Question about Epson Stylus 1400 InkJet Photo Printer
The printer was working fine, then I printed a test print and it was very faded. All the cartridges were almost empty except 1. I replaced all the cartridges. It shows me they are all full, but when
This info is included in the question above.
    New Friend:
    Problem Solver:
  • 7 Answers
Hi Sharon,
This may be an error. Shutdown the computer and re-seat cartridges to be sure they are connecting to the cartridge carriages properly. Once cartridge replacement procedure completes, close all the access panels.
Now shut off the power to the printer by unplugging it or by turning off the power bar it's plugged into. Don't use the printer's power switch!
Now, plug the printer back in. Reboot your computer. And then, turn on the printer and let it complete the initialization process.
Hope it will help.
You can also follow us for more info and support
Epson Printer Support Epson Technical Support Epson Phone Support Online...
Posted on Dec 01, 2014
jackboy
  • 2985 Answers
SOURCE: Magenta does not print
Can you find the bits and piece to make a orubt head clearing pump like this illustration? If you can take the cartridsge out fit the pump and suck out any ink in the chamger. Then empty the pumt and fill with Windex or propanol alcohol dilute with distilled water to 10%[or windex] and pump this through back and forth untill it shoes clear- put the cart back and see what happens Also download this utility www.ssclg.com set it up for your printer Also take a look at www.fixyourownprinter.com
Posted on May 27, 2007
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
SOURCE: Printer will not print ,paper comes out blank
Put new in cartridges in printer.
Page prints out blank.
Have cleaned the print heads 3 times.
Need help!
Posted on Dec 01, 2008
  • 68 Answers
SOURCE: Not printing
You probably have paper debris stuck to the underside of the print head.
While you are printing, pull the lead from the back of the printer leaving the head free floating and unlocked so you can slide it back & fore. Get a piece of kitchen roll and fold it until it's the size of the track beneath the print head slide the head to the left, place the folded kitchen roll flat down in the print track, slide the head over the folded kitchen roll until it appears on both sides of the head. Grab both ends of the roll and lift it toward the head. Slide the roll sideways left and right to physically clean the bottom of the print head. Try not to tear it as it will trap under the head. let go of one end and slide the head away until you can pull the roll out. It should have a lot of ink and gunk on it. Plug the printer in and the head will reset itself.
Now because printing has been non existant, you'll need to "Prime" the heads. Use the maintenance software and click head cleaning, when finished do not allow the nozzle check pattern to print. Carry out 3 more head cleans cancelling the nozzle check after each one by clicking [Finish] until 4 cleans have been completed. Then allow the nozzle check pattern to print and it should be back to normal. If not perfect, carry out another "Prime" as above.
Hope this helped.
Nigel
The INK Store
http://www.the-inkstore.co.uk
Posted on Jan 17, 2009
  • 3 Answers
SOURCE: epson cx3810 printing blank copies
I had the same problem and had to clean the nozzle tubes. After cleaning the tubes, printer worked great again.
Hope this helps.
Charlene
Posted on Mar 12, 2009
HP LaserJet 1320n Printer connected with usb to pc running on windows7; faded printing; economode = off; printer Density =3; what could be the problem
Faded printing is usuallly caused by an empty or defective toner cartridge. If the toner is new and the printer was working fine before the toner change then you might have a defective cartridge, or you may not have removed the tape strip from the cartridge when you installed it.
Oct 15, 2011 | HP LaserJet 1320n Printer
Tip
Replacing a FINE Cartridge on photo printer Prixma IP 6210D
If there is no improvement with the quality of printing following such maintenance as print head
cleaning, a FINE Cartridge is probably empty. Replace the empty FINE Cartridge with a new one.
When replacing a FINE Cartridge, check the model number very carefully.
The printer will not print properly if a wrong FINE Cartridge is used, or installed wrong.
When a FINE Cartridge runs out of ink, replace them using the following steps.
1 Ensure that the printer is on.
2 Open the card slot cover first and then open the front cover.
The FINE Cartridge holder moves to the left.
3 Remove the empty FINE Cartridge.
Color: CL-51 [High Yield] Photo: CL-52
The standard Color FINE Cartridge (CL-41) can be installed as option.
-Handle the FINE Cartridge carefully to avoid staining clothing or the
surrounding area.
-Discard the empty FINE Cartridge according to the local laws and
regulations.
on Dec 08, 2009 | Office Equipment & Supplies
How do I know which toner is empty on samsung clp315
  • 1.Log on to your computer and print a test page to the printer. Click on the "Start" button, choose "Control Panel" and then "Printers and Faxes." Right-click on the laser printer, choose "Properties" from the drop-down menu and click the "Print test page" box.
  • 2.Look at the quality of the print on the finished page. If the print is light or faded, the ink cartridge is probably empty or at least empty enough that it should be replaced. You can try to get some extra life out of your toner cartridge by taking it out of the printer, shaking it vigorously and putting it back in. Under normal printing loads, this can give you one to three days of additional printing capacity.
  • 3.Open the printer cover and carefully pull out the toner cartridge. Set the cartridge aside while you open the box containing the new toner. Pull the new toner out but do not yet remove any of the packaging materials. Compare the weight of the new toner with the old one. If the old toner is very light, it is nearly empty and should be replaced.
  • Sep 22, 2011 | Samsung CLP 315 Laser Printer
    Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
    Here are some steps you can check to resolve your issue.
    Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
    Here are the instruction for cleaning your printer.
    Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
    click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
    For more information here is the link for step by step instruction with visuals.
    Hope this will help you resolve the problem.
    Thank you for choosing fixya
    Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
    My printer won't print anything. The colour inks are empty so they are removed but the black ink still has some left so it's the only one still inside. I try to test print some black and white only...
    you need to install all the print cartridges in the printer to work the sensors in the print cartridges are needed for the printer while if the empty cartridge is inserted ans not working you will have to buy anew one
    Mar 01, 2011 | Brother MultiFunction Center MFC-440CN...
    My Samsung 3160 does not print uniformly across the page. It prints good, except for about 1" going down the left side is very light or faded looking.
    try to remove toner cartridge and shake, plug in and make a self test print. if not work, you need to change new toner cartridge to make sure that the problem is not with printer itself.
    Apr 06, 2010 | Samsung CLP 300 Laser Printer
    Brother 420CN printer will not print black ink. Have replaced the cartridge and after several cleaning cycles, it still will not print properly. Test Print shows colors are fine but black ink is hit and...
    I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
    1. I go to Printer Properties
    2. Change Media type from "Plain Paper" to "Inkjet Paper".
    3. Change Quality to "Photo".
    This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
    Good Luck
    RK
    Dec 20, 2009 | Brother MFC 420CN All-In-One InkJet...
    Printing won't work.
    Good day sir/maam, hi, when you test print it usually prints letters and no lines are printed. try first if the printer is setup to economy/draft or pictures, if lines are faded, the ink cartridges maybe dirty. manual cleaning is needed, the ink path starts from the ink cartridge to the cradle or carrier then to paper. so any dried ink that blocks the path can affect the printout. you can use warm water to loosen dried ink. remove the cartridges and cradle from the printer as you clean them.
    Oct 27, 2009 | Office Equipment & Supplies
    Scanner Test Page Prints Fine, Everything Else Prints Faded
    have you changed your ink cartridges and seen a difference?
    Dec 24, 2008 | Lexmark X2500 All-In-One Printer
    Replaced empt 3E cartridge. Now it won't print
    I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
    Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    Epson Stylus  1400 InkJet Photo Printer Logo
    Top Epson Office Equipment & Supplies Experts
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
