Question about Refrigerators
Whirlpool Gold model GB9FHDXWS06 :I had the very common problem of the condensation drain being blocked; I removed the inside back panel, which necessitated removing the door, drawers and ice maker. After melting the accumulated ice with a hair dryer and flushing the drain with hot water, I reassembled everything, but the ice maker is now not making ice. I double-checked that the water inlet tube and the electrical connector were in place, but still no ice (and no water in ice tray). Any thoughts on what to try?
  • 937 Answers
I know this is basic but did you check to make sure the ice maker didn't get switched off in the moving stuff around. Most have some manner of interconnect to shut down the ice maker if the receptacle is not in position - perhaps a wire got knocked loose?
Posted on Dec 01, 2014
  • 8 more comments
  • Ray Manikowski Dec 01, 2014
    I did check the connection; the ice maker is definitely on. I verified this by opening the door, holding down the light switch, and observed that the ice level bar was moving, suggesting that the ice maker was going through it's cycle - however, still no ice. And no water going into the tray after the cycle was complete. I think something ispreventing the water from flowing into the tray - perhaps I inadvertantly kinked the water tube when I disassembled the panel to remove the frozen condensation. Any thoughts on that? Thanks.
  • mbarre Dec 01, 2014
    That would be a logical step. Either it is not getting water, or the timer is not cycling and opening the valve to fill, or the valve is malfunctioning.
    Seems most likely that the tube is somehow blocked. I can't imagine that I somehow damaged the valve, as I didn't touch it. Do you know if there is some way to "re-boot" the system, if that makes sense?
    Only thing I can come up with is unplug wait a moment and repower.
    I'll try that (with fingers crossed...). Only other thing I think might have some value is to take it all apart again and inspect the water line. Thanks.
  • Ray Manikowski Dec 04, 2014
    Hi again: So, I took apart the freezer once again and verified that the water line was not kinked or blocked, so my next thought was that perhaps in all of the on/off cycles, the water inlet valve got damaged, so I bought a replacement and installed it. Same results - no water flowing to the ice maker. Any thoughts on any possible cause left? The only other thing I could think of is that the wiring thste controls the valve somehow is disconnected at a point which is not visible to me.
  • mbarre Dec 04, 2014
    Wow. surprising result. Let\'s think about what is supposed to happen... Fill the tray, freeze the ice, spit it out. repeat. In my experience, the ice maker has a rotating cam that acts as the timer to sequence everything but I must admit new units may well use solid state... Anyway, the timer signals the valve to open and fill the tray. You confirmed the valve is not faulty, if it is getting the signal to open. You confirm the unit has water? Can you confirm that the timer is rotating? do the arms cycle to push out ice that would be frozen?
    Cam appears to be operating properly; the ejector arms are turning, and the ice level bar is also moving/cycling. After a little more Googling, seems like the next thing to check is the thermostat on the ice maker. Given that it seems like the cam is nearly continuously cycling, that may be the culprit. What do you think? Thanks for the quick reply, BTW.
    google is a good friend!
    refers aren't my strong suit but it sounds like your methodology is sound. Tstat makes sense, I would guess it would interrupt the cycle if it is not cold enough to make ice otherwise it would simply pump water into the ice bucket.
Leaking water
Did you inspect if the hole in the drain inside the fridge at the bottom is not blocked? Try to clean it with a swab. Sometimes this causes a "leakage" of condensed water.
Dec 14, 2013 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a one year old Whirlpool side by side refrigerator model # ED5PVEXWS that has intermittent water leaks on the bottom of the fridge lately. Can someone help as to how I can fix it myself (60 yrs old...
hi,it sounds like you have a blocked drain in the freezer.the evapoator coil freezes up,then the machine goes into defrost,a heater comes on and melts the ice off of the coil,the melted water goes down a drain line that drains into the back near the compressor and condenser coil where it will evaporate in a pan.your drain line sounds like it's blocked and has to be cleared.if you open the freezer,remove the bottom bin if it isn't frozen in with ice and if the freezer floor has ice on it the drain is blocked.if this is what you have shut down the machine with the controls or unplug it,remove the food and bottom bins,look at the bottom back wall,if you can see the drain hole and have enough room to stick a turkey baster into it you don't have to do anything else,if you can't see it you have to remove a few more shelves and food so you can remove the inside back wall to get at the drain hole.melt out all the ice with a hair dryer,you might be there for 10 to 20 minutes or a little longer depending on how much ice is there,when the drain hole looks free of ice pour a cup of hot water into the hole,if the water drains you're done,if it doesn't get the turkey baster and stick it into the hole and pump it a few times to see if the water will drain down,also you can pull the fridge away from the wall,unplug it and remove the bottom back panel,on the right hand side usually this is where the drain line is,if you see water in the pan where the end of the drain line is you know the water is passing through the drain tube.also while you're there get a vac and clean out any dust you see.i use a steemer to clean out the drain,it works great.hope this helps and good luck.also if there's alot of ice on the freezer floor you can tap it easy with a hammer or any tool and crack it out and use a putty knife to help get the rest up or if you want just melt it all with the hair dryer.
Jul 07, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
Water accumulating in bottom of kenmore
It's likely the condensate drain is plugged. You can access it from the back of the refrigerator. You can disconnect from the inside of the fridge and blow it out to ensure it is not blocked, then reconnect.
Aug 15, 2009 | Refrigerators
Whirlpool refrigerator - condensation, ?clogged drain
The stopped up drain tube is inside the freezer probably behind the rear wall. There should be screws in it to remove it. Remove any ice at the bottome and you should be able to see it. I don't know about the wheel.
Aug 14, 2009 | Refrigerators
Ice collecting on floor of freezer and water dripping inside frig
Most likely you have a blockage in the defrost drain that begins behind the rear panel in back of the freezer and ends up in a pan beneath the refrigerator were a fan blows warm air over the water to put it back into the air inside your home. You need to unplug the refrigerator and remove the back panel inside the freezer and look at the condensate collector tray at bottom of the evaporator coil. Sometimes its ice blocking the hole because temperatures are too cold for the liquid to drain and it freezes before leaving the freezer and sometimes the line is blocked beyond the tray. Examine first and melt the ice and pour a warm solution of clorox and water in the pan and check if the amount ended up in the pan below the refrigerator. Sometimes a wet vacuum cleaner will help get what ever dislodged from the drain and sometimes we need to install something to warm the hole as the defrost takes place. But cleaning the drain is the best solution for now..Sea Breeze
Jun 22, 2009 | Whirlpool Refrigerators
My refridgerator box fills with water
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Feb 01, 2009 | Refrigerators
Fridge leaks water on the inside, is not condensation
Hi!!! Your drain line is plugg, also there might be some dirt plugged so remove the evaporator panel are clean the drain line..deb5a30.jpg
Jan 04, 2009 | Whirlpool ET1FTKXK Top Freezer...
Fridge collecting water inside
The drain is clogged.
If you want to DIY then here it goes:
Some models have access to the drain by an elbow on the outside back of the Ref. Disconnect the drain line here and if you find the clog, great. If there is no visible drain line and elbow on the outside then...
Hopefully you can access the drain in the back top center of the fridge. This will require removing plastic covers, usually a few screws is all you have to deal with. You must get everything removed so you can see the drain hole in the back wall then you can use a tube and a little air pressure to clear the drain from that point down. If this is clear and you don't find any cloggs from that point down then the clog is at the top of the drain which is in the freezer.
This is going to require a little more work.
1. Take everything out of the freezer, put it in a cooler or just pile it in the sink.
2. Take the icemaker out.
3. Take out the back panel so you can see the cooling coils.
4. The drain hole is in the center directly under these coils but may not be visible because of ice in the drain pan.
5. Use a hair dryer to melt this ice and clear the drain so water flows down.
Dec 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
