the lights go off, this resets the dishwasher. Then press the p button again to the program you want 1st light is heavy soil 2nd light is normal soil, 3rd light is eco wash, 4th light is rinse. At the end of the cycle the program light you have selected will flash.
Apr 24, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Won't start, can't change wash selections
hi there,
can you tell me if you can hear the motor running? if not
did you trip the house breaker? if not
can you open the door? if not
it's the door latch; if yes
is there water on the bottom of the dishwasher? if yes
you are not draining and the dishwasher lost power; if not
the timer is not advancing to the next cycle
let me know.
Sep 28, 2008 | Frigidaire 24 in. FDB679GF Built-in...
ESL 63010 will not start program
does your dishwasher have a timer button on it? sounds like the switch behind the button needs to be replaced.
Sep 13, 2008 | Dishwashers
INDESIT DW S 60
check and make sure the door switch is activating
Jan 03, 2008 | Indesit 23 in. DV62 IX Built-in Dishwasher
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
